Re: Indy 360-2 head and intake work
[Re: Ian]
#583659
01/26/10 12:52 AM
01/26/10 12:52 AM
Posts: 1,784 PA
W5DART66
PA
there s nice work and many hrs on the intake ,what s the hp gain on the intake over std and what comp did ya end up with.
I would think intake should be 25~35hp over what it was. I did fix the taper in the intake runner cross section was bigger at end of the port than the middle of the port. (that did not work well) the CR for now will stay at 10.3to1 .... we will see how Andy's budget is doing after this work LOL.
[Re: emarine01]
#583660
01/26/10 12:56 AM
01/26/10 12:56 AM
Posts: 1,784 PA
W5DART66
PA
Nice work Where are ya gona install the cam @ ad where do ya expect the power band to be?
cam is in at 103* should pull to 7300~7500 (cam and heads will do that) Push rods may not be up-to that task short block may not like that much RPM... we will see
[Re: S/ST 3040]
#583664
01/26/10 01:35 PM
01/26/10 01:35 PM
Posts: 1,745 Maryland
340_Dart
Maryland
I hope you post the numbers, with and without the intake.
Me too!
[Re: W5DART66]
#583665
01/26/10 01:46 PM
01/26/10 01:46 PM
340_Dart
Maryland
The old factory 360 block is what worries me with the bottom end... I know the K1 crank and rods will take the RPM.
[Re: Ian]
#583674
01/30/10 03:54 PM
01/30/10 03:54 PM
Posts: 1,784 PA
W5DART66
PA
Brett did you flow yours with a intake on and off also and what cc intake did you end up with thanks
I did flow it with the intake but was just a velocity check on the intake I did not record the flow numbers. I think it was down 8~10 CFM with intake and carb on. The intake port was 215cc last year. I had not looked at the flow numbers from last years engine for a long time as you can see the short turn still needed work port was going into flow separation.(still good port just could be better)Andy's ports are not bad for the time I have in them. I got 337cfm out of 2.08 valve and much smaller port this takes much more time to develop. Hey Andy this is cylinder #7 upper bearing shell worst rod bearing in the engine. I think it should be OK just had some dirt go through it.
