Page 2 of 3 1 2 3
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: Hemi Allstate] #57650
05/03/08 05:31 PM
05/03/08 05:31 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I had quite a few, but the one in the pics is a Weiand three two barrel tunnel ram converted to dual 4s, with the insides ported and fogger nozzles drilled for but not used. LOL The top had dams installed too, much like the Direct Connection Engine Manual pages....
I ran an M1 intake on my Demon, I drove it in the middle of winter, the cold start drivability was truly awesome!
CrAzYMoPaRGuY
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: CrAzYMoPaRGuY] #57651
05/03/08 06:01 PM
05/03/08 06:01 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
those direct connect connection package suggestions were dead on.
tunnels are so pretty....
you are handling the gas crisis well if tunnel rams are on your mind. at this point i consider them full scale models.
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: mark7171] #57652
05/03/08 10:30 PM
05/03/08 10:30 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Blow it! boost is like full time NO2.
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: mark7171] #57653
05/03/08 10:33 PM
05/03/08 10:33 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I ran one on my 68rr 440.
It ran great and looked even better.
Infact I was so happy with it,I am running the setup again in my truck.
Re: Old School TUNNEL RAM on 440 .can you drive on stre [Re: bigdad] #57654
05/04/08 12:10 AM
05/04/08 12:10 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm about to dig back into the DeSoto and rebuild the motor / trans and get it running since no one wants to buy it
I was posible I would love to buy it and restore it on its original conditions.
but is not posible
Re: Old School TUNNEL RAM on 440 .can you drive on stre [Re: NachoRT74] #57655
05/04/08 12:06 PM
05/04/08 12:06 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I will keep everything under the hood , nothing poking out ..
Sounds like its not such a dumb idea ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Old School TUNNEL RAM on 440 .can you drive on stre [Re: bigdad] #57656
05/04/08 12:36 PM
05/04/08 12:36 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I managed to hide mine, but it wasn't easy........I made some custom air filters that only stick up 3/4 inch above the carb. I hacked off the choke parts, painted everything with Eastwood carb restore, and got a 3rd place trophy last Summer. And don't disown me, but it is all under the hood of my '71 Camaro.
Re: Old School TUNNEL RAM on 440 .can you drive on stre [Re: 4BBodies] #57657
05/04/08 12:37 PM
05/04/08 12:37 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
My Edelbrock..........
Re: Old School TUNNEL RAM on 440 .can you drive on stre [Re: bigdad] #57658
05/04/08 12:44 PM
05/04/08 12:44 PM
lottsa positive answers here. even a blind man can see that.
if that ws my car, i'd be lookin to put a t-ramed 392 hemi in it.
just a thought.
Re: Old School TUNNEL RAM on 440 .can you drive on stre #57659
05/04/08 01:20 PM
05/04/08 01:20 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
just a thought.
Early on I had a old Hemi, then I started pricing what it would cost to build one with enough power to push the tank ..
Decided to go with old reliable ..Wish someone would adopt it but doubt that will happen so, its time to stuff more money in it and drive it
Re: Old School TUNNEL RAM on 440 .can you drive on stre [Re: bigdad] #57660
05/04/08 01:47 PM
05/04/08 01:47 PM
how long ago did you start pricing out for the first gen hemi parts?
i went here and they seem to have tons..
not too much more then for our Big Blocks. worth checking out IMO,
assuming you still have the old hemi.
Re: Old School TUNNEL RAM on 440 .can you drive on stre #57661
05/04/08 02:11 PM
05/04/08 02:11 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Depending on what route I go ..
My 440 all fresh will be around $1500.00 or less
Last one I did cost $380.00 ..
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: CrAzYMoPaRGuY] #57662
05/27/09 12:29 PM
05/27/09 12:29 PM
the one in the pics is a Weiand three two barrel tunnel ram converted to dual 4s. The top had dams installed too, much like the Direct Connection Engine Manual pages....
CrazyMoparGuy
I know I'm resorecting an old post but can you give me some more info in the Weiand? I want to do the same thing with mine for my 63 Plymouth.
What carbs did you use?
BTW It looks sweet, up till now I have not seen one installed.
John
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: bigdad] #57663
05/27/09 12:40 PM
05/27/09 12:40 PM
AndyF Offline
AndyF  Offline
Do it! I'd recommend going with a pair of Edelbrock carbs rather than the Holley carbs but either can be made to work. The Eddy carbs are just a little cheaper and easier to dial in.
Re: Old School TUNNEL RAM on 440 .can you drive on street ? #57664
05/27/09 02:10 PM
05/27/09 02:10 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
CrazyMoparGuy
John
Your right this is an old post!!!!
Big dad, drop in a 318 with A/C, roll the windows
up and leave the hood shut. Now head down the freeway and enjoy the cruise!
John, do the same!
Snap your neck, mega G-force launch, is all I want!
Re: Old School TUNNEL RAM on 440 .can you drive on street ? #57665
05/28/09 01:02 AM
05/28/09 01:02 AM
Canada
Canada
CrazyMoparGuy
John
HEY!
I saw this! LOL
Are you talking my Weiand 3x2bbl intake turned into a 2x4bbl ? The best carbs I ran on my truck were two 450cfm Holley center floats, I think they might have been the "Economasters" series but I'm not 100% positive.
I drove the truck year round, tons of torque, perfect drivability, and those two 450s on my Demon would pass AirCare emissions tests with flying colors, no detuning whatsoever....
I've used Edelbrocks too, which were OK, but those 450 Holleys really worked well for me. My distributor was recurved using two of the stock distributor "light" springs. Total advance was 34-36. NO vacuum advance.
CrAzYMoPaRGuY
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: CrAzYMoPaRGuY] #57666
05/28/09 07:32 AM
05/28/09 07:32 AM
HEY!
I saw this! LOL
Yes I'm going to run one of those old Weiand intakes on my 63. I plan on running Holley carbs were those 450 mechanical or vacuum secondary?
Thanks for the info.
John
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: BDS871Cuda] #57667
05/28/09 07:36 AM
05/28/09 07:36 AM
John, do the same!
Man I love it when people stay on subject.
Cuda, thanks for the usefull info on this subject
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: bigdad] #57668
05/08/13 12:17 AM
05/08/13 12:17 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Here's a MEGA to find out about the Desoto
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: Skeptic] #57669
05/08/13 01:25 AM
05/08/13 01:25 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I'll throw in my and say that I did with no problems, basic stock 440 with bigger cam, 2 Holley 750 double pumpers, Ran good on the street but to much intake / carbs at the strip to get the most out of it with the engine I had.
Page 2 of 3 1 2 3
