Page 2 of 3 1 2 3
Re: Indy 360-2 head and intake work [Re: 340_Dart] #583655
01/24/10 10:05 PM
01/24/10 10:05 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
there s nice work and many hrs on the intake ,what s the hp gain on the intake over std and what comp did ya end up with.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Indy 360-2 head and intake work [Re: Ian] #583656
01/24/10 11:22 PM
01/24/10 11:22 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
nice work Brett !
Re: Indy 360-2 head and intake work [Re: BobsProFab] #583657
01/25/10 12:12 AM
01/25/10 12:12 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
Andy, you're in good hands with Brett.
It seems he's going in the same direction that we are with the cam for next year; about the same lift and 10* less duration on the intake side. Unfortunately I have a pretty severe disadvantage with that intake though LOL.
Re: Indy 360-2 head and intake work [Re: Kevins493] #583658
01/25/10 08:48 AM
01/25/10 08:48 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Nice work Where are ya gona install the cam @ ad where do ya expect the power band to be?
Re: Indy 360-2 head and intake work [Re: Ian] #583659
01/26/10 12:52 AM
01/26/10 12:52 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
I would think intake should be 25~35hp over what it was. I did fix the taper in the intake runner cross section was bigger at end of the port than the middle of the port. (that did not work well) the CR for now will stay at 10.3to1 .... we will see how Andy's budget is doing after this work LOL.
Re: Indy 360-2 head and intake work [Re: emarine01] #583660
01/26/10 12:56 AM
01/26/10 12:56 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
cam is in at 103* should pull to 7300~7500 (cam and heads will do that) Push rods may not be up-to that task short block may not like that much RPM... we will see
Re: Indy 360-2 head and intake work [Re: W5DART66] #583661
01/26/10 12:59 AM
01/26/10 12:59 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Had heads on my buddy's flow bench tonight(Dennis Wheet at AFD) he needs to email the numbers for me hope to post them soon.
Re: Indy 360-2 head and intake work [Re: W5DART66] #583662
01/26/10 05:14 AM
01/26/10 05:14 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
thanks Brett nice post, i lost 12 cfm with the intake on the heads ,it will be good to see what yours flows .
Re: Indy 360-2 head and intake work [Re: W5DART66] #583663
01/26/10 10:59 AM
01/26/10 10:59 AM
On the south side of Nowhere
S/ST 3040 Offline
Happy Birthday S/ST 3040  Offline
I hope you post the numbers, with and without the intake.
Re: Indy 360-2 head and intake work [Re: S/ST 3040] #583664
01/26/10 01:35 PM
01/26/10 01:35 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Me too!
Re: Indy 360-2 head and intake work [Re: W5DART66] #583665
01/26/10 01:46 PM
01/26/10 01:46 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
The old factory 360 block is what worries me with the bottom end... I know the K1 crank and rods will take the RPM.
Re: Indy 360-2 head and intake work [Re: 340_Dart] #583666
01/26/10 02:47 PM
01/26/10 02:47 PM
412 SB Duster Offline
With the intake opened up what carb are you going to run on it.
Re: Indy 360-2 head and intake work [Re: 412 SB Duster] #583667
01/26/10 06:06 PM
01/26/10 06:06 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I plan on running my 1050 dominator on this motor. I ran it on the motor before the changes but used an adapter plate
Re: Indy 360-2 head and intake work [Re: 340_Dart] #583668
01/26/10 11:37 PM
01/26/10 11:37 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
flow just valve job.
.100"_______79.7
.200"______141.2
.300"______198.3
.400"______251.7
.500"______291.2
.550"______301.3
.600"______309.7
.650"______315.9
.700"______319.4
.750"______317.4
Re: Indy 360-2 head and intake work [Re: W5DART66] #583669
01/26/10 11:46 PM
01/26/10 11:46 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
flow numbers with update port work work.
Lift CCFM
0.0500 52.7
0.1000 81.8
0.1500 111.8
0.2000 143.27
0.2500 174.1
0.3000 203.3
0.3500 231.9
0.4000 257.2
0.4500 280.5
0.5000 298.02
0.5500 309.56
0.6000 319.7
0.6500 324.47
0.7000 331.71
0.7500 332.89
Re: Indy 360-2 head and intake work [Re: W5DART66] #583670
01/26/10 11:54 PM
01/26/10 11:54 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
flow with intake on.
Lift CCFM
0.3000 199.2
0.3500 225.6
0.4000 246.6
0.4500 265.1
0.5000 280.5
0.5500 292.0
0.6000 300.1
0.6500 307.5
0.7000 312.3
0.7500 308.0
0.8000 304.6
Re: Indy 360-2 head and intake work [Re: W5DART66] #583671
01/27/10 12:32 AM
01/27/10 12:32 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Brett,
just out of curiosity, what did the contest motor heads flow?
Re: Indy 360-2 head and intake work [Re: 340_Dart] #583672
01/27/10 09:47 AM
01/27/10 09:47 AM
S/ST 3040 Offline
2010 EMC INDY 360-2
.................. IN .................................EX
.100"_______63.9____________________57.0
.200"______152.9___________________110.8
.300"______204.4___________________150.3
.400"______258.2___________________173.4
.500"______305.2___________________194.7
.550"______321.1___________________203.1
.600"______331.7___________________210.1
.650"______337.6___________________214.4
.700"______324.4___________________218.1
2.08" IN/1.60" EX
Flowed @ AFD
Re: Indy 360-2 head and intake work [Re: S/ST 3040] #583673
01/27/10 09:55 AM
01/27/10 09:55 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
Brett did you flow yours with a intake on and off also and what cc intake did you end up with thanks
Re: Indy 360-2 head and intake work [Re: Ian] #583674
01/30/10 03:54 PM
01/30/10 03:54 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
I did flow it with the intake but was just a velocity check on the intake I did not record the flow numbers. I think it was down 8~10 CFM with intake and carb on. The intake port was 215cc last year. I had not looked at the flow numbers from last years engine for a long time as you can see the short turn still needed work port was going into flow separation.(still good port just could be better)Andy's ports are not bad for the time I have in them. I got 337cfm out of 2.08 valve and much smaller port this takes much more time to develop.
Hey Andy this is cylinder #7 upper bearing shell worst rod bearing in the engine. I think it should be OK just had some dirt go through it.
Page 2 of 3 1 2 3
