Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587242
01/20/10 12:16 AM
01/20/10 12:16 AM
sandwich IL
sublimehemi Offline OP
sandwich IL
i just bought a 5a,from that same guy who sold the 6al on ebay,it was his last one.auction#110483908534,he says he still has the mopar performance catalog saying the new 6a and 6al are direct plug in for chrome orange and gold box. there must be a bunch of these still lying around somewhere,i wonder if they made the 7al direct plug in too,he said he is printing out the page from the mp catalog.i am glad to hear its direct plug in.the question now is what to do with my ballast resister wires,hook a 4 pin ballast or connect together,the two tops and the two bottoms or leave empty???????i know that with a msd 6 series cd ignitions you dont need to run a ballast,what do i do?
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: does msd still make the 6al with the 5 pin connetor? [Re: prochargedhemi] #587243
01/20/10 01:15 AM
01/20/10 01:15 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
I remember seeing one of these units is a story that Richard e-berg put together back in the late 80s...as I recall, the plug is the same, but the wiring is NOT the same as a stock mopar ECU...
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587244
01/20/10 01:23 AM
01/20/10 01:23 AM
FYI I just connected both sides in parallel on a high miles 4 terminal ballast & ended up w 1.1 ohms
Re: does msd still make the 6al with the 5 pin connetor? [Re: RapidRobert] #587245
01/20/10 09:11 AM
01/20/10 09:11 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
wow 7c,that box has the same color and casing as the ramcharger setup,i bet its the same except the r-c had no autotronics sticker(i think)and instead had a mopar part.nr.and again,wow that square rev limiter is cool,i have a few of the cyliner shape ones,is the square type older /made before the cylinder shape models?if you want plug in, the 6c on the bag was 80$ yesterday,no bids.multiple discharge.4prong ballast.i wish i had a gold 7c.
Re: does msd still make the 6al with the 5 pin connetor? [Re: cuda-sweden] #587246
01/20/10 12:15 PM
01/20/10 12:15 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
wow, what a bunch of info... I forgott to check this thread latelly
Trying to get all the info and doubts on one same reply .
Ok we do have MSD 5C, MSD 6C and MSD 7C where:
5C like regular MP units so direct replacement ? does it call capacitive ? ( non multispark ? )
6C like the tipical MSD multispark
and 7C ? whats the diff ?
so we have also those MSD 6A and 6AL ( non limiter and limiter ) but are these modified or did they come with the 5 pins setup ?
and another doubt is... ballast still will need to be on the system or not ?
Do these units need still to be chassis grounded ?
Re: does msd still make the 6al with the 5 pin connetor? [Re: NachoRT74] #587247
01/20/10 12:23 PM
01/20/10 12:23 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Ok I noticed differenced between both MSD auctions 110477889585 and 110483908534
first one beside is a 6AL ( limiter option ) does have the 5pins conector on right side
the 6A unit ( non limiter ) has the conector at left side
Modified ? Originally offered ?
MP PN he provides on first auction is the actual the MP multispark black box
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587248
01/20/10 03:24 PM
01/20/10 03:24 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The following is from the Ramchargers 1980 catalog...
MSD-5C $49.95
MSD-6C $99.95
MSD-7C $169.95
All have Chrysler pentagon connector, and will take a 4 or 5 pin version. I actually got ahold of a MSD-6C off the internet last year still in the original box. I did make a shock base and installed it in my 70RR, works fine.
Just my $0.01..
Re: does msd still make the 6al with the 5 pin connetor? [Re: Sinitro] #587249
01/20/10 04:26 PM
01/20/10 04:26 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
MSD-5C $49.95
MSD-6C $99.95
MSD-7C $169.95
Just my $0.01..
so you say they all would work 5-6-7C with only 4pins connected and a 2prong ballast?
Re: does msd still make the 6al with the 5 pin connetor? [Re: cuda-sweden] #587250
01/20/10 04:35 PM
01/20/10 04:35 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
MSD-5C $49.95
MSD-6C $99.95
MSD-7C $169.95
Just my $0.01..
I am running a Blaster II coil, 0.25 Ohm ballast resistor (2 terminal) and the MSD-6C..
Note that I previously installed the OE Chrysler electronic distributor, OE harness and Orange box combo. When I got the MSD-6C, I took out the Orange box and installed the MSD.
Plug & play, in my 70RR..
Just my $0.01..
Re: does msd still make the 6al with the 5 pin connetor? [Re: cuda-sweden] #587251
01/20/10 04:42 PM
01/20/10 04:42 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
MSD-5C $49.95
MSD-6C $99.95
MSD-7C $169.95
Just my $0.01..
I ran my msd 6c without the ballast resistor.
Tony
70 AARCuda Vitamin C
Re: does msd still make the 6al with the 5 pin connetor? [Re: 70AARcuda] #587252
01/20/10 05:32 PM
01/20/10 05:32 PM
sandwich IL
sandwich IL
ok.....msd 5 series and Chrysler ignitions are inductive discharge.
msd 6 7 series are capacitive discharge i think this is true with the old 5c 6c 7c
if you google inductive ignition vs capacitive you will see the pros and cons of each system.go to this interesting article www.chevyhiperformance.com/...inductive...ignitions.../index.html
as far as for the for what i bought,it is msd 5300,which is the msd 5200 5 series high perf inductive.it was called the 5300 cause it was made for chryslers only with the plug.he had it listed as a 6a,he was wrong.i emailed the guy who bought the 6al,and offered him more than double what he paid,i want have and test both systems....now if we can find out they made a 7al with direct plug in that wood be cool,who has the mopar performance catalog from the early to mid 90's .....
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587253
01/20/10 05:44 PM
01/20/10 05:44 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
And for whomever is looking, there is an MSD 6C on ebay right now...
http://cgi.ebay.com/ebaymotors/MSD-6C-Mo...118237008r39106
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587254
01/20/10 07:46 PM
01/20/10 07:46 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The link was broken..
Here it is fixed..
http://www.chevyhiperformance.com/techarticles/45618_inductive_cd_ignitions_basics/index.html
Re: does msd still make the 6al with the 5 pin connetor? [Re: Sinitro] #587255
01/22/10 12:49 AM
01/22/10 12:49 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I have had a few "5" series ones... put onto a Sun scope the multiple sparks pon teh raster screen is a weird pattern... never knew they made these in a 6 or 7 series... I had my last one on my 83 D 250 pickup til it died.
so now I have a Jacobs to put on in its place.
Re: does msd still make the 6al with the 5 pin connetor [Re: volaredon] #587256
01/22/10 09:53 PM
01/22/10 09:53 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
I had an old 404BC box with a 5 pin connector and it ran great until one day it just quit.I called MSD and they said they don't rebuild them anymore
Gus
64 Plymouth Savoy
Dana 60
