Re: 4/10's Pro-Tree
[Re: Dave_S]
#583542
01/15/10 07:43 PM
01/15/10 07:43 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Racers This season I am hoping to move up a class at our local track. The class I raced in upto now used a .5 pro-tree. It took a whole season but I finally got the hang of it. The new class uses a .4 pro-tree. My question is do you think I can get my car to react fast enough? I have upgraded the engine to a 512 with a [Email]262@.050[/Email] solid roller. Same 5000 stall,4.10,t-brake, with Cal-tracs. Last season I could cut a pretty good light but was red quite a few times (.008-.010) Will the mods over the winter make up the difference?
It's 268 @ .050 Dave ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Re: 4/10's Pro-Tree
[Re: Dodgem]
#583543
01/15/10 07:45 PM
01/15/10 07:45 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Well if you are allowed to deep stage per the rules seems like the best way to go. If not limiting travel, shorter tires, higher launch rpm, more gear, more converter and practice practice practice.
Re: 4/10's Pro-Tree
[Re: Al_Alguire]
#583545
01/15/10 08:07 PM
01/15/10 08:07 PM
Posts: 1,288 Oregon
sg66mopar
I'm your Huckleberry
Good one DOC ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: 4/10's Pro-Tree
[Re: Dave_S]
#583546
01/15/10 08:18 PM
01/15/10 08:18 PM
Posts: 2,120 Byron, NY
W.I.N. Racing
Byron, NY
As already stated...small tire, High pressure, tie down the front suspension and leave against the converter (no two step)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 4/10's Pro-Tree
#583548
01/15/10 08:20 PM
01/15/10 08:20 PM
Posts: 1,288 Oregon
sg66mopar
Put the smallest front tire you can on the car...set the front tire pressure at 45#....and if you have limiters on the front suspension get rid of as much travel as possible...or tie it down if you don't have limiters..
If that's the route you go don't try to deep stage. The idea here is to LIFT the front tire out of the beam as fast as possible. If you roll in you have more tire sidewall to lift out of the beam.
If you tie down the front you still need to have a couple inches front end travel to get the thing moving up. Then you probably need a pretty good shock to keep the front from bottoming out and bouncing when it comes back down.
Re: 4/10's Pro-Tree
[Re: moparniac]
#583549
01/15/10 09:29 PM
01/15/10 09:29 PM
Quicktree
Tony the Troll
your trolling and your not going to like what you catch ![](/ubbthreads/images/graemlins/tsk.gif)
Re: 4/10's Pro-Tree
#583550
01/15/10 09:31 PM
01/15/10 09:31 PM
Quicktree
Good one DOC
![](/ubbthreads/images/graemlins/stirthepot.gif)
http://www.youtube.com/watch?v=g1Sn3zGG_aQ
i dont need any fancy electronics to win. ![](/ubbthreads/images/graemlins/thumbs.gif)
how many races have i won. thats a good one.
really have you won any? I am talking real bracket racing not NSS ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: 4/10's Pro-Tree
[Re: supercomp]
#583554
01/15/10 11:38 PM
01/15/10 11:38 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
I know it's gonna be tough but I will try anyway. If it turns out bad I can always slow it down and run in my old class.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
Re: 4/10's Pro-Tree
[Re: Blucuda413]
#583556
01/16/10 11:04 AM
01/16/10 11:04 AM
Quicktree
The new AHRA rules(draft) had the GAS (10.90) class running a .400 Pro tree. One of my comments to the rules was that for the grass roots racer that they are after many would not be competitive on a .4 tree. I hope they change it before finalizing the rules.
it makes a whole lot of cars unable to compete.
Re: 4/10's Pro-Tree
[Re: Al_Alguire]
#583559
01/16/10 01:01 PM
01/16/10 01:01 PM
Quicktree
IMO depends on the rest of the rules in the class. Weight, chassis type etc. IMO if it is a stock suspension class with a fairly heavy weight I dont see why it would be an issue, keep the playing field level IMO. Now if they allow cars like mine, meaning tube chassis cars, with boxes I dont think it is a step in the right direction at all.
![](/ubbthreads/images/graemlins/iagree.gif)
Re: 4/10's Pro-Tree
[Re: sg66mopar]
#583560
01/16/10 01:02 PM
01/16/10 01:02 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Somewhere between 400 rpm less than stall speed to just pull the chip out and go against the converter for your best leave on a .400 Pro Tree. My 400 is chipped to 6200, shift at 8200, I can red a .400 Tree if I really want to.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
