Re: B-Body Suspension [Re: Dodgem] #569771
01/03/10 03:02 PM
01/03/10 03:02 PM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
If it wasn't dangerous it wouldn't be as fun. Due to gearing, mine tops out at 105ish. You gotta give up some more details about that car. 140 is getting quick!
At some point your going to have to seal up parts of the grill and work on aerodynamics. I doesn't matter what you do to the suspension if the front tires are off the ground.
-1967 Belvedere II 440/4speed
Re: B-Body Suspension [Re: MACDiesel] #569772
01/03/10 09:54 PM
01/03/10 09:54 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
AutoX, any chance you could post a picture of the RR with the camaro spoiler? If it is subtle, that might be what I do! Lee.
Re: B-Body Suspension [Re: autoxcuda] #569773
01/03/10 10:04 PM
01/03/10 10:04 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Ok guys all of you have indicated on what I need to do. I'm on it next week!!! I talked with a guy today that has 727 trannys with overdrive. Opinions on that? Sorry I'm off topic....
There's a guy in our club with a 69 ABS plastic spoiler from a 69 Camaro on his 69 Road Runner. Actually look pretty subtle and most people don't reconize it as a Camaro piece. It does't stick down nearly as much as the one topside posted, but it's off the shelf, not too expensive, and because it ABS plastic it will give if you get it caught on something.
They are real cheap, and do give some...but you have to watch them if you are winching the car up onto a roll-back tow truck with the winch cable.
(I had just installed it too..and was putting the car on the truck to run it over to the exhaust shop..)
On a Camaro at least..
Re: B-Body Suspension [Re: OzHemi] #569774
01/03/10 11:51 PM
01/03/10 11:51 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Here is a link to a company that sells spoilers. They might have something that will work for you.
http://spoilersbyrandy.com/dartdemon.aspx
Re: B-Body Suspension [Re: Lee446] #569775
01/04/10 03:53 AM
01/04/10 03:53 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I can't seem to find a good picture of it. It's sort of hidden under the bumper. Still searching pictures....
Re: B-Body Suspension [Re: autoxcuda] #569776
01/04/10 04:30 PM
01/04/10 04:30 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
wonder how that looks on the 70 Roadrunner?
Re: B-Body Suspension [Re: roy2345] #569777
01/04/10 06:25 PM
01/04/10 06:25 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I'd start with checking the front suspension and alignment.
Even with old shocks, that will not control compression and extension. The side to side you are complaining about is not common for a B body, worn suspension or not.
If you do decide on an upgrade, big spring rate and stiff shocks. Z rated tires and have fun!
Re: B-Body Suspension [Re: Magnum] #569778
01/05/10 07:39 PM
01/05/10 07:39 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I believe my problem are the shocks. Cause it just floats up and down a little too mmuch at high speed. I'm doing that and sway bars and an extra spring on the back and see where that gets me. front end has already been rebuilt xcept for new front shocks. Thanks for input guys. And any more is certainly welcomed. I fixed the speedo gear and i figured 160 wldve been 140. But I was doing more like 130 and not 140. But that's still getting down for me. lol
Re: B-Body Suspension [Re: roy2345] #569779
01/05/10 08:35 PM
01/05/10 08:35 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I dunno, Had a cuda long ago that was doing same kindof thing at 135 mph on a straight road. It was still gaining speed, and as soon as it started lifting up then settling down, then up again, it was time to lift. After slowing it back to about 85, which felt like 30, I was figuring the car was trying to get on top of air underneath it. Make sense? That was stock suspension, and I was glad to not have to turn the thing at that speed.
