Re: any a-body turbo pictures?
[Re: radar]
#574384
01/08/10 09:04 PM
01/08/10 09:04 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
There are tons of blowthrough cars with lots of success. Carb's are by nature temperamental, but its no different in a boosted application, you just have to be willing to put the effort into tuning it.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: Triple Threat]
#574396
01/09/10 11:02 AM
01/09/10 11:02 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
We cant kid ourselves, this stuff is expensive....turbos, blow thru carbs, headers, bov, wastegates, top notch fuel pumps and all the other little pieces. That being said, can you be as frugal as possible with the turbo motor and surpass the performance of an n/a motor no questions asked. But if we all wanted to go fast cheap, we wouldn't be driving mopars!!!!
[Re: joshking440]
#574397
01/09/10 06:22 PM
01/09/10 06:22 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: 68DARTTURBO]
#574398
01/09/10 06:51 PM
01/09/10 06:51 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
It takes big RPM to get turbos to make boost and you are not going to do this with stock rods and pistons.
Tis to laugh at you sir, my 2.5 Reliant makes 28 psi with stock rods and pistons and cast crank before the lights even drop.
I go through the traps at 5500 rpm!
http://www.youtube.com/watch?v=RmuFhAv8-Ks
Give me a small block to turbo and you would need a telescope to make out my rear bumper ![](/ubbthreads/images/graemlins/devil.gif)
[Re: megajoltman]
#574400
01/09/10 11:35 PM
01/09/10 11:35 PM
Posts: 468 Dirty Dena, Maryland
dodge turbo
Mr.63plymouth..... Humm yea your 400plus cube motor in a 2500lbs car i hope would run nines. My 4000lbs brick pickup with a stock block .30 over 8:1 360 with stock x-heads, junk .508 cam, home built headers, with a $500 75mm turbo on 93 Citgo pump with 3.23 gears on drag radials on 7-8psi has been 11.08@125 with a 2.20 60ft. i drove it there and drove it home at 80mph on the expressway and sounds like a stock 360...oh and has single exhaust...no high dollar stuff either...ebay wastegate, blowoff and a $100 walbro fuel pump....Oh and a carb a i built myself too... So your comparing apples to oranges
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
[Re: headhunter]
#574403
01/10/10 08:30 PM
01/10/10 08:30 PM
Posts: 2,601 ky
headhunter
ky
