Re: 70-74 Dodge Challenger Doors
[Re: PhillyRag]
#581461
01/14/10 08:44 PM
01/14/10 08:44 PM
Posts: 69 Pittsburgh, PA
Deuces-Wild
Pittsburgh, PA
Only differences that would matter if interchanging pertain to the door glass & certain glass items: upper stops, track bolt access hole locations, etc.
Big Ditto on the above. One difference is with the number of holes in the door glass. I know 70 & 71? has 11 and the other years have 9. but those xtra holes were not used for anything...
[Re: Deuces-Wild]
#581462
01/14/10 10:28 PM
01/14/10 10:28 PM
Posts: 3,379 KY USA
mopargem
KY USA
As I recall the 70 also has more lower door panel clips and the upper inner bracing is not as robust.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#581463
01/15/10 10:13 AM
01/15/10 10:13 AM
Posts: 4,165 Florida
cataclysm80
As far as I know, all the doors had the same # of door panel clip holes which would be 7 holes towards the bottom of the door. It's very possible that the 70 door panels used all of these holes, while the later door panels may have only used some of those holes, I'm not sure.
As far as the upper inner bracing not being as robust, I agree totally. On the 70 doors it is a single layer of sheetmetal, while the later doors use a double layer. No big deal as far as interchange goes, both would work.
The easiest way to spot a 70 door is by the oval holes the cat whiskars clips go into. The later doors use screws to hold the cat whiskars on. If you try to put a 70 door on a non 70 car, you'll need two sets of cat whiskars because the oval holes for the clips are right where the round screw holes should be, and you won't have anything to screw into. On my own car, I had a non 70 door on my 70 and used a dremel to make the screw holes oval so they would accept the 70 style clips so that I wouldn't have to buy two sets of cat whiskars.
I've heard that At some point, 73-74ish I think, the window regulators were changed from a plastic slider in the track, to some kind of roller bearing in the track, and that this new setup required a few more holes in the door for access to bolts for adjustments, etc. It seems there would be at least 3 different doors then. 70 only. 71-whenever the regulator change happened. After the regulator change.
I'll try to write more later. Still looking for those pics.
Tav
[Re: YYZ]
#581465
01/15/10 11:16 AM
01/15/10 11:16 AM
Posts: 283 N.E. England
Roppa440
super street
super street
N.E. England
The door mirrors are different so are the mounting holes differently spaced or the same?
2002 Chevrolet Corvette 5.7 LS1
2011 Alpha Romeo Giulietta Veloce 1.6 JTD
Because running a Mopar in the UK is getting TOO expensive!!
[Re: YYZ]
#581468
01/15/10 01:23 PM
01/15/10 01:23 PM
cataclysm80
Spacing for the mirror holes (Rivnuts) are the same for all years - only the base is longer from '71-up.
On B-bodies, they went to a 'wide stance' in '73-4, which is not correct for E-bodies (though the shape/size of the mirror is the same
Good to see you again YYZ!
Tav
[Re: YYZ]
#581469
01/15/10 01:34 PM
01/15/10 01:34 PM
cataclysm80
Hardware, latches and regulators will work in all, though as mentioned early regulators & glass are different.
I agree, that's what I had heard before, but I'd like to add that while it is possible to install the late regulators into an early door and vice versa, there is some added difficulty when putting the late regulators into an early door due to the lack of some of the access holes in the early doors. Of coarse, you could just drill the holes yourself if you can figure out where to put them, but it is also possible (though more difficult) to install them without drilling. That is just what I had heard from someone who had done it. I haven't tried myself.
Tav
[Re: cataclysm80]
#581470
01/15/10 03:00 PM
01/15/10 03:00 PM
cataclysm80
Found some pics, here we go...
First off, some info. This car is a 1970 Challenger with a scheduled production date of August 26, 1969. An early car, but well into regular production. The drivers door is original. The car was T boned on the passenger side sometime, and that passenger door was replaced with a non-1970 door. Due to other parts that were replaced at the same time, I'm guessing that the passenger door is off of a 71, but I'm not positive. I only know for sure that it's not from 1970.
Keep in mind that this is a comparison of a Drivers door to a Passenger door, so it's not exactly an apples to apples comparison. Still, as far as I know, the only real difference in mounting holes between the driver and passenger door is the provisions for the remote mirror cable on the drivers side. As far as I know, the sheetmetal on all drivers doors came with provisions for this remote mirror cable, even if the car came with a non-remote drivers mirror.
Ideally I plan on going to a mopar junkyard I know of and comparing only drivers doors. The drivers doors have the VIN decal showing build date, which will help me track differences. Until then, this is what I have so far.
That I can tell, the door skin did not change from 70-74.
The rivnut spacing is the same on 70 non remote oval mirrors, 70 remote short base mirrors, 71-74 non remote round mirrors, & 71-74 remote long base mirrors. Not all cars had passenger side mirrors, so if you're swapping a passenger door, you may need to fill or drill mirror holes as needed. I've looked into the subject of passenger side mirror location quite a bit, and near as I can tell, the passenger mirror location measurements are supposed to match the drivers side measurements, although a lot of people adding a mirror have just eyeballed it.
Although earlier Challenger exterior door handles are concave to match the body of the car, while later handles were flat to be universal with the barracuda models, the sheetmetal of the door itself remained concave in this area and did not change 70-74. For this reason, the earlier concave handles will fit best, even though they are not "correct" for a later car.
I think the stainless steel trim that goes on top of the door on some cars is held on with metal clips. A door with this trim would have holes for the metal clips. Adding or deleting this trim on a donor door for your car may take a little work, but could be done.
I haven't had a chance to investigate body side molding on many doors yet. Info is appreciated.
Tav
