Re: 1973 Cuda Basin Blue Restoration
[Re: jstewart]
#568983
02/11/10 11:25 AM
02/11/10 11:25 AM
Posts: 4,046 Minnesota
72blubird
Minnesota
Freind of mine had a Basin Blue cuda like that minus the white vinyl top. That one was 3 speed on the floor very nice car. Yours will be very nice when done. I sympahize with the blue interior they are very hard to find and everyone I have ever seen has been chalky. The car looks very nice ![](/ubbthreads/images/graemlins/thumbs.gif)
What was I thinking....
[Re: denfireguy]
#568984
03/11/10 10:34 PM
03/11/10 10:34 PM
Posts: 1,822 Colorado
denfireguy
Colorado
In the paint booth. This car may never be this shiny ever again. Wow. I am beginning to remember why I bought this car.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#568985
03/11/10 10:36 PM
03/11/10 10:36 PM
denfireguy
Colorado
[Re: jake71]
#568987
03/14/10 06:08 PM
03/14/10 06:08 PM
denfireguy
Colorado
Thanks for your encouragement. It is a slow project dictated by funds or the lack thereof. The tail panel is now complete. Put organisol over the flat black the paint people put on. Have the lights in and wired. Bumper put on and restored bumper to body filler installed. The rough looking chrome piece on the quarter is going to be replaced. I want to do the entire three pieces at once. Craig
[Re: denfireguy]
#568988
03/14/10 06:13 PM
03/14/10 06:13 PM
denfireguy
Colorado
And the badge announcing it is a Cuda. Meanwhile, I am replacing the A904 with a lockup A904. It is apart on the bench now with a new TF2 shift kit, Alto Red Seals and Kolene steels going in. I am waiting for a bushing kit. Dumb me thought they would be in the master kit but they were not. Should have it together next weekend. Craig
[Re: burdar]
#568990
03/17/10 05:51 PM
03/17/10 05:51 PM
denfireguy
Colorado
It's looking really good.
Mike at BE&A sells the tail panel trim. His pieces are really nice and fairly inexpensive too.
It looks like you left your bumper fillers natural. Is that the way they came from the factory? I thought they may have been painted with textured argent. No?
Could be. I asked a local about that before I restored them. He said it was just gray vinyl like stuff with steel reinforcement. Mine were in pretty good shape with some rust stains from the inside of the bumper. I used SEM flex skim coat to cover the end pieces where they were scratched and covered everything with SEM gray vinyl dye. I thought it looked like argent as well. Craig
[Re: demon]
#568992
03/19/10 05:58 PM
03/19/10 05:58 PM
denfireguy
Colorado
Nice car! I too have a Basin Street Blue 73 Barracuda. Mine is a 318 904 with 8 3/4 diff. Blue interior. Few options. Same sort of condition as yours too. I plan to start the resto later this year. I bought goodmark fenders and plan to buy everything else from AMD. Have you found a source for the correct headliner? The 73-74 material is a ribbed material sort of like corduroy. I have not found this type anywhere yet. Nice job on your car.
I will post a close up of the headliner tonight. Craig
[Re: denfireguy]
#568993
03/20/10 12:44 AM
03/20/10 12:44 AM
denfireguy
Colorado
Here is a closeup of the headliner. This came from Legendary. Not sure how accurate it is but I like the looks of it. Craig
[Re: denfireguy]
#568998
05/08/10 10:48 PM
05/08/10 10:48 PM
denfireguy
Colorado
Progress to report. The rebuild on the transmission is done. Put in a low gear cluster into the transmission. Full transmission kit with Alto Red frictions and Kolene steels. This transmission was in great shape before I opened it up. The clutch frictions were near new. The rebuild kit came with 8 frictions and 8 steels. There was an extra friction in one of the packs so I had to buy another one. Also replaced the output bearing just because it was open. TF-2 shift kit was added as well as the modification to the lockup valve that addresses an issue with early lockup and shudder in a Chrysler service bulletin. None of the Mopar kits are available any more so I bought a TF-TQ shift kit that has the replacement spring to raise the lockup to 40MPH. 25 bucks for a spring and a drill to open a passage. Kind of frustrating to have it build but no motor yet to hook it up to to test. The old clutches:
[Re: denfireguy]
#568999
05/08/10 10:50 PM
05/08/10 10:50 PM
denfireguy
Colorado
