Re: Main Fuel line size
[Re: jamesc]
#602638
02/03/10 11:04 PM
02/03/10 11:04 PM
Posts: 1,200 UK
602heavy
UK
9 sec et requires 180 gph , 8 sec et 240 gph
i don't know where these numbers come from.
a general rule of thumb is .5 PPH (pounds per hour) per horsepower. as mentioned the SG of race fuel is around .725. a gallon of water (SG of 1) weighs around 8.35 pounds. 8.35 x .725 = 6.05. so a gallon of race fuel is about 6 pounds. an 800 HP engine will need about 400 PPH of fuel. 400 divided by 6.05 = 66.11 gallons per hour for 800 HP. an actual 180 GPH of fuel will feed 2000 HP.
on another note let's face it racers are in love with their fuel systems. big manly pumps, -12 lines, half a dozen regulators...all trying to jam fuel through two (or four for dual carbs) .110" orifices, THAT'S where the restriction is the needle and seat.
Line size/volume, pressure , restrictions.........all come into play , might dig the mechanal fuel pump out that delivers 80 gph , should be enough to feed the 600" .
[Re: Cab_Burge]
#602639
02/03/10 11:04 PM
02/03/10 11:04 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Ask HillBilly Conquest How fast he has been with his 10 year old Holley blue? He skipped the 10, bypassed the 9's and landed in the 8's..This is a stock stroke 440 with a set of nice Indy heads. I know a gravity feed fuel cell feeding through -8AN fuel line (belt driven pump) with a -8AN return is good for 144MPH in the 8th with 1 second flat short times. I wonder what kind of pressure head I would be looking at with that setup... about 18 inches from the pump inlet to the top of the fuel cell, figure this would be full. that would be .433 x 1.5 =.6495 lbs this would be water pressure..so SG of fuel is what .75-.8 so....right at 1/2 lbs of head pressure. Does anyone know flow rate? Can figure out the gallons per hour as the pumps are rated for this? Figure 1.75 gallon, perfect world, no bends or friction loss for a 1/2 tube at this pressure using 1.75 gallon for a 8th mile run taking 10 seconds? This should cover burn out and a 4.7 second pass. From this we would know at least a -8AN line will feed this X amount of fuel in gallons per hour.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
#602642
02/04/10 01:21 AM
02/04/10 01:21 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
I have -12 from the cell to the pump. -10 from the pump bypass to the cell. -10 to the regulator and -6 to the carb.
[Re: 602heavy]
#602643
02/04/10 06:06 AM
02/04/10 06:06 AM
Posts: 5,875 communist bloc of new jersey
jamesc
i'm fully aware of friction losses etc. i've been pumping oil for the past 15 years. IIRC Dwayne Porter's Satellite (3800#?) ran low 11's with a stock fuel system as in 5/16" line and mechanical pump. Ken Bowers runs a holley blue on his 150+ MPH 500" B1 SST Cuda. but i guess these guys don't know what they're doing.
[Re: jamesc]
#602646
02/04/10 05:20 PM
02/04/10 05:20 PM
Posts: 1,200 UK
602heavy
UK
Been in the plumbing & heating industry for 35 years , if you read my post you will notice i mentioned guys going overkill with their fuel systems.
[Re: Bob_Coomer]
#602649
02/05/10 02:27 PM
02/05/10 02:27 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Im just wondering if -10 is overkill..I have a long section of -8AN hose and some fittings. I know on the dragster I ran -8AN running alky/methonal and it was what I would consider a pretty high demand system...it burnt 2 1/2 gallons of fuel per 8th mile run.
So how does one draw the line? Does duel carbs make a diff?
According to BG the 280 Pump doesnt require a return, which is fine by me. It says a -10 to from the fuel cell to the inlet of the pump, then -8 to the regulator.. I have the pump and there two port regulator, I wont be running there fuel filter..I will be running a earls 85 micron stainless mesh type filter.
http://www.barrygrant.com/bgfuel/default.aspx?page=85
If you had -8 and alky, it will feed 2.2 times the hp in gasoline. -10 tank to pump, -8 to regs, -6 to bowls ought to feed a LOT of motor! A tunnelram will require a bit less pressure, due to having twice the needles and seats. I went from a TR to a single dominter and problems showed up. My pump was hurting, but it got by till I needed the extra psi to feed only two bowls.
[Re: gregsdart]
#602650
02/05/10 02:48 PM
02/05/10 02:48 PM
Posts: 127 Dahlonega, GA
TechAtBG
Dahlonega, GA
Sorry guys I've been tied up this week putting our new Facebook page together so I didn't see this but looks like the majority of you have the right ideas.
Here are the recommendations we have for fuel line sizes with our pumps for optimum performance. Also try to keep any bends , 90's and such to a minimum.
BG280 -10 an feed and -8an to the regulator . This pump is rated for 650hp which also seems to be the range of the -8an line.
BG400 -12an feed and -10an to the regulator with a -8an from the bypass. This pump will feed over 1000hp.
Keep in mind every single application will be different and have different needs and what one guy gets away with 9 others may not.
Somebody will always make the argument well so and so ran xxx with a xxx pump but what would have happened if that person put a larger pump and lines on the car? In many cases we see them pick up and in others where somebody may have had to run the fuel pressure and floats up or had to put a ton of jet in they are now able to get back into a normal tuning window.
Having come from a nitrous background myself I would rather have too much fuel supply then worry whether I had enough. Erring to the big side also gives you room to grow down the road without having to change the fuel system up depending on the changes.
[Re: Bob_Coomer]
#602651
02/05/10 03:27 PM
02/05/10 03:27 PM
Posts: 16,930 NC
440Jim
NC
This is BG 280 fuel pump by the way and needs to feed 800+hp..
Some of those guys think they are feeding 2000 hp, not 800.
I really prefer hard line from the pump to the front. It has a larger inside diameter and less pressure drop due to curves in the hose.
Bob, I believe #8 line from the pump to the front (regulator) will be just fine. I do agree a return system is better than a dead-head at the regulator. When I used a carb, I ran two #8 lines from the cell to the filter/pump (Y-connection to solid line at inlet). But a #10 should be fine.
I also think putting #10 to the front is fine, just cost more and no benefit, at 800 hp.
