Re: How to tell if engine was broken in properly? [Re: aarcuda] #576635
01/16/10 02:17 PM
01/16/10 02:17 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Yes I am using the stock 70 pistons and the thing gaskets. These pistons come up out of the block slightly. Ive never degreed a cam so I am reading up on it. I have a 7 inch degree wheel and a dial indicator with magnetic base.
Re: How to tell if engine was broken in properly? [Re: derekeh] #576636
01/18/10 10:44 PM
01/18/10 10:44 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Do they make a different bolt to attach the degree wheel to the crank? Ive never used a degree wheel so its new to me.
Re: How to tell if engine was broken in properly? [Re: derekeh] #576637
01/19/10 08:51 AM
01/19/10 08:51 AM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
the harmonic crank bolt and washer has always worked for me.
Re: How to tell if engine was broken in properly? [Re: Lew] #576638
01/19/10 11:03 AM
01/19/10 11:03 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I just thought it would be difficult to keep the degree wheel in the same spot that way.
Re: How to tell if engine was broken in properly? [Re: derekeh] #576639
01/19/10 11:11 AM
01/19/10 11:11 AM
cinch it down tight and when you put your socket/breaker bar on the bolt head dont put it on all the way to where it (the socket) is contacting the wheel and make a radial magic marker mark on the wheel and the bolt like you do on a harmonic balancer to keep tabs on it not moving.
Re: How to tell if engine was broken in properly? [Re: derekeh] #576640
01/19/10 11:15 AM
01/19/10 11:15 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Comp Cams p/n 4799 is a neat device that mounts the wheel and allows you to turn the crank.
