Re: No Body Filller Fender Repair [Re: elitecustombody] #579140
01/11/10 01:24 AM
01/11/10 01:24 AM
MD
HEMI472 Offline
HEMI472  Offline
MD
did you check the 3 dark spots at the bottom??????????? i striped the paint and had spots like that on the bed side of my truck the metal felt strong but in 2 years they turned into holes.
Re: No Body Filller Fender Repair [Re: HEMI472] #579141
01/11/10 09:07 AM
01/11/10 09:07 AM
Southeastern MI.
Q
QuickSilver Offline OP
mopar addict
mopar addict
Q
Southeastern MI.
Thanks for the kind words guy's. Yes the three dark spots received a small coupon to make repairs. I leave no stone unturned when it comes to doing this type of work. It was really strange as those dark spots which are rust pits formed right at the end of the rocker molding holding junk in there. The repairs made like this will out last the car, that's why I do them in the first place. Besides paint costs are so crazy that I don't want any comebacks from blistering.
Re: No Body Filller Fender Repair [Re: moparmojo] #579142
01/11/10 09:50 AM
01/11/10 09:50 AM
Southeastern MI.
Q
mopar addict
mopar addict
Q
Southeastern MI.
To answer your questions concerning the hammer welding technique. First of all you are not going to do high end metal work using the mig welding process, well I shouldn't put it quite like that. Yes it the cats pajamas for certain aspects of the trade but the only thing I use mine for is floor pans where I need a lot of filler metal coming off as fast as possible so that I can make good time stitching up the seam. And yes I can do some pretty amazing things with my mig but I have many years of experience however the weld joint becomes unworkable because it it so hard. If you try working the panel afterward it will almost always crack out right where the edge of the weld meets the base metal. Now I do prefer my acetylene torch or my tig welder. That is where the small welds come from. I set the joints up pretty tight and just fuse them together. Then you can file them down instead of using coarse grinding discs. The welds using tig or gas are malleable so that you can work the panel afterward. Hammer welding is a very good way to control your distortion as you are welding up the joint. It is welding, stop and hammer the weld as it cools down and then welding some more. After lots of practice you will get the hang of it and figure out what to do. I guess the biggest thing with all of it is practice. Hopefully this will get you going.
And yes I am still making aluminum bumpers for everything Mopar! Thanks. JC.
Re: No Body Filller Fender Repair [Re: QuickSilver] #579143
01/11/10 12:16 PM
01/11/10 12:16 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
great work!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: No Body Filller Fender Repair [Re: DPelletier] #579144
01/11/10 10:07 PM
01/11/10 10:07 PM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
Nice stuff. I have some rust free road runner fenders that have the inner bracing and miscellaneous flanges cut off the headlight bucket are, being an ex race car. They need surgery and I have a good set of donor fenders for the pieces. I have yet to find the surgeon to do the work. Wish you were close to Mass......
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: No Body Filller Fender Repair [Re: Q5_Ed] #579145
01/11/10 10:23 PM
01/11/10 10:23 PM
Chicago
curbman68 Offline
curbman68  Offline
Chicago
Wow, that's fantastic work.
Re: No Body Filller Fender Repair [Re: curbman68] #579146
01/12/10 06:32 AM
01/12/10 06:32 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
I've had some metal unbent and cleaned up by Joey, pictures don't even come close to doing justice.
It's more art then it is labor.
I can't afford this. mark
Re: No Body Filller Fender Repair [Re: a12superbee] #579147
01/13/10 11:25 PM
01/13/10 11:25 PM
Detroit, Mi
michiganhotrod1 Offline
Detroit, Mi
Very nice work. Agree with you on the MIG weld, very tough to work.
What rod do you use with the Acetylene?
Mark
Re: No Body Filller Fender Repair [Re: michiganhotrod1] #579148
01/14/10 09:15 AM
01/14/10 09:15 AM
Southeastern MI.
Q
mopar addict
mopar addict
Q
Southeastern MI.
I forgot to post some of the backside showing 100% weld penetration with absolutely no grinding needed. And Mark I think that I use something like an ER70S-2 copper coated filler wire in a .030 dia. It is de oxidized rod and I have never used anything else. JC.
Re: No Body Filller Fender Repair [Re: QuickSilver] #579149
01/14/10 02:35 PM
01/14/10 02:35 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
holy smoke,beautyfull work,i want to learn more,those backside welds in the picture above,are those made with gas or with tig,no protecting gas on the backside?
Re: No Body Filller Fender Repair [Re: cuda-sweden] #579150
01/14/10 06:52 PM
01/14/10 06:52 PM
Southeastern MI.
Q
mopar addict
mopar addict
Q
Southeastern MI.
Thanks guy. Yes those are backside shots of the weld and they are tig welded even though the gas welds are identical. No I don't use anything on the backside, they just come out that way. I have heard of guys using backside gas but this works for me. Maybe some applications will require extra gas. I even gas weld my aluminum sheet as well instead of tig for the same reasons. Nice pliable weld joints. JC.
Re: No Body Filller Fender Repair [Re: QuickSilver] #579151
01/29/10 11:28 PM
01/29/10 11:28 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Hey QC thanks for the few welding tips can't wait to try them!!
