Re: Those with mini tubbed Dusters/Demons, what ....
[Re: StrokerPost]
#60187
11/06/11 06:06 PM
11/06/11 06:06 PM
Posts: 4,085 Indiana
W5Duster436
Indiana
Like most already stated, IMHO, if you don't want to trim, a 28" is all you'll stuff underneath a duster so no real use in mini-tubbing it. Mine has the offset shackle kit, standard width a-body 8 3/4 and Billet Specialty Street Lites that are 15x10 with 6.5BS. Currently I have 1/2 billet spacers that will get cut down to 1/4" this winter just to center the wheel a little better. Also even with the MT ET Drag 275/60/15's I had to put in 1/2 thick spacers in between the frame and the front spring hangers to get the wheels spaced forward/backward.
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: Dusted U]
#60193
11/08/11 04:42 PM
11/08/11 04:42 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Here's my duster with 325 50 15s on a 15x10 with 6" bs
Dusted U, what is the width of your rear axle, drum to drum? Did you move it back any or trim the front edge of the wheel lip? That's the exact tire I am trying to get under a Demon, but I want to do it with a stock width A body rear, in case I ever decide to go back to a stock width rim.
[Re: Dusted U]
#60196
11/09/11 09:00 PM
11/09/11 09:00 PM
Posts: 136 PENNSYLVANIA
HAUK67
PENNSYLVANIA
I run a 15x10 3.5 back spaced and a 325/50/15 tires..
[Re: HAUK67]
#60197
11/09/11 09:21 PM
11/09/11 09:21 PM
HAUK67
PENNSYLVANIA
another shot
