Re: '37 Plymouth pickup comes home.
[Re: dirt]
#56866
04/29/08 08:38 AM
04/29/08 08:38 AM
Posts: 2,648 GA
Boosted
GA
I have been wanting a truck like that for a long time.. One day I wil lhave it..
What I would do is to put it on a dakota frame, a Cummins 4bt with an Intercooler and a HX35 turbo, an injector upgrade and a 47rh behind it.
It would be incredible... One day... One day..
Great find on an awesome truck...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: Cheeto]
#56869
05/03/08 12:25 AM
05/03/08 12:25 AM
Posts: 168 Torrance, Ca
Fig
Torrance, Ca
http://earlyiron.com/index.php makes some glass parts for it. I have never purchased anything from them but I have talked to the guy a couple of times. He was helpful and didn't mind spending the time to figure out what was needed.
1937 Plymouth R/S Coupe 440/727
[Re: Fig]
#56870
05/26/08 05:09 AM
05/26/08 05:09 AM
Cheeto,
I'd still like to buy that old engine and transmission for my 37 pickup.
David
[Re: Cheeto]
#56873
07/30/08 05:11 PM
07/30/08 05:11 PM
Posts: 4,165 Florida
cataclysm80
I'd suggest a 400 cubic inch (should be able to find one cheap since the muscle car group isn't looking for them) with a long arm cross ram intake (don't hesitate to weld it up yourself if you can't find an original) so that you've got a 4 barrel carb hanging out over each front fender!! Leave the hood off so everyone can get a good look. (one less part you need to find) Now THAT would be eye popping!!! ![](/ubbthreads/images/graemlins/drool5.gif) Tav
[Re: beesting]
#56874
07/30/08 05:36 PM
07/30/08 05:36 PM
Great find! Good luck with your project ![](/ubbthreads/images/graemlins/beer.gif)
#56875
08/04/08 07:52 AM
08/04/08 07:52 AM
Posts: 1,519 AZ
Mike P
AZ
Those headlights look good, and would answer what I'm going to do for turn signals.
Almost any engine will fit and as said no hood means one less problem. This is my 37 Dodge, I'm planning on keeping the top of the hood, but sides are available is you need them and if they work (I suspect they are the same as the Plymouth).
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: AZ_A12_BEE]
#56879
01/19/09 10:47 PM
01/19/09 10:47 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
My seat is the rear seat from a 69 Plymouth wagon
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#56881
01/19/09 10:50 PM
01/19/09 10:50 PM
AZ_A12_BEE
Dreaming of the 808
all steel very little rust
37 Plymouth PU
[Re: AZ_A12_BEE]
#56884
01/19/09 10:54 PM
01/19/09 10:54 PM
AZ_A12_BEE
Dreaming of the 808
Other side, not bad for $3000.00
37 Plymouth PU
