MP .557 solid cam help needed #596002
01/27/10 08:55 PM
01/27/10 08:55 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
I am 95% decided to go with the Lunati 60305 Hyd cam in my motor..
Here is Combo....
'71 440 Block .30 over
All neccesary machine work/ fully balanced
Block square decked
Ross 99539 pistons/ 2.065 Comp. Height
New Scat Rods
Lunati 60305 cam/lifters
440 Source stealth heads/Crane Ductile adjustable rockers, bushed by RAS/ Bananna groove shafts
Holley SD intake
Holley 850 DP
1 7/8 headers/ 3" exhaust w X pipe
MP Ignition
3.91 gears
Windage Tray
I have gotten numerous suggestions to go with the mp.557 solid cam. Here is my dilemma. This being my 1st high performance build I have "0" experience with a solid cam.
Can someone in a nutshell explain how to adjust valve lash. Is it relatively easy to do once figured out? Does motor need to be running while doing this?
I don't have my FSM handy, does it go into this in there??
Chuck
Re: MP .557 solid cam help needed [Re: moparrulzzz] #596003
01/27/10 09:03 PM
01/27/10 09:03 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
You can rough the lash cold then finish hot, engine not running. You can get a tape to put on the damper that will guide what valves to adjust. You will need different pushrods than the ones for a hyd cam. much more and you really do need a FSM- at least the first coulpe of times anyway. I have a different procedure that I use, but I've been a tech for nearly 26 years. I always recommend starting off from the book(s), you'll learn then shortcuts later.
Re: MP .557 solid cam help needed [Re: moparrulzzz] #596004
01/27/10 09:23 PM
01/27/10 09:23 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
Once you have gone solid, you won't go back.You will need differant pushrods(make sure your springs are ok with the 557,(which by the way rocks IMO).Setting lash is no big drama and contrary to popular old wives tales need not be done all that often,... as long as no valvetrain problems are present to start with.Setting lash cold is fine,pull the valve covers and set up 1 cylinder at a time.Lash is over-rated and although you should follow the manufacturers specs, the engine only really cares to see some clearance at operating temperature.There is a voice in your head saying...go solid...go solid
Re: MP .557 solid cam help needed [Re: moparrulzzz] #596005
01/27/10 09:26 PM
01/27/10 09:26 PM
adj each rocker arm when its cam lobe is on the cam base circle (several methods to do this). eng off/plugs out/breaker bar/1&1/4" socket on crank bolt. hand turn it to reach each adjusting point. If the spec is for example .020" adj it to where a .019" feeler gauge has NO drag and a .021" gauge has a SLIGHT drag. then start the eng & when it is warmed up (or after a 20-30 min 2500 breakin) then shut it off & pull the plugs and repeat the above. Some adj them while running, I do not. If the cam gives a cold and a hot spec(s) then go w that. If this is a new cam/lifter(s) breakin I'd adj the valves (cold) then take off the rocker shafts and regoop the lobe/lifter bottoms w the rocker screw adjustment untouched as alot of hand turning will wipe the goop off & with this much $$$ invested it's not the time to take shortcuts
Re: MP .557 solid cam help needed [Re: Skeptic] #596006
01/27/10 09:26 PM
01/27/10 09:26 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I initially lash cold using the 180º method so I can do 4 valves at a time. Since you have aluminum heads, subtract .005" from the cam card recommendations ( .020" - .005" = .015" ) if you cold lash.
Check the tech archives here, there might be step by step instructions.
Re: MP .557 solid cam help needed [Re: 64Post] #596007
01/27/10 11:08 PM
01/27/10 11:08 PM
Mansfield,Ohio
Mansfield,Ohio
Thnx for the info guys. I need to chew on this some more but I think I may go ahead and go solid!!
I will get my FSM out and read up and look in the tech archives here!!
Thnx!!!
Chuck
Re: MP .557 solid cam help needed [Re: moparrulzzz] #596008
01/28/10 12:13 AM
01/28/10 12:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Chuck I am sorry I did not get back to your PM as I am feeling much better today. As was stated you need the lifter on the cam base to adjust and I just do mine by cranking the eng and watching the valves to know where they are. Adjust them cold when you assemble it and the after it runs a bit pull the covers and adjust them again hot without the eng running. I love the .557 cam my self as it works great in my 63 and my boys Dart. You can PM me anytime as I will try to help all I can. Good luck. Ron
Oh and I only adjust my valves once a year. And I drive my 63 alot in the summer.
Re: MP .557 solid cam help needed [Re: moparrulzzz] #596009
01/28/10 12:23 AM
01/28/10 12:23 AM
Long Island, NY.
Stroked65Belv Offline
Long Island, NY.
It is a huge undertaking to maintain a solid lifter cam. Especially if your a part time driver/streeter cruiser type. If so then go roller or hyd. Solids take time to set up and for the most part you have to inspect!
I run an Ultradyne .577 solid in my 440/498 stroker. Had I built this engine I would had gone roller but the power now is tremendous and scary fast. Not many "cams" have it as solids do..
go see a few old school builders and ask away!
Im stuck with what I have for now but I tell you, this cam is crazy! set up right you can get huge power...
Re: MP .557 solid cam help needed [Re: Stroked65Belv] #596010
01/28/10 12:27 AM
01/28/10 12:27 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Dead wrong.
As long as you have good adjusters you shouldnt need to adjust the valves very often.
Now if you have crap adjusters, that is another story. DAMHIK.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: MP .557 solid cam help needed [Re: Stroked65Belv] #596011
01/28/10 12:49 AM
01/28/10 12:49 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I just don't get it,my Ultradyne solid cam has never needed any real effort,just don't assume all valve springs are the same,just because they have similar numbers doesn't mean good valvetrain life.I wouldn't put a .557 mopar in anything,unless it had shag carpet.The last Mp .557 cam was a dog when 2 other cams were run against it at the track,maybe MP ground me a dud?
Re: MP .557 solid cam help needed [Re: goldmember] #596012
01/28/10 03:09 AM
01/28/10 03:09 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The MP .557 cam a dog ?? I have had that cam in at least 4 cars and they all run very hard. I would think the car you talk about had other problems as I have always seen everyone happy with the .557 cam. Ron
Re: MP .557 solid cam help needed [Re: Von] #596013
01/28/10 03:12 AM
01/28/10 03:12 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dead wrong.
Von is dead right. As I stated I drive my 63 alot and race it 3 or 4 times a year and I only adjust my valves once a year. And they are usually not out of adjustment or only out a very little bit. I just use standard ductile iron rockers. Ron
Re: MP .557 solid cam help needed [Re: goldmember] #596014
01/28/10 03:17 AM
01/28/10 03:17 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
I agree you should use the 180 method since you are new to adjusting the valves.As far as the cams I prefer the Lunati.You will have a huge difference in mid range torque with the Lunati.Top end H.P. will be close between the two cams.As far as the .557 it is the only MP cam I would use if I had no other choice.Ultradyne,Engle and others have some terrific solid lifter cams.One note if you decide to run a solid invest in a set of edm (oiling) solid lifters.
Leave the gun.......take the Cannoli's....Mike
Re: MP .557 solid cam help needed [Re: mike s] #596015
01/28/10 08:17 AM
01/28/10 08:17 AM
NJ
440challenger Offline
NJ
557 kicks azzzzz
11.30s in a full street car with power brakes
Re: MP .557 solid cam help needed [Re: 440challenger] #596016
01/28/10 09:14 AM
01/28/10 09:14 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
What is the current part# for the cam and or cam and lifters?
Re: MP .557 solid cam help needed [Re: dOc !] #596017
01/28/10 11:15 AM
01/28/10 11:15 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
I don't know how true this is but I've been told to steer clear of the MP cams. I guess they are now a happy china part. And are having more than normal cams going flat. I guess it's a hardness issue.
Re: MP .557 solid cam help needed [Re: 70VcodeCoronetRT] #596018
01/28/10 11:32 AM
01/28/10 11:32 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Country of origin is USA.
They're processed and machined in Jackon Michigan and packaged in Adrian Michigan.
I have two wiped Comp cams under my desk, and my buddy has a wiped Lunati he threw in the dumpster a couple weeks ago, but you'll never catch me posting any "made in" lies about their products. All the major cams out there are generally good but ---- happens sometimes.
Re: MP .557 solid cam help needed [Re: ZIPPY] #596019
01/28/10 12:21 PM
01/28/10 12:21 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Were these cams purchased before or after the nitriding process?
Re: MP .557 solid cam help needed [Re: dOc !] #596020
01/28/10 12:51 PM
01/28/10 12:51 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
go with the 557, awsome cam, have it heat treated to be safe.
Re: MP .557 solid cam help needed [Re: 70VcodeCoronetRT] #596021
01/28/10 12:54 PM
01/28/10 12:54 PM
I've heard the same complaints for 20 years regarding MP cams and valves
