Re: New H beam rods-best way to measure length?
[Re: '72CudaRacer]
#592128
01/24/10 12:52 AM
01/24/10 12:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Well if you can measure it to the 4th point, the way you did it would be fine... as to why they're short... that would be a manufacturing problem. You could make up a checking fiture but it probably wouldnt be much better... if any
[Re: '72CudaRacer]
#592130
01/24/10 01:09 AM
01/24/10 01:09 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Dial caliper ? That will get you pretty doggone close. Tape measure ? I could see being of by a couple thou. That is how I measure them ......... or a couple different snap gauges and a dial caliper if I'm feeling saucy !
