Re: Electrical Engineers I need your help! [Re: PHJ426] #60390
05/29/08 11:40 AM
05/29/08 11:40 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Where is that switch located that is pictured in the schematic above the motor with the park and run positions.
To the best of my knowledge the switch you are referring to is built into the wiper motor gear assy.
Ron
Re: Electrical Engineers I need your help! [Re: Ronnman] #60391
05/29/08 06:32 PM
05/29/08 06:32 PM
Detroit
Got2Gnow Offline OP
Got2Gnow  Offline OP
Detroit
PHJ426 & Ronnman,
I have attached some documentation I've found about the WIPERS-OPERATION (on page 2 of the schematic).
It appears the PARK switch is built into the wiper motor assembly as Ronnman suggested.
With this information I believe the schematic should be correct if we use the "thick VIOLET" wire vs. the "thick RED" wire.
Do you agree?
Got2Gnow
Re: Electrical Engineers I need your help! [Re: Got2Gnow] #60392
05/29/08 09:13 PM
05/29/08 09:13 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
I agree use the thick violet wire and Omit the Red one in the last schematic.
I think you are good to go now.
Good luck and keep us posted on the progress.
Re: Electrical Engineers I need your help! [Re: PHJ426] #60393
05/29/08 09:22 PM
05/29/08 09:22 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I agree. Remove that Red wire from B+ to the upper switch or you will have a short and blow your fuse.
Re: Electrical Engineers I need your help! [Re: Got2Gnow] #60394
05/29/08 10:38 PM
05/29/08 10:38 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Got2Gnow, I will look at your schematic later. For some reason it will not open up right now. But based on what I recall, the red wire would not be needed.
Ron
Re: Electrical Engineers I need your help! [Re: Ronnman] #60395
05/30/08 11:55 AM
05/30/08 11:55 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Got2Gnow - Remove the red wire and looks like you have a winner!
Ron
Re: Electrical Engineers I need your help! [Re: Ronnman] #60396
05/30/08 07:58 PM
05/30/08 07:58 PM
Detroit
Got2Gnow Offline OP
Got2Gnow  Offline OP
Detroit
Paul, Ron, & Steve,
Attached is the final(?) version of the schematic. I really appreciate the guidance and opinions.
You guys rock!
Beers to you all!!
It will be sometime before I can get this all together and installled in the car, but I'll let you know how it turns out.
Now it's time to go shopping for the RedLine dash insert, some toggle switches, and a couple more gauges.
Thanks Again,
Got2Gnow
