Re: Dominator on the street, power valve or not
[Re: galen]
#570335
01/03/10 03:13 PM
01/03/10 03:13 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
As I understand it, the 8082 models are a good choice or as you stated, maybe a modified/conversion of what you have.
[Re: galen]
#570336
01/03/10 03:21 PM
01/03/10 03:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Which 2 circuit would you recmmend for the street. I can have mine modified but by the time I buy metering blocks and boosters to try and make the 3 circuit run right, it may just be time to change carbs
I've heard of guys running the 8082 on the street and it works just fine... just like Thumper
[Re: MIKES_DUSTER]
#570339
01/03/10 09:35 PM
01/03/10 09:35 PM
Posts: 1,200 UK
602heavy
UK
[Re: 602heavy]
#570340
01/03/10 09:54 PM
01/03/10 09:54 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Guys that can run 3 circuits on the street with no fouling issues is amazing.
No way these out the box 3 circuits can run clean @ tip in , as soon as the throttle blades are cracked open fuel will pour in below the boosters , i'm gonna bet anyone running a 3 circuit out the box with no modifications to temporary block the intermediate tube with a tooth pick or similar & then post back hoe that little ole mod made the world of difference.
You are absolutely correct. I spent a month dialing mine in. Once I did the plugs were a nice tan brown. It was the best carb I ever owned. I restricted the transfer slots but you could probably do the same with the intermediate circuit. I also opened up the PV chanels so I didn't need as much primary jet, but this the jetting and PV sizing will depend on a lot of things (intake, cam, engine size, etc.)
[Re: torkrules]
#570342
01/03/10 10:17 PM
01/03/10 10:17 PM
Posts: 1,200 UK
602heavy
UK
Transition slot position can vary from carb to carb , some will set the throttle blades to just uncover the trans slot , this causes issues if that particular carb has the trans slot set higher up the throttle bores , all this does is pull fuel through the intermediate tube @ idle due to the throttle blade angle , some guys will set the idle speed & if it does'nt pull main metering they assume there good to go , forgeting it's dumping fuel through the intermediate tube.
