Re: Upgrade to 17 or 18" wheels/tires...need help
[Re: Crocker]
#586803
01/19/10 12:30 PM
01/19/10 12:30 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
The problem with Coys (beside the fact they are made in china) is that they are a one piece wheel, so it will limit your backspacing options abit..)
I'm old school (steel wheels) so please please educate me. Can 2 piece wheels be altered to change the offset?
Yep, just cut them apart and reweld them. I have it done often. Steel wheels are cut up and widened or changed often too.
That said, the 1 piece wheels sold for the older cars usually do come in offsets made close to work (since so many people use them of course) but if you wanted to really squeeze in the max size or what not, measuring the car (both sides) and having the wheels made to suit can do that. (Or if the car is lowered and off the shelf offsets rub, 2 piece wheels can get moved a 1/2",etc to give you the room you need)
If you are just going to run a common size and not worried about the max that will fit that's another thing I suppose.
[Re: OzHemi]
#586804
01/19/10 12:41 PM
01/19/10 12:41 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
OZ helped me get some Boyd Codding Smoothie IIs custom built. They're 18 x 8 and 18 x 10. Tires are Nitto NT555 in 245/45-18 front and 295/45-18 rear. My wheels were made with an extra thick mounting pad to clear the big brakes. Cars with more common or stock brakes can get away with normal mounting pads. That would give the wheel a 1-1/2" deeper look. They're awesome in a deep dish. Look at the picture of the front wheel between the center hub and the rotor. You can see the seam where the extra material was added. The lug nuts are the tall chrome spline drives and don't even reach the outside of the wheel center. That will give you an idea of how much farther back the spokes would be. It would be killer on a muscle car. Another bonus is having the valve stem behind a spoke of the wheel. You don't see it from the outside. That makes for a much cleaner appearing wheel with more of a custom look. The stem is easy to reach even with the monster brakes in there. ![](http://image.popularhotrodding.com/f/9166398+w750+st0/0711phr_08_z+1965_plymouth_belvedere+front_left_view.jpg) ![](http://image.popularhotrodding.com/f/9166413+w750+st0/0711phr_11_z+1965_plymouth_belvedere+rear_right_view.jpg) ![](http://image.popularhotrodding.com/f/8898833+w750+st0/0711phr_15_z+1965_plymouth_belvedere+wheel.jpg) ![](http://image.popularhotrodding.com/f/8898902+w750+st0/0711phr_16_z+1965_plymouth_belvedere+wheel.jpg)
[Re: feets]
#586805
01/19/10 12:50 PM
01/19/10 12:50 PM
OzHemi
Garden Grove, CA
Speaking of Boyds....how about some old school ones ? I picked these up a little bit ago and had them polished, my wheel guy said these were the very first of the Boyd billet (not cast) series "big" wheels, they are 18" He guess they were from about '94 or 5 ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) (came out pretty good after the polishing)
[Re: feets]
#586806
01/19/10 12:52 PM
01/19/10 12:52 PM
OzHemi
Garden Grove, CA
My, what small brakes you have... ![](/ubbthreads/images/graemlins/tonguue.gif)
[Re: cogen80]
#586807
01/19/10 01:00 PM
01/19/10 01:00 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Btw its a 70 barracuda
goody has a nice combo on his car.
Thanks, ill post pics later of mine,. 255s up front, 295s in the rear. the rear tires are on 18s and are 28.5" tall
[Re: GoodysGotaCuda]
#586809
01/19/10 03:31 PM
01/19/10 03:31 PM
Posts: 444 Newfoundland
Crocker
Newfoundland
Goody: What rim sizes (ie width/ rear offsets ) are you using?
[Re: OzHemi]
#586810
01/19/10 07:44 PM
01/19/10 07:44 PM
Crocker
Newfoundland
Ozhemi/Cnxt et al: Well I'm commited to this thing now as I sold the 15x7 rallyes. I got a couple more questions: -Can I mount a 285-45-18 on a 18x9 wheel or do i need an 18x10 wheel? -any problem with a 275-45-18 on a 18x9 wheel? -The torq thrust wheels I'm looking at are advertised as not 'hubcentric". How do mount them concentric? - I got a dr diff brake setup with 11.7" rotors/wilwood calipers front and 10.7" cobra set up in the Back. I had no issues with the rallyes. Any problems with clearances with the bigger wheels and those type brakes? Appreciate the help Glenn C
[Re: Crocker]
#586812
01/19/10 07:57 PM
01/19/10 07:57 PM
OzHemi
Garden Grove, CA
Yep, a 9" wheel will be fine for either of those sizes. The larger size shows (for a Pirelli P Zero at least) as to suit a wheel width of 9" - 10.5", and the 275 will be great as well, I have used that size on 9's (and 10's) a bunch of times in the past. As mentioned, the non-hub centric wheels just center off the lug nuts, no problem there...all the 2 piece wheels we use at least are the same way and have no issues at all. I can't see a caliper issue either. Feets had the issue because of the very large body of the AMG caliper combined with the shape of the spoke he wanted in the Smoothie II. I have a flat spoked wheel going on my Torana for instance that where made from the begining to go on road race cars with large caliper so does not need the deeper mounting pad like Feet's. But with "normal" sized calipers it's not really an issue in most cases. (Here is mine on the rear...an 18 x 10) ![](http://i415.photobucket.com/albums/pp237/ozhemi/00616.jpg)
[Re: RTSE4ME]
#586814
01/19/10 09:14 PM
01/19/10 09:14 PM
Crocker
Newfoundland
Front 17x8 4.75" BS 245/45/17 Rear 17x9.5 5.25" BS 275/50/17 B-body dana w/ DrDiff offset hangers
I got springs in the stock location. Will I be able to use 18x9 wheels without moving the springs??? ![](/ubbthreads/images/graemlins/frown.gif)
[Re: Crocker]
#586817
01/19/10 11:52 PM
01/19/10 11:52 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yes, see my post. 295s on 18x9s with stock spring location on my ebody.
[Re: sogtx]
#586819
01/20/10 01:08 AM
01/20/10 01:08 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
How much of a stiffer/ bumpier ride do you get withe 17's ? Because of the shorter profile ?
I didn't notice much change with mine. I did manage to keep a tall tire still which certainly helps. I did notice it was more responsive and held up on its wheels better through the average corner versus the old 15s.
#586820
01/20/10 01:02 PM
01/20/10 01:02 PM
Crocker
Newfoundland
Goody: Any issues with front wheel well clearance when turning Lock to lock. My car sits a little lower than yours with the hemi rear leafs and the 1" t bars cranked down Glenn C
[Re: Crocker]
#586821
01/20/10 01:07 PM
01/20/10 01:07 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have my front bars cranked down at least an inch. Used to rub with my ol, taller tires.
#586822
01/20/10 01:57 PM
01/20/10 01:57 PM
Crocker
Newfoundland
Goody, I just calculated it out and realized there's insignificant difference in the 235-60-15 I have in the front now and the 245-45-17 you are using. The 4.75" rear offset keeps the c/l of the wheel in the same place and overall height is 25.6".... the 235-60-15s are 26", so the 17s are 3/8" wider and 3/8" shorter.... When all else fails do the math. Are you using the rear spacers for asthetics or to provide extra clearance on the inside? Sorry for all the questions, but i want to get this right Glenn C ![](/ubbthreads/images/graemlins/beer.gif)
