Re: '53 Dodge on Gen II Dak frame??
[Re: KatFysh]
#582607
01/21/10 06:29 PM
01/21/10 06:29 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
Kinda a cross between rod and pro-street. Just one i have wanted to do for a while.
[Re: rattler]
#582608
01/21/10 07:25 PM
01/21/10 07:25 PM
rattler
Crofton, Ky.
I can't get any pictures to post? Randy. Thata okay, i got my daughter to help.
[Re: rattler]
#582609
01/21/10 08:46 PM
01/21/10 08:46 PM
rattler
Crofton, Ky.
I will post a couple of pics, but i have been taking pics along the way, so i have a lot.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#582610
01/22/10 09:34 AM
01/22/10 09:34 AM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
That looks like real nice.. Do you have any pics of what the truck was originally? Just to see the height ,etc? Got any of the engine mounted in place? What are you going to use as a bed floor,wood? I was kinda of concerned how the profile of the truck would be being lowered and not chopped. Yours doesn't look too bad. I think I may not have to chop mine, yet.. ![](/ubbthreads/images/graemlins/biggrin.gif) The pic of my Dak has it lowered 2" from stock up front with BelTech drop spindles. I also used CalTrac bars on the rear with a 1 7/8" drop block. I still have the blocks and the spindles but may go back to stock leafs. I'm thinking that it should work out okay stancewise. My rear tires are almost needing replaced from doing the burnouts in the box.. I was planning on going to the widest tire I could fit on the wheel I already have and go a little wider than the front also. Post up more pics.. This is going to help me quite a bit. Thanks for having been there doing that.. ![](/ubbthreads/images/graemlins/thumbs.gif) I never really noticed before, but that body line from the back of the cab around the front of the hood and back again, I really like how "crisp" that is. That IS really cool..Guess I should pay a little more attenetion to these things.. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: KatFysh]
#582611
01/22/10 09:53 AM
01/22/10 09:53 AM
rattler
Crofton, Ky.
Just about all the fab work is done now. I already have the motor-trans mounts built and in place. I wanted to chop, but i need the room. I started out with the dak column but had trouble getting in so i changed to a jeep tilt and that worked great. I was having trouble with seat placement until i found a set of grand cherokee full power buckets, they work great, also used a durango console.If there is any particular parts you want to see, just ask. Oh, this was also a long-bed and i shortened it to a short bed. I measured it against a stock 57 and i am 13" lower in the front. Randy
[Re: rattler]
#582612
01/22/10 09:56 AM
01/22/10 09:56 AM
rattler
Crofton, Ky.
Oh, and i had to shorten the inner fenders by 12" to make them work with the lowering.
[Re: rattler]
#582613
01/22/10 10:00 AM
01/22/10 10:00 AM
rattler
Crofton, Ky.
I can only seem to post one pic at a time.I used stock dodge big-block motor mounts and oil pan, that way i only had to build out to them and can use off the shelf isolaters.Randy
[Re: rattler]
#582615
01/22/10 11:08 AM
01/22/10 11:08 AM
KatFysh
Falconer, NY
Nice tranny tunnel work. ![](/ubbthreads/images/graemlins/thumbs.gif) What year steering column and seats are they? I didn't even consider a console. Didn't think there would be room. Looks good though. When you post pics try [img] [/img] and your pic link to fill the space between the ] & [... Then when you want to add another pic use a space after the [/img] I usually hit enter for the next pic.. Is that understandable?? ![](/ubbthreads/images/graemlins/biggrin.gif) What/where are you going to to do for brake master cylinder? Looks like it may be tight with the bb. This is another reason I was thinking sb. I may go with pb and ps..
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: rattler]
#582616
01/22/10 12:39 PM
01/22/10 12:39 PM
rattler
Crofton, Ky.
Tha column in the pic is the Dak, i changed to the jeep last week. I think the column came from a 92 cherokee( square body). I didn't want the boxey column. The seats came from a 98? grand cherokee. Junkyard finds, seats $54, column and leather wheel-$72, console-$30. I have since installed the master cylinder on the firewall and the pedal under the dash. I am not running power breakes because i am planning on a big cam, so - no vacumne.I also just finished rebuilding the driver door this week(lower 4" rusted bad).The dak had power rack and pinion, so that stays.
[Re: rattler]
#582617
01/22/10 01:37 PM
01/22/10 01:37 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
love your 57 project,,best vintage dodge truck style IMO,,, ide like to see pics of the cherookee buckts please,,and a total width deminsion on the bottom part where you sit,,im looking for some thing for my 40 dodge,,perferably out of a mopar,,thats not so wide i cant get some sort of center console,, thanks ,,cant wait to see more on your truck
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#582618
01/22/10 01:56 PM
01/22/10 01:56 PM
rattler
Crofton, Ky.
I"ll try to measure for you today. Randy
[Re: rattler]
#582619
01/22/10 03:35 PM
01/22/10 03:35 PM
KatFysh
Falconer, NY
My wife drives an '02 Grand Cheerokee. Thats why I was wondering what year. Her seats and steering is pretty comfortable. I could see those working in a '50's truck. Thanks for the tip.. ![](/ubbthreads/images/graemlins/thumbs.gif) I hear ya about the no vacuum. That is something that I'm seriously considering so that I can run the Dak master and booster. Once I get started on this, I see how things will fit. My Dak frame is a '94 so it too had a ps rack. I just need to get a new one. The manual that I installed is now sold. Just waiting on the payment.. What is that in the background of yer last pic? ![](/ubbthreads/images/graemlins/scope.gif) Here's mine.. ![](http://i242.photobucket.com/albums/ff249/KatFysh-4/The%20V%20dub%20bug/f1f5a720.jpg)
[Re: KatFysh]
#582622
01/23/10 09:00 AM
01/23/10 09:00 AM
rattler
Crofton, Ky.
Hey, you yankees ain't all bad. ![](/ubbthreads/images/graemlins/biggrin.gif) I have a friend over in Delaware that has my old 71 Cuda vert.
[Re: rattler]
#582624
01/26/10 03:15 AM
01/26/10 03:15 AM
fstfish66
levittown pa
i like the fact the switches are built in to the seats,,they look blue in the pic,,ide never think cloth in a cheerokee,,,
[Re: rattler]
#582625
01/26/10 03:18 AM
01/26/10 03:18 AM
fstfish66
levittown pa
kol thanks 21 wide,would work and give me 6 or 7 inches for some sort of console,,is that including all the side plastic molding and switch area?? thanks again
