Re: under hood pics of orignal 68 GTX needed
[Re: A12]
#586446
01/24/10 03:10 AM
01/24/10 03:10 AM
Posts: 21,547 N.E. OHIO, USA
A12
N.E. OHIO, USA
The 3-digit number usually on the right/passenger's side valve cover are the last three digits of the engine part number. If it's a Lynch Road car and you have the fender tag for a '69 is shows that number as the first set of numbers on the second line from the top. It identifies the engine, transmission and heater or A/C which determines things like the firewall (A/C or heater firewall), the floor pan (4-speed or Auto, bucket seats, etc.) and who knows what else Body-In-White needs to know.
I've seen the 3-digit number on the front of the right valve cover too.
MikeR
Here's an example of a 1969 LYNCH ROAD FENDER TAG and engine part number again I have NOT seen a '68 fender tag with this number on it.
