50 truck hot rod project
#599978
01/31/10 06:30 PM
01/31/10 06:30 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
What's the cheapest way to lower the front of the 85 coil spring chassis? Some say cut others say heat. what's the cheapest and best method? How is it done?
4bbl
If you can't hear it coming what's the point.......
Re: 50 truck on to 85 chassis, lower?
[Re: poorboy]
#599981
01/31/10 10:59 PM
01/31/10 10:59 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
Nice looking 4x4. You're right the front wheel opennings are going to be changed quite a bit, but that's the plan.
4bbl
[Re: 4bbl]
#599982
02/07/10 12:03 AM
02/07/10 12:03 AM
Posts: 1,970 ID/MT
Cheeto
ID/MT
Mustang offset wheels may fit those tires inside the wheelwells. Just be sure you have the room between the tire and frame/suspension.
If you're going cheap on the springs then I vote for cutting . Do it with a chop saw or cutoff wheel though to minimize the amount of heat you put into the coil.
Cheeto It's not perfect. It's not correct. It's not yours!
[Re: Cheeto]
#599983
02/21/10 09:41 PM
02/21/10 09:41 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
fire wall in now. about off to the blaster
4bbl
[Re: poorboy]
#599985
02/22/10 10:11 PM
02/22/10 10:11 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
new pic of fire wall. sorry , just started with pictures
4bbl
[Re: fstfish66]
#599987
02/23/10 09:10 AM
02/23/10 09:10 AM
Posts: 163 Iowa,US
4bbl
Iowa,US
Thanks, I noticed something though. I need to reconstruct the drip rail in the upper middle of the fire wall. I don't want to get the distributor wet when I wash the thing.
4bbl
[Re: poorboy]
#599989
02/23/10 11:09 PM
02/23/10 11:09 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
Here is another look during construction to give a better idea of depth at the top. Things tapper back to clear the 727 bell area. I plan on a small center hump, with drink tray kind of stuff. I kepth the cab body back and hope to sneak the front wheel openings forward as far as possible with out looking wierd, but as you see, that,s a ways off yet.
4bbl
[Re: 4bbl]
#599990
02/25/10 11:11 PM
02/25/10 11:11 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
Snow is too deep to get it out the door but ready for the blaster after a little de-greasing. 85 chassis, shortened 22.5 inches (took the "z" out and rear axle over the springs with 2" lower blocks
4bbl
[Re: 4bbl]
#599991
02/28/10 12:38 AM
02/28/10 12:38 AM
Posts: 163 Iowa,US
4bbl
Iowa,US
Chassis ready to go to the media blaster, back to work on the cab so it can go when we pick the chassis up. See where 22.5 inches cut out,and boxed area.
4bbl
[Re: 4bbl]
#599992
03/07/10 02:44 PM
03/07/10 02:44 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
spring hanger pic, chassis is gone to blaster. Should be painted and motor back in by next weekend
4bbl
[Re: 4bbl]
#599993
03/07/10 04:32 PM
03/07/10 04:32 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
drip rail is completed. Should keep things dry now
4bbl
[Re: 4bbl]
#599994
03/07/10 05:31 PM
03/07/10 05:31 PM
Posts: 15,487 Florida
scratchnfotraction
on a stock 85 truck with the axle floped,that rear rubber stop is gonna be real close to the axle tube makes a 5-150 almost scrap like that,but may not with yous..depends on the wieght the flip flop and pocketed/short spring is the best ride for the 85 frame and ez to do cheaply great project,nice workmanship ![](/ubbthreads/images/graemlins/bow.gif)
[Re: poorboy]
#599996
03/09/10 02:39 PM
03/09/10 02:39 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
did not se the drain fitting until the other day. Good point thanks
4bbl
[Re: 4bbl]
#599997
03/27/10 02:31 PM
03/27/10 02:31 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
Cab going to media blaster
4bbl
