Re: Gotta little more done
[Re: wheelsup68dart]
#597797
01/30/10 11:49 AM
01/30/10 11:49 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
10.60's
ON the other hand, knowing my luck
[Re: WILD BILL]
#597800
01/30/10 08:58 PM
01/30/10 08:58 PM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Does that paint stay one pretty good? I wanted to paint the inside of mine, but was concerned that it would come off and clod up oil pick up or mess up oil pump. What about out side? Just paint or primer first? Brian
[Re: WILD BILL]
#597801
01/30/10 09:04 PM
01/30/10 09:04 PM
Scott's hoping for 700+ HP. I really don't know what to expect and am trying to remain realistic.
The paint was Rustoleum rust metal primer and it's purpose is to speed up oil return as well as seal the metal and seal in any residule casting sand that may still be there.
Car weighs 2820 W/o me and 2960 on the line. Might be a little less now with some parts on this build being lighter than what I was running.
Wild bIll, 1st you should of painted the inside Blue!
2nd,your telling me you weigh 140 lbs. Jesus, i weighed that as a freshman in High School.
#597802
01/30/10 09:19 PM
01/30/10 09:19 PM
WILD BILL
BROOK PARK, OH
No I hit the wrong dam key. I weigh around 160 so it should read 2980
I'm sure the paint will hold up fine inside the block.
[Re: '72CudaRacer]
#597804
01/30/10 09:27 PM
01/30/10 09:27 PM
WILD BILL
BROOK PARK, OH
Are you going to also put paint on the inside, or leave it primer?
I'm sure I'll find out next Thur when I can get back out there
I did pick up the paint for the outside of the block though
#597810
01/30/10 11:30 PM
01/30/10 11:30 PM
WILD BILL
BROOK PARK, OH
Most of last years motor is not being used. We are using the block and forged crank that I had in my garage.
It is a factory forged crank though so no stroker.
Pistons are from Weisco's Pro Tru line and the rods are K1 H beams. My old motor had Hyper pistons and LY rods W/ a cast crank.
[Re: hemi-itis]
#597811
01/30/10 11:32 PM
01/30/10 11:32 PM
WILD BILL
BROOK PARK, OH
Bill,your car is about 1000 lbs lighter than my junk
Start then
[Re: tboomer]
#597813
01/31/10 12:46 AM
01/31/10 12:46 AM
WILD BILL
BROOK PARK, OH
Flat tops
The plan was to use to use my 555 solid flat tapet cam.
Then again not much of the original plan is holding true so
#597815
01/31/10 12:52 AM
01/31/10 12:52 AM
WILD BILL
BROOK PARK, OH
BTW who is building a trans to hold up to the new power level.
