Re: 360 backfiring through carb and exhaust [Re: 77DragracerR/T] #592196
01/26/10 11:35 AM
01/26/10 11:35 AM
GA
roadrunninMark Offline
GA
Change the #2 and #7 plugs, get new ones. Replace the gasket that is missing the piece. Start the car up and see how it runs. Check to see if you burnt any of the spark plug wires as well, if they were laying on the exhaust or too close. Replace if any are burnt.
Mark
Re: 360 backfiring through carb and exhaust [Re: roadrunninMark] #592197
01/30/10 10:29 PM
01/30/10 10:29 PM
Illinois
SGTFURY62 Offline
SGTFURY62  Offline
Illinois
any news?
Re: 360 backfiring through carb and exhaust [Re: 77DragracerR/T] #592198
01/31/10 12:33 AM
01/31/10 12:33 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
If a cam lobe is gone you'll have a lot of excessive play in the rocker.
You will also have metal in the oil. Hold the valve cover in the sun and look for "metal flake". Sounds like you have a carb issue to me.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: 360 backfiring through carb and exhaust [Re: MattAman] #592199
01/31/10 02:51 PM
01/31/10 02:51 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
start with the basics. check compression of all cylinders. needs to be within 10% from lowest to highest. please post the results.
Re: 360 backfiring through carb and exhaust [Re: SixDRacing] #592200
02/06/10 11:33 AM
02/06/10 11:33 AM
MattAman Offline OP
MattAman  Offline OP
Thanks to everyone for the help so far. Shoveling snow has been keeping me from the garage so I don't have much news to report. I decided to pull the intake so I could get a good look at the cam and rule out a leaking intake gasket. The cam looked fine to me and all the pushrods are in the lifters and none seem bent. Based on what I read above, my next step should be a compression test. Before I put everything back together, can I run the test? I read that the engine needs to be warm to get the best results, but thought I should see what the group thought.
Thanks,
Matt
Re: 360 backfiring through carb and exhaust [Re: MattAman] #592201
02/06/10 11:40 AM
02/06/10 11:40 AM
warm is ideal and gives you the highest readings but a cold test will for sure suffice here as we are seeking a cyl that is not doing it's job (for one reason or another)so we can rule out the long block so the variations and of much less concern the total will tell us if your long block is healthy. EDIT be sure to block the choke and the throttle all the way wide open
Re: 360 backfiring through carb and exhaust [Re: RapidRobert] #592202
02/06/10 01:52 PM
02/06/10 01:52 PM
MattAman Offline OP
MattAman  Offline OP
Do I have to do the test with the intake and carb back on?
Re: 360 backfiring through carb and exhaust [Re: MattAman] #592203
02/06/10 03:14 PM
02/06/10 03:14 PM
Do it as is & lets see what you got. Pull the plugs and if a helper is using the key to crank it take off the pentastar ECU connector. Let er rip & post some #'s.
Re: 360 backfiring through carb and exhaust [Re: RapidRobert] #592204
02/06/10 04:56 PM
02/06/10 04:56 PM
MattAman Offline OP
MattAman  Offline OP
Just ran the compression test. Here are the numbers:
#1 - 150
#2 - 140
#3 - 165
#4 - 170
#5 - 150
#6 - 160
#7 - 150
#8 - 150
Could this be a head gasket leak between #2 and #4? The numbers all seem good to me, but the variance between these cylinders has me thinking. Thoughts?
Thanks,
Matt
Re: 360 backfiring through carb and exhaust [Re: MattAman] #592205
02/06/10 05:04 PM
02/06/10 05:04 PM
michigan woods
imfixinmopars426 Offline
michigan woods
what intake? if its a edelbrock w/ a spreadbore pattern [performer/sp2p??]ect ect,do you have the gold plate under the carb? this prevents a vacuum leak in the 2ndary area of the intake to carb area.might be a chance?
Re: 360 backfiring through carb and exhaust [Re: imfixinmopars426] #592206
02/06/10 05:38 PM
02/06/10 05:38 PM
MattAman Offline OP
MattAman  Offline OP
It has an Edelbrock Performer RPM with squarebore.
Re: 360 backfiring through carb and exhaust [Re: MattAman] #592207
02/06/10 09:27 PM
02/06/10 09:27 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
check for a broken valve spring.
Re: 360 backfiring through carb and exhaust [Re: SixDRacing] #592208
02/06/10 09:32 PM
02/06/10 09:32 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
You have a major timing issue. Rotate engine to TDC compression stroke and check to see if #1 is being pointed at under the dist cap. My vote is a broken oil pump gear or something let go in the dist, timing chain.
Re: 360 backfiring through carb and exhaust [Re: wheelsup68dart] #592209
02/07/10 02:50 AM
02/07/10 02:50 AM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
if timing chain breaks, no compresion and no start. if oil pump gear or dist breaks, no start.
Re: 360 backfiring through carb and exhaust [Re: SixDRacing] #592210
02/07/10 12:23 PM
02/07/10 12:23 PM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
I thought I'd replied; since #7 and #2 are right next to ea other in the firing order I'd look for bad wires, bad dist cap (carbon track between them?) etc.
Re: 360 backfiring through carb and exhaust [Re: volaredon] #592211
02/09/10 09:51 PM
02/09/10 09:51 PM
MattAman Offline OP
MattAman  Offline OP
Thanks for the continued help. I checked the cap and wires and they are fine. Any other thoughts based on the compression numbers I posted above?
Re: 360 backfiring through carb and exhaust [Re: volaredon] #592212
02/09/10 10:03 PM
02/09/10 10:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
5 & 7 are right next to each other in firing order in the cap and on the engine. Very easy to mix those 2 wires up without noticing it. At an idle the miss when this happens is sometimes barely noticeable due to the closeness of the firing in the firing sequence, but under a slight load condition or slight pull the miss becomes very noticeable and can cause backfiring under load.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 360 backfiring through carb and exhaust [Re: MoparforLife] #592213
02/10/10 10:04 AM
02/10/10 10:04 AM
PA.
3
340rocks Offline
340rocks  Offline
PA.
nobody mention ing coil Ihave msd coil #8253 on my 340 backfired one day stalled got it restared ran poorly started to smoke from tailpipes changed msd box didnt work changed coil was back to normal when it backfired blowed out Intake gsks. your Comp readings are fine I did same ckd .comp readings were 35psi off please try know good coil
Re: 360 backfiring through carb and exhaust [Re: 340rocks] #592214
02/10/10 10:23 AM
02/10/10 10:23 AM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
Is this a new re-build with a new cam lifters etc.? Or has the engine been in the car and run just fine last year etc.? If the engine has been in the car and ran fine last year, what changes were made from when it ran just fine until now? Did you change ignition setups? Did you change the distributor? Did you add gas to the tank? It could be bad gas. I would pull the carb off and empty all the gas out of it and use dry air and blow the carb out as best as you can. I am with Andy F that some debri is probably caught in the carb. Especially if the car runs at higher RPM's with no problem. The debri is probably clogging up the transition circuit from off-idle.
Re: 360 backfiring through carb and exhaust [Re: dm69charger] #592215
02/10/10 10:31 AM
02/10/10 10:31 AM
Upper Midwest
Upper Midwest
I missed that and if this is right it almost has to be fuel related. This gas now days don't take long to gum things up.
