Re: Just installed the new Unlawful frame conectors
[Re: Quicktree]
#568093
01/02/10 01:18 PM
01/02/10 01:18 PM
Posts: 325 Greenville, WI
Big B
Greenville, WI
I maybe wrong but bolted in I don't see it doing much(better than nothing I guess) except for looks. if it's not welded into the floor pan I bet it will still flex. but it does look good
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: RoadRnnr69]
#568095
01/03/10 06:56 PM
01/03/10 06:56 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Looks good. Our 71' 340 Roadrunner ran high 12's and would flex bad enough to pop the speakers out of the rear package tray, it had no cage in it, and at the time had no frame connectors. I prefer to have stuff like this welded in but it looks pretty stout with 3 big blots on each end.
[Re: DynoDave]
#568096
01/03/10 07:16 PM
01/03/10 07:16 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Deleted after seeing some more pics
[Re: RoadRnnr69]
#568097
01/03/10 08:19 PM
01/03/10 08:19 PM
Posts: 4,085 Indiana
W5Duster436
Indiana
Any kits for A-body vehicles? I didn't see these even listed on the website.
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: Leon441]
#568098
01/04/10 01:45 AM
01/04/10 01:45 AM
Posts: 4,675 Ortonville, MI
RoadRnnr69
Keyster
Keyster
Ortonville, MI
One important point to all of this that the system is bolted in. This can be done by most any car guy lying on his back under the car with really basic tools. Not everybody has a hoist.
I have looked at other set ups that interfere with the e-brake cables, the stock fuel lines and the brakes lines. My e-brake cables are off because of the system I had originally.
I used to have the Lakewood hoop. If any of you have ever used one you know it doesnt fit our cars. I had to cut, weld and drill it to fit. Then I had to find a spot to mount it without interfering with my seat and seat belt mounting. I ended up bolting it to the seat bolts.
My car is a street, strip and show car which is what most of the hobby is. That being said I didn't want to weld a bunch of tubes, bars and sheet metal frame ties to the car and the floor pan. Then I would have to repaint the entire bottom of the car. The square plates with four bolts near the rockers are the backing plates for the roll bar. There is a gusset that will go from the plate to the tube on each side tying this to the roll bar. That part is welded and this installation was all the bolted together stuff. I'll post some pictures when the gussets are on (I need to finish my snowmobile first for a trip in two weeks).
I am really impressed with all the technical knowledge the here members have!! I am sure there are a million ways to do this but short of building a dedicated race car this is good way to go for a street car. If I was going to build the perfect set up it would be a chassis car just for racing but you can't take the kids for ice cream in a chassis car!!!
Some day down the road if I want to I can unbolt all the safety and race stuff, put the air grabber hood back on, put the numbers engine back in, the steel wheels back on and the car is a restored RoadRunner not a cut up race car.
P.S. There is an E-Body and A-body set up as well, none of these are on the web site, Jack said he has been busy in the shop and not working on the web site.
[Re: RoadRnnr69]
#568099
01/04/10 02:09 AM
01/04/10 02:09 AM
Posts: 22,808 Bitopia
jcc
Bitopia
Lets face it, as long as you are happy, that is a lot more important then what the rest of us think ![](/ubbthreads/images/graemlins/thumbs.gif)
And Everyone has commented how nice it looks, another ![](/ubbthreads/images/graemlins/thumbs.gif)
I quoted the above because I and suspect everyone else has said the same thing at one point in time, but does it ever really happen? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: jcc]
#568100
01/04/10 11:32 AM
01/04/10 11:32 AM
Posts: 453 Holly, MI
JackGTX440
Holly, MI
The rear attachment point is at the spring hanger. It bolts on using the spring hanger nuts. One of the major functions of this setup is to strengthen the spring hanger attachment point on the chassis as well as serve as a stout sub-frame connector. All of the forces of the spring are sent through sheet metal that is at best, inadequate. Especially on a car that has some power and hooks. This is why HEMI cars have the spring hanger boxes. The factory found it necessary to strenghthen this area on a stock car, but most people never even realize this as an issue on a nice street strip car with good tires. A nice street strip car with today's technology tires puts way more abuse on the stock spring hanger mount than any stock HEMI car did when it was new. These sub-frame connectors transfer the energy across a lot more of the chassis of the car. Now, with this setup, the energy goes from the spring hanger mount, through the tube and all the way into the front sub-frame. This alone strengthens the car a great deal, especially on a hard launch. Jack Irons Jr. www.unlawfulracing.com
[Re: jcc]
#568103
01/04/10 08:07 PM
01/04/10 08:07 PM
JackGTX440
Holly, MI
I'm not by my pics (i'm on my iPhone) I'll post some tomorrow. Keith, do you have any right now? -Jack Irons Jr www.unlawfulracing.com
[Re: RoadRnnr69]
#568105
01/04/10 09:12 PM
01/04/10 09:12 PM
Leon441
Lynchburg, VA
Man what did I say about this kit????
Didn't notice the tubing used for the frame connector is bent. Also didn't realize the plate for your roll cage is not part of the connector.
Here is something to think about. A straight peice of alluminum tubing. You can walk around and push ceiling tiles out of position and even slide boxes off the top shelf with it. Now take it and put the slightest bend in the tubing. Go back and try to do the things you tried before. You can't the bend just get's worse.
Tubing is bent all the time in race cars. But, if you notice there is a supporting structure welded in to support that bend.
[Re: jcc]
#568108
01/04/10 09:58 PM
01/04/10 09:58 PM
Posts: 1,256 Salisbury North Carolina
8secDart
You guys put way to much tought into things!!!! This is not an 8sec car,nor is a most of the cars that will be using this.Will I run this setup probley not.But it looks like it will do just fine.Hell it's better than nothing.For years all I've run is 1 5/8s tubing for frame conecters,no problems in lots of cars and passes.
Post deleted by Defbob
[Re: RoadRnnr69]
#568109
01/04/10 10:12 PM
01/04/10 10:12 PM
[Re: Leon441]
#568110
01/04/10 10:25 PM
01/04/10 10:25 PM
JackGTX440
Holly, MI
Here is something else to think about... The forces being applied to that slight bend are now where near enough to bend a 1.625 .120 wall tube, but they are strong enough to bend the sheet metal spring hanger mount. Keep in mind that this aspect of the sub-frame connector also is working in conjunction with the spring hanger structure that is already there from the factory.
[Re: Leon441]
#568112
01/06/10 05:33 PM
01/06/10 05:33 PM
Posts: 439 Ortonville, MI
StyleElements
Ortonville, MI
Omg dude you totally called it ![](/ubbthreads/images/graemlins/eyes.gif)
Yes, let's look at your analogy. Pushing ceiling tiles out of position takes almost no effort. Your piece of aluminum tubing with a slight bend in it is going to need to be paper thin for it to bend oppose to moving a ceiling tile. Assuming you're not using a paper thin aluminum pipe, the pipe even with a large bend in it will be much stronger than the force it takes to move the ceiling tile. This is exactely why your anology doesn't work. A 1.625 .120 wall pipe with a slight bend in it is a lot stronger than the sheet metal it's bolted to. The 1.625 .120 pipe will be the last thing to fail.
