Re: 440 Source kit update part 1
[Re: curt jr]
#569600
01/05/10 04:12 PM
01/05/10 04:12 PM
Posts: 35 Johnstown,PA
curt jr
Johnstown,PA
This is typical of all the other holes drilled in the rod journals that are drilled parallel.
1971 dodge challenger 500ci 9.70s
1969 superbee 383 4speed numbers matching original redline tires
1970 challenger round tube chassis project
#569602
01/05/10 05:58 PM
01/05/10 05:58 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Muscle Motors dont have their own kit, they use 440 SOURCE and put it in their own packaging
Wrong... Not true at all. I have a Muscle Motors crank, that I just installed in the new Hemi engine/block. It was looked at from flange to snout, checked in every way possible. It only needed final balanced and polished. Was it perfect? No, it was tolerable and withing specs according to my machinist, and was given a good bill of health. He knows, and expects it to live a nice life in a 800-900hp Hemi. I installed the crank and main caps one by one checking crankshaft end play. It was right were I wanted it to be .005, it never varied .001 from the first center thrust main cap to the last one installed. Fact is it was a bargain. The 440 Source crank I used two years ago was the same way fit and finish.
Only problem so far was with the American finished World Block, the mains were not acceptable and needed honed and bored to correct.
FYI The last Eagle crank I used had a bunch of taper and was way large on the big end spec, so it need turned on the rods to correct. Back then the Eagle Crank as about the only choice for a budget crank...It was $750-$800 for the crankshaft..Add the cost of needing turned, and final balanced I had over $1000 in the crank alone. That crank took more abuse than anyone could ever dish out to a engine, and kept right on working.
Some times these budget cranks, are a bargain, some times they are not..Its pretty much Hit or Miss with these.
![](http://i93.photobucket.com/albums/l45/The_Dakota_Kid/IM003229.jpg)
![](http://i93.photobucket.com/albums/l45/The_Dakota_Kid/IM003233.jpg)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: curt jr]
#569603
01/05/10 06:21 PM
01/05/10 06:21 PM
Quicktree
to much saki when those were drilled ![](/ubbthreads/images/graemlins/beer.gif)
[Re: VernMotor]
#569606
01/05/10 06:39 PM
01/05/10 06:39 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
So is that crank alright to use ?? I think that needs to go back where it came from ! That not good.I would think it will be weak right there ?
Our big concern is the strength at the main thrust journal compromised,that large bore of that hole removed a lot of the attaching material. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: cbarracuda]
#569608
01/05/10 08:23 PM
01/05/10 08:23 PM
Posts: 2,431 USA
SSAAHemiFan
USA
I'm far from a pro.... But I would be sending that crank back. Being drilled on a angle so close to the journal.. ![](/ubbthreads/images/graemlins/eeek.gif) I would be VERY afraid of any weakening in that area. Much respect BG.. ![](/ubbthreads/images/graemlins/bow.gif) . Great post, and thank you for taking the time to do this. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: SSAAHemiFan]
#569609
01/05/10 09:25 PM
01/05/10 09:25 PM
B G Racing
Eighty Four, PA
Much respect BG.. .
I got it from a guy that originally bought it.IT was a great deal,so I thought.As Monte and many other have stated you get what you pay for.How the Manufacture could ever ship a product in this condition is beyond me.That the supplier missed it is one thing,the guy who bought it is another,the guy that preped the block machine work and started to assemble is still another mystery and it wasn't till it came to BGR after repeated questions and a request for help did we start to completely evaluate the kit for everyone on Moparts did this all come to light.As we seen from many responces that the adverage guy would have assume that it was in race ready or usable condition,we know what "assume does"Thankfully it stopped the assumptions at "me" and no one got hurt and were made an "azz of".Thanks Curt Jr for tinkering in the shop,he was told to take the crank to the crankshop where more good money would have been wasted.Sorry for peeing in everyone cereal and sinking their battleships,but"if you want the truth,you better be able to handle the truth".My next series will be the rods and pistons lets hope we can do better ![](/ubbthreads/images/graemlins/bow.gif)
[Re: dartman366]
#569613
01/05/10 10:01 PM
01/05/10 10:01 PM
Posts: 16,934 NC
440Jim
NC
Was it purposly drilled at a angle to clear the drill past rear counter weight,and was it purposly stopped at the point it was as not to drill into the thrust face? kind'a hard to tell from the pic's
I think this needs more scrutiny before coming to a conclusion.
I am looking at my 440Source 4.250" crank (RB) and both the 5-6 and 7-8 rod journals have the lightening hole at an angle. This appears to be done to allow the drill bit/tooling to clear the crank flange. Mine doesn't appear to be at as much angle as BG's, but that could be a photo illusion or the angle the bar is held at (bar smaller than hole). It appears the 5-6 journal is drilled larger (0.79" dia) and not as deep as the others which are all the way through and about 0.71" dia. The larger bit/tooling for the 5-6 requires it to be at a slightly larger angle than 7-8 and the amount of metal removed may be the same. This does not apply to the front journals since there is no crank flange on the front (damper snout).
[Re: B G Racing]
#569614
01/05/10 10:06 PM
01/05/10 10:06 PM
Posts: 415 Peru
cbarracuda
Peru
Much respect BG.. .
Hey I like to waste money, how much for the crank?
[Re: 440Jim]
#569616
01/05/10 10:10 PM
01/05/10 10:10 PM
dartman366
Mt. Vernon, Ohio
best I can tell from the pic , the protractor appears to be at a 5* angle. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: cbarracuda]
#569617
01/05/10 10:12 PM
01/05/10 10:12 PM
Quicktree
Much respect BG.. .
sell it to the man Bob, he likes what he sees ![](/ubbthreads/images/graemlins/image_294343.gif)
