Decoding an A12 fender tag
#592035
01/23/10 10:41 PM
01/23/10 10:41 PM
Posts: 450 DFW
68RRFlyer
DFW
Hey Gang, I'm looking at potentially buying a A12 car and was curious as to how to decode the fender tag. I understand how to decode the 69 tag's info with no problem, but it's the first two lines that I'm having a hard time deciphering. Not being an A12 expert, I'm noit sure where to lool. Any ideas? ![](/ubbthreads/images/graemlins/shruggy.gif) 23117 254721 9A255789 925 999 603 Thanks ![](/ubbthreads/images/graemlins/thumbs.gif) ! Cheers ![](/ubbthreads/images/graemlins/beer.gif)
Re: Decoding an A12 fender tag
[Re: 68RRFlyer]
#592037
01/24/10 02:43 AM
01/24/10 02:43 AM
Posts: 21,554 N.E. OHIO, USA
A12
N.E. OHIO, USA
Hey Gang,
Thanks !
Cheers
Here's a speed-decode for what you posted:
23117 = gates and stuff that even after reading the Lynch Road assembly story I still can't pinpoint what it all means. Only thing I know is the third number is always a "1" The next number is some kind of sequence or production number that is usually about a 1,000 numbers less than the VIN sequence give or take a couple hundred, again too confusing and no rhyme or reason for me The third set of numbers are a no brainer if you have a VIN tag....it's the VIN with the 9 = 1969, A = Assembly Plant Code for Lynch Road Assembly plant in Detroit, Michigan, the last are the sequence numbers 255789.
Now the next line would tell Body-In-White that this car is to start out with a 383-4bbl road runner or Super Bee engine with a heater firewall and a 4-speed will be bolted to it. The 999 means it gets a "special axle" and in this case a 4.10 Dana with big 11 inch brake backing plates bolted to it. The 603 confirms the 4-speed but this one is the Hemi 4-speed.
All A12's started out as 383 cars and then the A12 Package was added to the base car, the E63 was left on the fender tag and the A12 was added and the 26 for 26 inch radiator.......
There I've managed to get everything screwed up and wrong and totally muddied the water, hope this helps
MikeR
[Re: A12]
#592038
01/24/10 06:45 AM
01/24/10 06:45 AM
Posts: 450 DFW
68RRFlyer
DFW
Yup, that'll do it. I figured out the 23117 and the sequence number from the site Dave posted. Thanks for the second line info, that good stuff man! ![](/ubbthreads/images/graemlins/thumbs.gif) Just what I wanted to know. Cheers ![](/ubbthreads/images/graemlins/beer.gif) Dave
[Re: A12]
#592039
01/24/10 11:22 AM
01/24/10 11:22 AM
Posts: 1,183 eganville ont
440beep
eganville ont
Hey Gang,
Thanks !
Cheers
23117 = gates and stuff that even after reading the Lynch Road assembly story I still can't pinpoint what it all means. Only thing I know is the third number is always a "1" The next number is some kind of sequence or production number that is usually about a 1,000 numbers less than the VIN sequence give or take a couple hundred, again too confusing and no rhyme or reason for me The third set of numbers are a no brainer if you have a VIN tag....it the VIN with the 9 = 1969, A = Assembly Plant Code for Lynch Road Assembly plant in Detroit, Michigan, the last are the sequence numbers 255789.
MikeR
the m in the vin number they all come with 3 speed Wiper motors
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: 440beep]
#592040
01/24/10 10:01 PM
01/24/10 10:01 PM
Posts: 3,380 KY USA
mopargem
KY USA
Dont forget come over here and play, lots of good info! http://a12mopar.com/yabb/YaBB.pl
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#592041
01/24/10 10:55 PM
01/24/10 10:55 PM
Posts: 450 DFW
68RRFlyer
DFW
I've been trying to! ![](/ubbthreads/images/graemlins/bawling.gif) The site sends me an email and then I can't activate my registration. Sending the admin guy an email... ![](/ubbthreads/images/graemlins/confused.gif) I'm psyched, I want this car!!! Cheers ![](/ubbthreads/images/graemlins/beer.gif)
[Re: A12]
#592043
02/22/11 05:36 PM
02/22/11 05:36 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey Gang,
Thanks !
Cheers
MikeR
Would the "603" tranny designation on a A12 car really mean nothing more than the car was an original 23-spline 4-speed 383 road runner with a future transformation into a M-code car? I mean the original E63 code is still there. So, in essence, wouldn't the complete 383 drivetrain be removed and replaced with a 440-6bbl and a 18-spline A833? I thought in '69, "605" would have meant 18-spline HD A833.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#592044
02/22/11 06:25 PM
02/22/11 06:25 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Hey Gang,
Thanks !
Cheers
MikeR
Yes , 603 is the 23 spline code , 605 is the 18 spline trans code , since it has the 383 code it makes sense , to a degree , that it would also sport the 23 spline trans code .
[Re: 68RRFlyer]
#592045
02/22/11 07:54 PM
02/22/11 07:54 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
It's kinda goofy how they code the Dana (which isn't available with a 383) along with the 383 and 23 spline codes.......but that's what they did;
925 - 383 4bbl, manual transmission, heater, 335hp, orange
999 - 4.10 s/g, Dana 60, 11" rear and front drums (A12 pkg)
603 - 833 4spd. manual, 383 4bbl engine (23 spline)
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#592046
02/23/11 12:37 AM
02/23/11 12:37 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Appears to be a Super Bee hard top. Keep us posted! ![](/ubbthreads/images/graemlins/beer.gif)
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: A12]
#592047
02/23/11 01:39 AM
02/23/11 01:39 AM
69CoronetRT
Harlan, Iowa
FWIW, '69 LR sequence to VIN number differences can have a wider swing than 1,000. It depends on other factors. ![](/ubbthreads/images/graemlins/Twocents.gif)
Research continues.... ![](/ubbthreads/images/graemlins/scope.gif)
Seeking:
[Re: 69CoronetRT]
#592048
02/23/11 08:36 AM
02/23/11 08:36 AM
Posts: 450 DFW
68RRFlyer
DFW
That's some great info there. So basically, for whatever reason, they changed the stamping for the axle but not for the trans. Yet on A12 cars only, the 603 does means Hemi 4spd since that's the only thing they came with. It does and it doesn't, sorta. You'd think they would just of stamped the one number to a 5 and the tag would make sense since they restamped the rear anyway..sorta? ![](/ubbthreads/images/graemlins/shruggy.gif) I just bought an A12 clone Runner, and I know it actually has an 18 spline trans in there, since that's how he had it built and has the receipts and pics to prove it. It's a Lynch Road car too and is a factory 4spd car to boot. I was under the impression, since I've been on the hunt for a real A12 Bee project, that the 603 meant Hemi 4spd but didn't realize 605 was the code. Glad I kept this post as a reference. Nice to learn new things about stuff you thought you already know. Now I know, and knowing is half the battle! Great info guys, thanks! ![](/ubbthreads/images/graemlins/thumbs.gif) Cheers ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 68RRFlyer]
#592049
02/23/11 11:29 AM
02/23/11 11:29 AM
JohnRR
Cheers
no the 603 does not mean hemi 4 speed , and the 925 is the code for the 383 4 bbl with 4 speed trans .
The ONLY codes to tell you it's an A12 is the M in the engine code on the VIN and the A12 on the fender tag , unless it one of the first few that were not coded with either ... ...
[Re: JohnRR]
#592050
02/23/11 11:56 AM
02/23/11 11:56 AM
hemi68charger
Houston, Tx
Cheers
The 999 for the differential code would help too.. For a 383 727/4-speed car, that could would typcially range from "589-595". If there was a A12 without the "999", a red flag would be raised. Not to say it couldn't happen.
[Re: hemi68charger]
#592054
02/23/11 05:27 PM
02/23/11 05:27 PM
JohnRR
The ONLY codes to tell you it's an A12 is the M in the engine code on the VIN and the A12 and the VON on the fender tag , unless it one of the first few that were not coded with either ... ...
How so? The only thing consistent on the VON between cars is the beginning "9"
The VON is how those without A12 or the M in the VIN are confirmed as A12 cars ...
I knew I was leaving out something , nice catch Doug
