Page 4 of 5 1 2 3 4 5
Re: any a-body turbo pictures? [Re: radar] #574384
01/08/10 09:04 PM
01/08/10 09:04 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
There are tons of blowthrough cars with lots of success. Carb's are by nature temperamental, but its no different in a boosted application, you just have to be willing to put the effort into tuning it.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: any a-body turbo pictures? [Re: joshking440] #574385
01/08/10 09:44 PM
01/08/10 09:44 PM
Edmonton alberta Canada
mr. 63plymouth Offline
Holy you seem like a firecrack,how fast is your car with a hairdryer for an engine?? Let me guess you probably spent nothing for the engine but put a 550.00 turbo and run 8's,with 600dollar headers!!!!!!Ha Ha Ha. If you want to go fast you have to spend money!!!
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574386
01/08/10 10:06 PM
01/08/10 10:06 PM
ky
headhunter Offline OP
ky
so i guess your saying that i cant run in the nines with a 76mm and 446 c.i without buying a good set of heads and such????
Re: any a-body turbo pictures? [Re: headhunter] #574387
01/08/10 10:21 PM
01/08/10 10:21 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
"lookin off the front porch at the backside of goodbye.."
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: any a-body turbo pictures? [Re: cheapstreetdustr] #574388
01/08/10 10:38 PM
01/08/10 10:38 PM
ky
ky
Re: any a-body turbo pictures? [Re: headhunter] #574389
01/08/10 11:24 PM
01/08/10 11:24 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
you can go nines no problem with that set up. a PT76 will support up to 1150hp no problem.... do you think you will have aluminum heads, or a set of steel?
Re: any a-body turbo pictures? [Re: joshking440] #574390
01/08/10 11:43 PM
01/08/10 11:43 PM
ky
ky
right now steel just putting together to see if i like a turbo setup if it shows promise then ill do a decent motor like another b-1 motor like i had before then agian may leave a cheap motor in it lol
Re: any a-body turbo pictures? [Re: headhunter] #574391
01/08/10 11:48 PM
01/08/10 11:48 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
get on yellowbullet and theturboforums.net and look for a deal on a precision 76mm or an 88mm you will find that there are deals to be had and dont let anything discourage you because it will be worth it in the end
Re: any a-body turbo pictures? [Re: joshking440] #574392
01/08/10 11:58 PM
01/08/10 11:58 PM
ky
ky
only thing i have worrys about is the tuneing curve
Re: any a-body turbo pictures? [Re: headhunter] #574393
01/09/10 12:12 AM
01/09/10 12:12 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
i know what you mean. I am taking mine to Scott at Koffel for that, but I think with a good afr meter, and your years of experience you wont have to much problem....
Re: any a-body turbo pictures? [Re: joshking440] #574394
01/09/10 01:52 AM
01/09/10 01:52 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574395
01/09/10 02:52 AM
01/09/10 02:52 AM
Renton Washington
Triple Threat Offline
Renton Washington
You dont have to spend as much as you did
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: any a-body turbo pictures? [Re: Triple Threat] #574396
01/09/10 11:02 AM
01/09/10 11:02 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
We cant kid ourselves, this stuff is expensive....turbos, blow thru carbs, headers, bov, wastegates, top notch fuel pumps and all the other little pieces. That being said, can you be as frugal as possible with the turbo motor and surpass the performance of an n/a motor no questions asked. But if we all wanted to go fast cheap, we wouldn't be driving mopars!!!!
Re: any a-body turbo pictures? [Re: joshking440] #574397
01/09/10 06:22 PM
01/09/10 06:22 PM
Odessa, Fl
blowndart Online content
blowndart  Online Content
Odessa, Fl
Re: any a-body turbo pictures? [Re: 68DARTTURBO] #574398
01/09/10 06:51 PM
01/09/10 06:51 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
It takes big RPM to get turbos to make boost and you are not going to do this with stock rods and pistons.
Tis to laugh at you sir, my 2.5 Reliant makes 28 psi with stock rods and pistons and cast crank before the lights even drop.
I go through the traps at 5500 rpm!
http://www.youtube.com/watch?v=RmuFhAv8-Ks
Give me a small block to turbo and you would need a telescope to make out my rear bumper
Re: any a-body turbo pictures? [Re: blowndart] #574399
01/09/10 07:26 PM
01/09/10 07:26 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
And a unbelievable amount of cheap excellent condition used performance parts especially for mustangs
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: any a-body turbo pictures? [Re: megajoltman] #574400
01/09/10 11:35 PM
01/09/10 11:35 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
Mr.63plymouth.....
Humm yea your 400plus cube motor in a 2500lbs car i hope would run nines.
My 4000lbs brick pickup with a stock block .30 over 8:1 360 with stock x-heads, junk .508 cam, home built headers, with a $500 75mm turbo on 93 Citgo pump with 3.23 gears on drag radials on 7-8psi has been 11.08@125 with a 2.20 60ft. i drove it there and drove it home at 80mph on the expressway and sounds like a stock 360...oh and has single exhaust...no high dollar stuff either...ebay wastegate, blowoff and a $100 walbro fuel pump....Oh and a carb a i built myself too...
So your comparing apples to oranges
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: any a-body turbo pictures? [Re: dodge turbo] #574401
01/10/10 12:02 AM
01/10/10 12:02 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Hell, I can run more mph in the 1/8th than most N/A run in the 1/4.....and I built it all myself....but I still have put a buttload of money into it...mostly parts though.
Re: any a-body turbo pictures? [Re: instigator] #574402
01/10/10 08:28 PM
01/10/10 08:28 PM
ky
ky
a few progress pictures
Re: any a-body turbo pictures? [Re: headhunter] #574403
01/10/10 08:30 PM
01/10/10 08:30 PM
ky
ky
