Page 2 of 3 1 2 3
Re: 4/10's Pro-Tree #583541
01/15/10 07:41 PM
01/15/10 07:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea Dave limiting front end travel will move the wheels quicker. The big motor will speed things up a bit and then more RPM at launch!
Re: 4/10's Pro-Tree [Re: Dave_S] #583542
01/15/10 07:43 PM
01/15/10 07:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Racers
This season I am hoping to move up a class at our local track. The class I raced in upto now used a .5 pro-tree. It took a whole season but I finally got the hang of it. The new class uses a .4 pro-tree. My question is do you think I can get my car to react fast enough? I have upgraded the engine to a 512 with a [Email]262@.050[/Email] solid roller. Same 5000 stall,4.10,t-brake, with Cal-tracs. Last season I could cut a pretty good light but was red quite a few times (.008-.010) Will the mods over the winter make up the difference?
It's 268 @ .050 Dave
Re: 4/10's Pro-Tree [Re: Dodgem] #583543
01/15/10 07:45 PM
01/15/10 07:45 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well if you are allowed to deep stage per the rules seems like the best way to go. If not limiting travel, shorter tires, higher launch rpm, more gear, more converter and practice practice practice.
Re: 4/10's Pro-Tree [Re: Al_Alguire] #583544
01/15/10 07:47 PM
01/15/10 07:47 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Tony the Troll
Mopar Performance
Re: 4/10's Pro-Tree [Re: Al_Alguire] #583545
01/15/10 08:07 PM
01/15/10 08:07 PM
sg66mopar Offline
sg66mopar  Offline
I'm your Huckleberry
Good one DOC
Re: 4/10's Pro-Tree [Re: Dave_S] #583546
01/15/10 08:18 PM
01/15/10 08:18 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
As already stated...small tire, High pressure, tie down the front suspension and leave against the converter (no two step)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 4/10's Pro-Tree [Re: sg66mopar] #583547
01/15/10 08:18 PM
01/15/10 08:18 PM
Good one DOC
http://www.youtube.com/watch?v=g1Sn3zGG_aQ
i dont need any fancy electronics to win.
how many races have i won. thats a good one.
Re: 4/10's Pro-Tree #583548
01/15/10 08:20 PM
01/15/10 08:20 PM
sg66mopar Offline
sg66mopar  Offline
Put the smallest front tire you can on the car...set the front tire pressure at 45#....and if you have limiters on the front suspension get rid of as much travel as possible...or tie it down if you don't have limiters..
If that's the route you go don't try to deep stage. The idea here is to LIFT the front tire out of the beam as fast as possible. If you roll in you have more tire sidewall to lift out of the beam.
If you tie down the front you still need to have a couple inches front end travel to get the thing moving up. Then you probably need a pretty good shock to keep the front from bottoming out and bouncing when it comes back down.
Re: 4/10's Pro-Tree [Re: moparniac] #583549
01/15/10 09:29 PM
01/15/10 09:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Tony the Troll
your trolling and your not going to like what you catch
Re: 4/10's Pro-Tree #583550
01/15/10 09:31 PM
01/15/10 09:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Good one DOC
really have you won any? I am talking real bracket racing not NSS
Re: 4/10's Pro-Tree [Re: Quicktree] #583551
01/15/10 10:52 PM
01/15/10 10:52 PM
Lehigh Acres, Florida
rickstershemi Offline
count me in, I'm them!
my money is on you and Al.
Can I play too
Rickster
Re: 4/10's Pro-Tree [Re: rickstershemi] #583552
01/15/10 11:13 PM
01/15/10 11:13 PM
Burlington, Ontario Canada
Dave_S Offline OP
Dave_S  Offline OP
Cool, thanks for the help. Your right Barry the cam isn't 262@.050 its 268....wasnt paying attention.
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: 4/10's Pro-Tree [Re: rickstershemi] #583553
01/15/10 11:24 PM
01/15/10 11:24 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I seriously wouldn't try with that car. You are going to be taking a KNIFE TO A M16 GUNFIGHT and that's a fact. I'm not trying to throw water on your parade, it's just a fact.
Re: 4/10's Pro-Tree [Re: supercomp] #583554
01/15/10 11:38 PM
01/15/10 11:38 PM
Dave_S Offline OP
Dave_S  Offline OP
I know it's gonna be tough but I will try anyway. If it turns out bad I can always slow it down and run in my old class.
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: 4/10's Pro-Tree [Re: Dave_S] #583555
01/16/10 10:34 AM
01/16/10 10:34 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
The new AHRA rules(draft) had the GAS (10.90) class running a .400 Pro tree. One of my comments to the rules was that for the grass roots racer that they are after many would not be competitive on a .4 tree. I hope they change it before finalizing the rules.
Re: 4/10's Pro-Tree [Re: Blucuda413] #583556
01/16/10 11:04 AM
01/16/10 11:04 AM
Q
Quicktree Offline
Quicktree  Offline
Q
it makes a whole lot of cars unable to compete.
Re: 4/10's Pro-Tree [Re: Quicktree] #583557
01/16/10 11:13 AM
01/16/10 11:13 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Its all about the pinion angle....
Mopar Performance
Re: 4/10's Pro-Tree [Re: Blucuda413] #583558
01/16/10 12:59 PM
01/16/10 12:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO depends on the rest of the rules in the class. Weight, chassis type etc. IMO if it is a stock suspension class with a fairly heavy weight I dont see why it would be an issue, keep the playing field level IMO. Now if they allow cars like mine, meaning tube chassis cars, with boxes I dont think it is a step in the right direction at all.
Re: 4/10's Pro-Tree [Re: Al_Alguire] #583559
01/16/10 01:01 PM
01/16/10 01:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: 4/10's Pro-Tree [Re: sg66mopar] #583560
01/16/10 01:02 PM
01/16/10 01:02 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Somewhere between 400 rpm less than stall speed to just pull the chip out and go against the converter for your best leave on a .400 Pro Tree. My 400 is chipped to 6200, shift at 8200, I can red a .400 Tree if I really want to.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Page 2 of 3 1 2 3
