70 B Body Pistol Grip Correct #`s #586025
01/17/10 09:49 PM
01/17/10 09:49 PM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
Does anyone know the correct # that is on the reverse lever for a 70 B Body pistol grip. I know it`s a special shifter box for 70 only,identified by the # on the reverse rod. Thanks
Re: 70 B Body Pistol Grip Correct #`s [Re: 6pktgo] #586026
01/18/10 07:14 PM
01/18/10 07:14 PM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
Anybody ??? There must be 70 B Body pistol grip 4 speed Guys or Gals ??
Re: 70 B Body Pistol Grip Correct #`s [Re: 6pktgo] #586027
01/18/10 07:54 PM
01/18/10 07:54 PM
Mass
charge70 Offline
charge70  Offline
Mass
The # on the reverse lever is 7174.This is off a non-console shifter,I would assume a console style is the same but I'm not sure. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 70 B Body Pistol Grip Correct #`s [Re: charge70] #586028
01/19/10 12:01 AM
01/19/10 12:01 AM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
Thank You John
Re: 70 B Body Pistol Grip Correct #`s [Re: 6pktgo] #586029
01/19/10 12:02 AM
01/19/10 12:02 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct, the 7174 Mechinism is the same for either console or non console applications.
