what do I use for break in oil... #602593
02/03/10 05:14 PM
02/03/10 05:14 PM
Escondido, California
JonGottaDemonDad Offline OP
I am putting a motor together and comp cam recommends that I use a break-in oil/additive to run in the motor for the first thirty minutes. I went to all the local stores Kragen/Oreily, AutoZone and Napa and no one sells the break-in additive.
What do I use as an alternative to break in oil?
Thanks,
Craig
Re: what do I use for break in oil... [Re: JonGottaDemonDad] #602594
02/03/10 05:20 PM
02/03/10 05:20 PM
AndyF Offline
AndyF  Offline
No speed shops in the local area? There are lots of different break in oils and additives. Hard to believe you wouldn't be able to find any on the shelf at a local store. You used to be able to get a break in additive from Mopar as well as GM. I think the GM stuff is still available but the Mopar stuff might be disco.
Re: what do I use for break in oil... [Re: JonGottaDemonDad] #602595
02/03/10 05:27 PM
02/03/10 05:27 PM
upstate NY 12839
TMBOOTS Offline
TMBOOTS  Offline
upstate NY 12839
My builder recommends Brad Penn break-in oil
Re: what do I use for break in oil... [Re: TMBOOTS] #602596
02/03/10 05:37 PM
02/03/10 05:37 PM
pretty weird... went to the biggest Kragen in the city and they have nothing... just checked with Carquest as well... NOTHING!
Re: what do I use for break in oil... [Re: JonGottaDemonDad] #602597
02/03/10 06:00 PM
02/03/10 06:00 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I live in a small town in East Tennessee and the local Advance Auto stocks COMP Cams Break in additive as well as the local NAPA. But we also got good corn squeeze.
Re: what do I use for break in oil... [Re: JonGottaDemonDad] #602598
02/03/10 06:08 PM
02/03/10 06:08 PM
N
newem Offline
newem  Offline
N
Any kind of Zinc additive is needed. Redline is one brand.
Re: what do I use for break in oil... [Re: newem] #602599
02/03/10 06:30 PM
02/03/10 06:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
valvoline vr1 racing oil has zinc in it....should be available at your local parts store.
Valvoline VR1: Contains 75% higher zinc than SM motor oil with a balanced additive package designed to work in both racing and street-legal applications. This product will protect older style push-rod and flat tappet engines. Valvoline provides this product in both multi and mono viscosity grades: 20w50, straight 50, 10w30, straight 30, straight 40, and straight 60.
Tony
70 AARCuda Vitamin C
Re: what do I use for break in oil... [Re: 70AARcuda] #602600
02/03/10 06:52 PM
02/03/10 06:52 PM
ok... I have called all over to find this with no luck I am going to use the race oil recommended. It is available at the local parts store.
One more question. Do I need to change the oil after the breakin or am I ok to just leave the race oil in the motor?
All I did was replace the lifter in the motor.
Thanks,
Re: what do I use for break in oil... [Re: 70AARcuda] #602601
02/03/10 07:23 PM
02/03/10 07:23 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Valvoline does sell an oil that has the significant zinc level. The above oil is not it. Its as simple as this, if any oil has an API rating of SM, by regs it cant have more than a certain PPM of zinc. The oil that Valvoline sells that does have the zinc is marked "Not for street use" on it and does not have a API rating.
To the OP, did you coat the cam and lifters with lube? Are your inner valve springs pulled out, if applicable? Did you verify that you have lifter rotation? If yes to all 3, get Rotella 10-30 or 15-40. If you cant get the EOS (which GM renamed, and I cant remember the name) from a GM dealer, get a red bottle of STP and you should be good to go.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: what do I use for break in oil... [Re: JonGottaDemonDad] #602602
02/03/10 07:23 PM
02/03/10 07:23 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Thanks,
No Joe Gibb? Yes, change the oil after break in to flush out all the little particles.
Re: what do I use for break in oil... [Re: Von] #602603
02/03/10 07:38 PM
02/03/10 07:38 PM
Valvoline does sell an oil that has the significant zinc level. The above oil is not it. To the OP, did you coat the cam and lifters with lube? Are your inner valve springs pulled out, if applicable? Did you verify that you have lifter rotation?
(1) The (above mentioned) valvoline racing oil is considered a street oil . (2) & for sure lifter rotation
Re: what do I use for break in oil... [Re: RapidRobert] #602604
02/03/10 11:24 PM
02/03/10 11:24 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[ The (above mentioned) valvoline racing oil is considered a street oil
Im not sure what you are asking. The VR-1 available at most auto parts store has a API SM rating on it, hence no zinc.
The good Valvoline says "Not for street use", but in theory any oil without a API rating is not supposed to be used on the street.
Re: what do I use for break in oil... [Re: Von] #602605
02/03/10 11:41 PM
02/03/10 11:41 PM
Yes my wording was vague. OK so the VR-1 is an SM (street)oil (not high zinc) and there's another valvoline oil that IS high zinc? If I got it straight what is the hi zinc valvoline oil and the VR-1 says "not for street use" but is a racing oil but is not a high zinc oil?
Re: what do I use for break in oil... [Re: RapidRobert] #602606
02/04/10 12:01 AM
02/04/10 12:01 AM
"Valvoline does sell an oil that has the significant zinc level. The above oil is not it. Its as simple as this, if any oil has an API rating of SM, by regs it cant have more than a certain PPM of zinc. The oil that Valvoline sells that does have the zinc is marked "Not for street use" on it and does not have a API rating.
To the OP, did you coat the cam and lifters with lube? Are your inner valve springs pulled out, if applicable? Did you verify that you have lifter rotation? If yes to all 3, get Rotella 10-30 or 15-40. If you cant get the EOS (which GM renamed, and I cant remember the name) from a GM dealer, get a red bottle of STP and you should be good to go. "
coat the cam and lifters? YES
inner valve springs pulled out? N/A
lifter rotation? YES
I talked to the Napa guy today and he told me about the Rotella oil as well. Sounds like a pretty solid plan. He told me he used it successfully as well.
Craig
Re: what do I use for break in oil... [Re: JonGottaDemonDad] #602607
02/04/10 02:08 AM
02/04/10 02:08 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
It's still called EOS and it's part # 88862586 and should be available at any GM dealer or Summit, Jegs etc.
http://www.summitracing.com/parts/NAL-88862586
My
Own
Personal
Adrenaline
Rush
Re: what do I use for break in oil... [Re: Moparzrule] #602608
02/04/10 02:11 AM
02/04/10 02:11 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
My
Own
Personal
Adrenaline
Rush
Re: what do I use for break in oil... [Re: JonGottaDemonDad] #602609
02/04/10 09:56 AM
02/04/10 09:56 AM
United States
V
v269 Offline
v269  Offline
V
United States
Re: what do I use for break in oil... [Re: v269] #602610
02/04/10 11:28 AM
02/04/10 11:28 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
VR1 Racing Oil (VR1)
The #1 selling racing motor oil. High zinc provides race-level protection for any vehicle.
High zinc/phosphorus provides extreme wear protection, including flat tappet applications
Additional friction modfiers to help deliver maximum horsepower
Enhanced anti-foam system protects engine during extreme stress
Compatible with gasoline or alcohol fuels
Available through leading auto parts retailers
http://www.valvoline.com/products/consumer-products/motor-oil/racing-motor-oil/6
valvoline says it has high zinc protection for flat tappets...and available through leading auto parts retailers...
been using the 20w-50 for several years now..with solid lifter cams..
Tony
Re: what do I use for break in oil... [Re: 70AARcuda] #602611
02/04/10 11:38 AM
02/04/10 11:38 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
This is the right VR1 for break in, and everyday use with high spring psi, not sure how many PPM of zinc it has but should be over the safe minimum of 1300ppm.
http://www.valvoline.com/products/consumer-products/motor-oil/racing-motor-oil/9
Re: what do I use for break in oil... [Re: TMBOOTS] #602612
02/04/10 12:42 PM
02/04/10 12:42 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
71 scamp big block with 915 heads 727 trans
