Re: Eagle cast stroker crank---Quality
[Re: dr.mopar]
#575599
09/05/11 01:28 AM
09/05/11 01:28 AM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Dude... Are you an Eagle sales person? Every single post you have ever made on this forum is defending eagles crap, mabey in chevy land it is upgrades but not here. Every one else knows the cast cranks that they make and the SIR rods are total garbage and nothing else, they are worse than stock parts. You can look at the casting quality of those rods and see terrible grain flow issues, especially the SIR rods. The cast cranks have so much meat ground out of them on the overlap area on the front of the crank there is no way you can expect them to live under ANY power even a stockish power leval. There are plenty of guys running factory 40 year old cast 360 cranks over 500 hp with no crank issues. The SCAT crank on the other hand is way better than stock useing better cast iron than stock (eagle uses weaker material than stock)and plenty of meat on the over lap area. If it is just balance issues how come it effects a severly high number of eagle cranks VS any other crank includeing bone stock cranks?
[Re: HotRodDave]
#575600
09/05/11 05:45 AM
09/05/11 05:45 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Maybe because like me, he's never had a problem with them?
I do agree that the metallurgy is not the best from what I've seen..and mine did have to be index ground as well.
That said,....430 HP - 10000 miles a year...Internal balanced Cast Eagle..KB Forged slugs.....no issues.
Go figure.....
