Re: My '68 Charger restoration
[Re: 67Charger]
#587437
01/19/10 11:11 AM
01/19/10 11:11 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Excavation has begun. Hood is trash, as is the RF fender. I removed them for better access to the engine and to begin assesment of the frame. The engine cranks and tries to fire, but more exhaust was coming out the valve cover than the pipes, so I've got a burnt piston or something equally bad. No bother, I just won't mess with it anymore and move on to the body for now. I've unbolted the K-frame and loosened the control arms, I just need to ditch the t-bars and trans crossmember and the K-frame assembly will get pulled. Hopefully tonight I'll get to do so. A rough life in the Mexican desert has led to massive amounts of silt in the frame and body work, holding moisture and causing rot. The car had a vinyl top that failed and caused rust all around the roof, so it will need replacement. Lower quarters, rear decklid, rear filler, sail panels, package tray, trunk floor, all shot. Ironically, the floors are perfect. I'm just moving my way back and excavating before I cut metal and blast, patch and replace. Here's the current status: Rust in the lower A-pillar Rust by the bumper mount
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#587438
01/20/10 03:31 AM
01/20/10 03:31 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Good luck on the journey... Follow along with Jakes tactics of just cutting away at it one piece at a time, steel is pretty easy to cut, weld and grind.. Just takes a buttload of determination to tackle projects like yours. Ill be checking in, get after it!!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#587439
01/20/10 03:51 AM
01/20/10 03:51 AM
67Charger
Erda, UT
Done for the night. It took over an hour to get the T-bar bolts backed out. My I-R 600 ft.lb. impact wouldn't touch them after about the first 5 turns. The nut had just enough tension off it at that point to allow it to absorb the impact and render it useless. I had to go after it with a 3' handle on the breaker bar. K-frame is unbolted, I just need to cut the exhaust off by the trans, pull the steering column back, disconnect the shift linkage, and drop the driveshaft then it's free to lift the body up and off. Maybe tomorrow.
[Re: jake71]
#587442
01/20/10 02:32 PM
01/20/10 02:32 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Now that's a project! Guess you can't look a gift Charger in the mouth though! Any thoughts on drive train, colors, options? It's fun to see how people's ideas change over the course of the project. Hope this isn't going to keep you from the MATS this year.
[Re: RodStRace]
#587443
01/21/10 10:28 PM
01/21/10 10:28 PM
67Charger
Erda, UT
I'm thinking red with a black top, stripe and interior. 470" lowdeck stroker, one of those 5 speed OD's from Passon, make a healthy cruiser out of it. I'd love to be able to drive it to Montana and back.
[Re: redzards]
#587446
01/22/10 04:48 AM
01/22/10 04:48 AM
67Charger
Erda, UT
Yup, I couldn't ask for a better wife! Today's progress: K-member assembly out. What a pain!
[Re: 1972CudaV21]
#587449
01/22/10 08:56 PM
01/22/10 08:56 PM
67Charger
Erda, UT
What's up with the hood?
Rust removal via torch. No, it wasn't me. Same as they did to the front of the lower quarters and a piece of the door. Ironically, the piece they DIDN'T cut was the latch. It's safely in that little tab in the middle.
[Re: 67Charger]
#587452
01/25/10 10:08 AM
01/25/10 10:08 AM
Posts: 90 Chandler, AZ
cirrusaero
Chandler, AZ
Holy Crap!!! I hope the previous owner Paid you to take it away. That is one major project. Kudos to you for taking it on.
I'm almost done with my 68 Charger and I have a ton of parts, Trim, grill, tail lights, 68 dated 440, Nice pearl white interior. Let me know if you need anything or just advice.
In Phoenix which isn't to far away.
68 Charger 605 Hemi, Keisler 5spd, Pro-touring 66 Coronet 2dr post 66 Satellite
