Re: identify what these an lines are for on B1 heads?
[Re: Diablo]
#570935
01/03/10 03:58 PM
01/03/10 03:58 PM
my engine is apart so i cant really get any more pics than what i have... ill look through my comp pics and see what else i have.
For a Dist my heads were machined so any stock width Chrysler dist would fit. From your pictures i can see yours has not had the machining. So don't really have a choice but to run an offset off or buy a front mount one.
The An fitting coming out of the oil inlet will go to your pressure line coming out of your dry sump. My engine has a plate that bolts on instead of just a an fitting. both do the same thing.
For my water pump set up. i have the "out" of the pump with a "Y" thats splits into two runs to the back of each head. Comes out the front back into a "Y" and down to my rad. The two little lines out the sides of the heads between the exhaust valves run into a T i just tapped into the water pump itself.
If you have a water block i'm not really sure if you can set it up with way. Maybe my advise would be to use a head gasket that will block the water to the block and just run it through the heads. I ve got a solid block and never have had a heat problem.
I'll see what pictures i have.
who's offset distributor should i get, thats the next piece i need?
#570936
01/03/10 04:04 PM
01/03/10 04:04 PM
Posts: 19,638 Las Vegas
Al_Alguire
Las Vegas
Well it was NRC, Which then became Predator which I think you can still get through Steve Gill on here or Indy who knows has purchased the Predator line.
[Re: Al_Alguire]
#570937
01/03/10 05:29 PM
01/03/10 05:29 PM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
Go through Steve direct. PM here "gillman34" or I can PM his number.
#570938
01/03/10 05:35 PM
01/03/10 05:35 PM
Posts: 6,001 Anoka County, MN
Leigh
Anoka County, MN
valley tray hole
Man, I wish I could tig like that.
[Re: Leigh]
#570939
01/04/10 12:25 AM
01/04/10 12:25 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
valley tray hole
You could, if you did it all day, every day, like the guy at Hogan's who welds those manifolds.
Monte
