Re: Racing Alternator Help
[Re: sg66mopar]
#576341
01/07/10 10:16 PM
01/07/10 10:16 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my mini neipn denso puts kicks on at 800 rpm so it is charging at an idle.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: jamesc]
#576343
01/07/10 10:27 PM
01/07/10 10:27 PM
#576344
01/07/10 10:29 PM
01/07/10 10:29 PM
i forgot to mention that i run a JONES mini alternator on my other 2 cars. i believe they are 65 amp alternators, really nice pieces.
#576345
01/07/10 10:44 PM
01/07/10 10:44 PM
Posts: 1,443 Maryland
Dads426
Maryland
We have a GM one-wire on ours and the only problem I had was low voltage output at idle with the small Moroso crank pulley. Put the stock pulley on and the voltage was much better. I think the aftermarket alts work much better at lower speed.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#576346
01/07/10 10:51 PM
01/07/10 10:51 PM
Posts: 5,875 communist bloc of new jersey
jamesc
in some case there may be a little truth to this but for the most part i don't think there's any real magic. imho the majority of these "racing" alternators are standard alternators of different designs/combinations that mostly have a hefty price tag. you can get a nice denso one that will do the job at just about any boneyard for a lot less money. pretty much all the small ones are denso's the ones i first used came off a kubota diesel. personally i'd be hard pressed to spend the money they're getting for the so called race one's.
[Re: CDoering]
#576349
01/08/10 12:38 AM
01/08/10 12:38 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
What are you running for batteries? Just curious, as I run two batt's and the alt. I still use a factory style 78 amp alt. I was finding that with it running, the alt was fine and starting int the pits no problem, BUT if I ran the fans in the lanes, and then tried to start it on a hot day, after some hot lapping, it was REALLY tough. With the two batt's, that has been eliminated. I guess where I'm going with this, is if you are running two batteries now, and plan on keeping it that way but just adding an alternator, then almost any alternator should meet your needs ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: sg66mopar]
#576350
01/08/10 12:42 AM
01/08/10 12:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a denso unit... pretty sure its a 75 amp and I use a external regulator(the high output reg from Mopar)... I've never charged the battery(single) in years ![](/ubbthreads/images/graemlins/wave.gif)
[Re: jamesc]
#576351
01/08/10 01:01 AM
01/08/10 01:01 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
lot of options for charging systems. most of the smaller ones are denso, a lot of people use the gm single wire as well. imho too many people run without a charging system and i can't figure out why especially when using electronic ignition which most are today. i mean how much is it really going to slow you down measured against the problems that running without one can/does cause. if you need more output at lower speed you can almost always spin them faster. most of them can survive fairly high drive speeds.
![](/ubbthreads/images/graemlins/iagree.gif)
Also The battery is most often over looked in a a race car. Its crazy not to run a alt in todays race cars. I have run around the pits trying to charge a battery for next round, hooking up, unhooking..Its just not worth it. Most guys think hey if it starts its ok to race. A drained battery will KILL CONSISTENCY!! Those high flow fuel pumps flow good with a constant voltage, but going down the track the battery draw is in overload trying to keep up with everything..That big fuel pump isnt flowing what it should when its only getting 11 volts or so. This is when engine output is at the highest point at the end of a run.
IMHO First a alt isnt there to "Fix" a drained battery. Its purpose is to supply and maintain a level of output, and to keep a good charged battery well Charged.. Although it will charge up a dead battery, honestly we should NOT be racing with a battery in this condition. But we do.. If your battery will not charge up and hold 12.2 volts it needs replaced period.. IMO A deep cycle battery has no purpose in a race car.
a 800-850 CCA battery should be plenty..Charge it up before every race and check the volatge before you leave...If its not 12.2...replace it. Most dont like the little alt cause they dont charge well at idle, there is ways to fix this, but really at idle is not what a race car is about. Even the little alt will help your ignition box and your fuel pump working properly. So IMo putting a alt back on your car is a smart choice. Go to the junk yard and look for late 80's 4 cylinder GM cars...Grand Am's, Cavaliers etc.. They have what you need and the local starter service guy can convert it to a one wire deal for probably under $50 which will include a rebuild and replacement of worn parts.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: AndyF]
#576354
01/08/10 02:20 PM
01/08/10 02:20 PM
Posts: 1,288 Oregon
sg66mopar
Andy, I'm running a tube chassis and motor plates. I think I'd need a pretty big hole in the front plate for that to work. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Any other suggestions. Also, has anybody actually checked their alternator for Amperage output at idle or just above? If I can't get one that honestly puts out around 35 or more at idle and maybe 50 down the return road I don't see the point. Just more weight on the nose. I've run two group 24 deep cycle batteries in the trunk forever and the car's always been consistent. My reason for even considering this is the "hot lap" scenario these days at division and national events. Oh yeah, same thing last two rounds at PIR on Wednesday nights with the 10 PM curfew.
[Re: TS3303]
#576356
01/08/10 02:52 PM
01/08/10 02:52 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Bob, thanks for the alternator info ![](/ubbthreads/images/graemlins/thumbs.gif)
Andy your stuff is always like jewelry! ![](/ubbthreads/images/graemlins/thumbs.gif)
sg66 since your in Oregon near Andy drop your car off and let him design all kinds of brackets for us motor plate guys.
Yea, one that mounts on the other side of the engine as well.... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: AndyF]
#576359
01/08/10 09:19 PM
01/08/10 09:19 PM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
I build motor plate kits for the 8162 alternator. I also make the billet pulley for the 8162 alternator.
everyone wants to put the alternator right next to the crank trigger pickup???? maybe I'm just paranoid but I'd rather have it on the passenger side up high. or I need to make a new bracket and move the pickup?
