Re: 55 plymouth 230 cid L-head six question(update) [Re: Magnumguy] #584679
02/12/10 10:07 PM
02/12/10 10:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you have an air compressor, pump some air in thru the spark plug hole, a compression tester hose witht eh schrader valve pulled works good.
The find the hiss, if you are hooked up to #1 and hear the hiss in #2's plug hole that's probably the head gasket. If the radiator bubbles air, it could still be the head gasket or a crack.
Good luck
Don't be the exception.
Re: 55 plymouth 230 cid L-head six question(update) [Re: Supercuda] #584680
02/12/10 10:26 PM
02/12/10 10:26 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Yes, do a compression test or a leak-down test.
For more on flathead sixes, try the P-15 D24 website.
http://www.merc583.addr.com/mopar/index.html
