Page 3 of 3 1 2 3
Re: Pictures of Dakota drag trucks please. ALL years. [Re: 71yelladustr] #578808
08/28/14 03:35 PM
08/28/14 03:35 PM
Gainesville Fl
mphsmitch Offline
mphsmitch  Offline
Gainesville Fl
Another pic of my 90 Dakota taken at Gainesville Raceway
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
Re: Pictures of Dakota drag trucks please. ALL years. [Re: mphsmitch] #578809
08/28/14 08:13 PM
08/28/14 08:13 PM
monticello,ms
andy3965 Offline
andy3965  Offline
monticello,ms
89 Dakota, 422 W9 smallblock .
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Re: Pictures of Dakota drag trucks please. ALL years. [Re: 71yelladustr] #578810
08/28/14 09:37 PM
08/28/14 09:37 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
My 88 with 5.7 Hemi/727 installed. Gonna add a 93 front clip for better looks and more room. Hope to have it going this spring.
Can you keep us posted on this project?
I've thought about this swap for my 92
Is there a mount kit for this setup?
Re: Pictures of Dakota drag trucks please. ALL years. [Re: andy3965] #578811
08/28/14 10:02 PM
08/28/14 10:02 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Andy, I like your Dakota. Do you mind telling your ET and combo?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Pictures of Dakota drag trucks please. ALL years. [Re: DaKuda] #578812
08/28/14 10:03 PM
08/28/14 10:03 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
my last shelby, fm3 pink, running at lyons raceway park bill mccarty driving.
won pro and sportsman the same day.
http://youtu.be/HPOGhMRRFdo
Re: Pictures of Dakota drag trucks please. ALL years. [Re: D-50] #578813
08/28/14 11:20 PM
08/28/14 11:20 PM
monticello,ms
andy3965 Offline
andy3965  Offline
monticello,ms
Only went low 6.0's. Only made 12 passes on it. Was still working on the setup and the tune when we broke the motor. It kicked two lifter bores out of it. The block is currently in PA being repaired. Hope to get it back soon and back in the truck. The goal for the truck was to run 5.80's on motor and 5.50's with nitrous. We pretty much only race the 1/8 mile round here.
Re: Pictures of Dakota drag trucks please. ALL years. [Re: andy3965] #578814
08/28/14 11:30 PM
08/28/14 11:30 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Only 1/8 mile around here also. My goal is to run 6.0' also for the 6.00 heads up classes around here.
Re: Pictures of Dakota drag trucks please. ALL years. [Re: RV2] #578815
08/29/14 12:33 AM
08/29/14 12:33 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
RV2 there is a combination of parts you can buy for the install. Only problem is they are not available from the same vendor. The mounts and pedastals came from Schumacher. They are for installing a big block. Trans mount is also from Schumacher. The engine adapter plates came from Street and Performance. Same ones used to install a gen III Hemi in a B or E body. They work perfect together along with a Milodon oil pan made for the swap. The only issue now is headers. Passenger side is real tight. Truck manifolds fit fine if all else fails. Sorry to hijack. Keep on posting those good looking Dakotas!
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Pictures of Dakota drag trucks please. ALL years. [Re: KRYPTONITE] #578816
08/29/14 03:26 PM
08/29/14 03:26 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
The Dark blue Dakota in those pics use to be mine!! sold it before I got to finsh it and Now Im thinking about building another one
I really wanted to buy that truck from you Kriptonite, but at the time could swing it, I still would like to have it. Did it ever get completed?
Keefe
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: Pictures of Dakota drag trucks please. ALL years. [Re: mphsmitch] #578817
08/29/14 03:32 PM
08/29/14 03:32 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
Nice
Re: Pictures of Dakota drag trucks please. ALL years. [Re: hp340nos] #578818
08/29/14 03:34 PM
08/29/14 03:34 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
My 94
Re: Pictures of Dakota drag trucks please. ALL years. [Re: TheOtherDodge] #578819
08/29/14 03:35 PM
08/29/14 03:35 PM
Houston, Texas
Houston, Texas
And my 2000
Re: Pictures of Dakota drag trucks please. ALL years. [Re: TheOtherDodge] #578820
08/29/14 03:39 PM
08/29/14 03:39 PM
Houston, Texas
Houston, Texas
And both together!
Re: Pictures of Dakota drag trucks please. ALL years. [Re: TheOtherDodge] #3254729
08/30/24 10:28 AM
08/30/24 10:28 AM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
popcorn to the top drumhit
Re: Pictures of Dakota drag trucks please. ALL years. [Re: skep419] #3254745
08/30/24 11:32 AM
08/30/24 11:32 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ill play along. Here is mine. All steel except front end. Weighs to much but still has power windows smile BB glide and 9" ford. Bed is all carbon with carbon bed cover. Have not run it much but its been low 8's here in Vegas. Was built for super class racing. Has been 11.05 160 here but I am still working on it.
Re: Pictures of Dakota drag trucks please. ALL years. [Re: skep419] #3254864
08/31/24 05:16 AM
08/31/24 05:16 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Wow! 10 years later! eek
Page 3 of 3 1 2 3
