Re: head swap to B1 BS HP gain?
[Re: HardcoreB]
#574142
01/10/10 05:55 PM
01/10/10 05:55 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am far from an expert on blowers, but have some basic understanding of them, having messed with one a bit. If you put a head on that flows ten percent better, and show a large drop in boost, bring the boost back up to 12 lb and the differance should be roughly the same increase in total pressure brought back into the picture. 12 psi boost, plus atmospheric pressure would be 26.7 absolute psi. If you loose 2.67 psi on the head change, then increase the boost back to 12 psi, it might show a 100 hp increase. There are a lot of variables i don't know about on this type of blower, so take it as a WAG.
[Re: gregsdart]
#574143
01/10/10 06:01 PM
01/10/10 06:01 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
i agree.i am upgrading the heads to gain HP, reduce heat/restriction plus my 346 iron heads are at there limit for putting $$ into.
[Re: blownzoom440]
#574144
01/10/10 07:34 PM
01/10/10 07:34 PM
blownzoom440
ELYRIA,OH
its not just that increase in HP for me as i will be turning up the boost to about 1300HP now and then. about 16 psi i would guess.
[Re: Bill_T]
#574148
01/14/10 03:03 PM
01/14/10 03:03 PM
blownzoom440
ELYRIA,OH
interesting! thanks. mine will be made to flow as stated in the 330 range so it will be better than the 280 cfm i had from the iron heads. i am sure the new rockers have a better baring now from then.i will check.
