Re: Adjstable pinion snubber ?
[Re: HealthServices]
#589746
01/22/10 02:24 AM
01/22/10 02:24 AM
Posts: 503 Sooner state
Slim Smitty
Sooner state
I spoke to Rick Ehrenberg about snubbers a while back.
This is what he said:
"You need some kind of windup control for sure with any pure leaf-spring rear suspension. The other option, other than the snubber, would be Cal-Tracs.
You also might get away without the snubber if you use quadrashocks (Just Suspension has the kit as 'Ground Pounder'). The old-fashioned "traction bars" also accomplish this, but they bind up the rear suspension making them a disaster for street driving.
With no windup control, it is possible to momentarily over-angle the U-joints, resulting in instant destruction -- not pretty if you're at WOT in the 60-foot!"
65 Coronet
[Re: Slim Smitty]
#589747
01/22/10 02:46 AM
01/22/10 02:46 AM
Yes, no doubt you need the one that the factory installed.
It's the useless adjustable "too tall" one we're talking about.
[Re: Slim Smitty]
#589748
01/22/10 02:51 AM
01/22/10 02:51 AM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
B U T .. there is ZERO wind-up with the proper equipment ......
.... and PROPER equipment are SS springs.
#589750
01/22/10 07:30 AM
01/22/10 07:30 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
With stock springs and the lowest setting you still have to cut the rubber down! I used a cut down upper bump stop on mine.
Thats the other reason I made mine.
