Re: How To Attach Vent Window Glass
[Re: BeBeep]
#592107
01/24/10 12:25 AM
01/24/10 12:25 AM
Posts: 18,167 Mass
DAYCLONA
Mass
Bob,....most find out how big that gap is when it removed for chroming, which usually destroys the black hard plastic seal,....I usually just use black windshield aycrlic/ureathhane windshied adhesive,..do not use silicone, or cheap tube sealers, spend the money for a caulking tube of windshiel adhesive, put a good bead in the groove, install the glass, proping it up vertically to dry, leave it for a few days to really set up, before subjecting it to use/installation, center the glass in the channel, side to side, so you have an even bead/gap on each side of the vent glass,...Mine have been in for over 5 years, you wouldn't know looking at them, that it's adhesive, no problems/issuses with use
Mike
[Re: BeBeep]
#592108
01/24/10 01:13 AM
01/24/10 01:13 AM
moparpollack
Lil Herman
Lil Herman
85086
Honestly mine didn't slide in I hammered it in with a rubber mallet. Not the smartest thing I've ever done but that's how I did it on my 67 Coronet. I switched out the frames and the pitfree pivots had clear glass that needed to be changed. The was relief when I finished but it was the only way I could think to get it done.
[Re: moparpollack]
#592109
01/24/10 01:55 AM
01/24/10 01:55 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
The proper stuff is glass setting tape. it comes in rolls and has sticky glue on both sides. fold it over the glass and insert into the vent frame..light tappin with a wood mallet to seat.. here is the OEM manufacturer. http://www.stanpro.com/rgstape.aspx
[Re: sthemi]
#592111
01/24/10 08:21 AM
01/24/10 08:21 AM
Posts: 1,945 Grand Rapids MI
N9671X2
Grand Rapids MI
I stopped at one of the local glass stores, that does commercial, custom showers etc... They gave me a couple feet of this product, FWIW.
[Re: N9671X2]
#592112
01/24/10 01:00 PM
01/24/10 01:00 PM
Posts: 442 NRH, TX
BeBeep
super street
super street
NRH, TX
Good info, thanks.
[Re: N9671X2]
#592113
01/24/10 02:47 PM
01/24/10 02:47 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
there are many different thicknesses so you might want to get a couple of different lengths of the different thickness materials at your local glass shop..
[Re: minivan]
#592114
01/24/10 03:40 PM
01/24/10 03:40 PM
Posts: 2,304 WI
RestoRick
WI
I have glass setting tape available. (not on my online store yet). I go on the thicker side; it's easily thinned out by stretching it length-wise. The trick is to get your glass fitting snug, then coat the tape on both sides with clean engine oil. Slide the glass into place and tape it to hold the trim in place overnight. By morning, the setting tape expands and the glass will be nice & tight. Finish by trimming the edges with a new razor blade. Works like a charm... Releasing glass with old tape is done by soaking with gasoline. Don't use urethane window sealer... makes it a nightmare to remove later and doesn't have the correct look, if that's a concern. Rick
[Re: RestoRick]
#592115
03/16/10 08:46 PM
03/16/10 08:46 PM
Posts: 442 NRH, TX
BeBeep
super street
super street
NRH, TX
Rick
I finally got to use the tape you sent me and it worked awesome. I can't thank you enough for this info.
Thank You, Bob
