Re: Dipping and E-coating? [Re: QuickSilver] #592267
01/28/10 09:02 PM
01/28/10 09:02 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
Quicksilver,
was this on cars that were just stripped, or stripped and e-coated?
'71 Duster
Re: Dipping and E-coating? [Re: ta340] #592268
01/28/10 10:20 PM
01/28/10 10:20 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
ta340...If you don't mind, please email me.
I'd like to discuss the quality of that ecoat.
Brad
brad@dornautocraft.com
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Dipping and E-coating? [Re: warmpancakes] #592269
01/28/10 11:32 PM
01/28/10 11:32 PM
ohio
ta340 Offline
ta340  Offline
ohio
why did you ecoat with fenders on?
Mayflowers main job is doing semi-cabs. They put your car on their processing line. The car has to be mounted to their fixtures. The more you can have bolted on the car body the better. Car doors can be put on a smaller fixture to be dipped. I shimed the fenders with washers so the ecoat could get in between. The more they have to rig up on the fixtures the more it cost you. When I had mine done, they tried to do one car a month. They scheduled you a day to bring it in at 9:00am and you were done by 3:00pm. I had mine done 2 years ago and have not seen any problems yet.
Re: Dipping and E-coating? [Re: Thackdaddy] #592270
01/29/10 12:15 AM
01/29/10 12:15 AM
Oh
His and Her 69's Offline
Oh
So let me get this Correct,
If it was stripped the chemical way that this electrolisis would NOT have happened even if it wasn't all rinsed out????
I like the e-coat and it's protective covering but I will Not go thru this headache again.
I have some 36 ply coupe fenders, hood and grill surround that I would like to get e-coated so I am wondering now about the chemical strip first.
I will not do the parts that have wood in them but want to do the other stuff that doesn't.
I have taken stuff to american metal cleaning before. I wasn't happy with the handling of the parts as they did get more dents in them but dents are easier to take care of then the electrolisis.
How would you do these items Quicksilver??
David
you can send a pm if you want.
Re: Dipping and E-coating? [Re: His and Her 69's] #592271
01/29/10 12:20 AM
01/29/10 12:20 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
American metal cleaning does great work when you catch Greg (the owner) there. When you get his wife you better have KY available. Shes the most rude/ crude person i have ever met and will break it off in you anyway possible. He will make sure your parts are taken care of. she on the otherhand could give a sh*t less.
Re: Dipping and E-coating? [Re: prochargedhemi] #592272
01/29/10 01:52 AM
01/29/10 01:52 AM
Oh
Oh
When I talked to them I talked to him.
When I dropped off the parts she took care of it.
Maybe that explains it then.
I do know they picked up a coupe body by the 1/4 windows and messed up the body on a friends 37 chevy. They gave him the dip for free and he had to repair the body himself. He even asked them NOT to lift it that way and they aggreed to it.
Oh well I guess there isn't too many places around that does this kind of work so it is what it is.
David
Re: Dipping and E-coating? [Re: His and Her 69's] #592273
01/29/10 10:14 AM
01/29/10 10:14 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
to me it sounds like alot of risk invovled in dipping just to get it a tiny bit cleaner than you could do with a media blaster.
Re: Dipping and E-coating? [Re: chrisf] #592274
01/29/10 10:58 AM
01/29/10 10:58 AM
Temperance, MI
P
P
Temperance, MI
Theres just as much risk media blasting though.
The nice thing about dipping is everywhere is clean not just were you can get a nozzle. The biggest problem i see with stripping is getting the acidic stuff all washed out and neutralized.
Re: Dipping and E-coating? [Re: chrisf] #592275
01/31/10 02:36 PM
01/31/10 02:36 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Media doesn't remove any rust . Dipping removes it all .
I have cars that were dipped 8 years ago without issue .
The most important thing is to get them clean after dipping and use plenty of epoxy primer .
here is a pic of TA340's car after paint .
Re: Dipping and E-coating? [Re: FY1TA] #592276
01/31/10 04:32 PM
01/31/10 04:32 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Media doesn't remove any rust????????
Admiration For Multiple Carburetor Vehicles...
Re: Dipping and E-coating? [Re: Stewpar] #592277
01/31/10 05:25 PM
01/31/10 05:25 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
if you use sand it will . But sand will ruin sheetmetal . Media is plastic . It won't take off rust neither will soda .
Re: Dipping and E-coating? [Re: FY1TA] #592278
01/31/10 05:51 PM
01/31/10 05:51 PM
Jacksonville Florida
elitecustombody Offline
lol,who told you media is plastic? There are many types of media,and it does remove rust
Here are some types of blasting media :corn cob,glass bead,pumice,ceramic shot,stainless cut wire,steel shot,walnut shells,steel grit,aluminum oxide,silicon carbide,crushed glass,plastic media and more
Re: Dipping and E-coating? [Re: elitecustombody] #592279
01/31/10 06:39 PM
01/31/10 06:39 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Well excuse me . Plastic around here is called media .
Re: Dipping and E-coating? [Re: FY1TA] #592280
01/31/10 10:53 PM
01/31/10 10:53 PM
so what do they call media other than plastic ?
Re: Dipping and E-coating? [Re: elitecustombody] #592281
02/01/10 09:22 PM
02/01/10 09:22 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
they call it media.
