Which motor oil?
#567894
12/31/09 05:12 PM
12/31/09 05:12 PM
Posts: 532 Charlotte, NC
Kowal
Charlotte, NC
With all the articles lately on the declining zinc content in "off the shelf" motor oil, I had been thinking about what might be the best oil to use in a '69, stock, 440. Which brand? Synthetic or conventional? What about the new Joe Gibbs "Hot Rod" motor oil, comes in both a synthetic and conventional, with heavy zinc and other additives for flat tappet motors? Thoughts? http://www.joegibbsdriven.com/hotrod/index.html
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Which motor oil?
[Re: Suregrip391]
#567898
12/31/09 07:40 PM
12/31/09 07:40 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I use Brad Penn or Valvoline Racing oil. Of the two, Brad Penn has higher Zinc/Phosphates from my understanding.
I doubt you will find anything with more zinc than Brad Penn.Had this anlysis done a year ago.
[Re: hemi4speed]
#567899
12/31/09 08:13 PM
12/31/09 08:13 PM
Posts: 553 DE
Ply72rr
DE
This is what I use in My Mopars its coventional..High Zinc content..My Machinist told me if I use anything eles, No Warranty on engine builds 15-40 HD wieght http://www.cen-pe-co.com/
Who sells cen pe co oil ? I looked at the web site but didn't see any distributors listed.
[Re: Kowal]
#567901
12/31/09 08:16 PM
12/31/09 08:16 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Your normal oil brand + 1 bottle of STP oil treatment ought to be enough zinc to keep the cam alive.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Ply72rr]
#567902
12/31/09 08:23 PM
12/31/09 08:23 PM
Posts: 1,240 Fairfield Maine
hemi4speed
Fairfield Maine
Try your local Tractor Supplier.
[Re: Locomotion]
#567904
01/02/10 09:00 AM
01/02/10 09:00 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Food for thought: Four-Ball Wear Test (ASTM D-4172): * 132lbs surface tension pressure * 302 degrees Fahrenheit operating temperature * 1800 RPMs * 1 hour operating time * Wear scar expressed in millimeters Quote:
"The ASTM D-4172 4-Ball Wear Test is a good measure of an oil’s ability to minimize wear in case of metal-to-metal contact. The test consists of a steel ball that sits atop three identical balls that have been placed in a triangular pattern and restrained from moving. All four balls are immersed in the test oil, which is heated and maintained at a constant temperature. The upper ball is then rotated and forced onto the lower three balls with a load measured in kilogram-force (kgf). After a one-hour period of constant load, speed and temperature, the lower three balls are inspected at the point of contact. Any wear will appear as a single scar on each of the lower balls. The diameter of the scar is measured on each of the lower balls and the results are reported as the average of the three scars, expressed in millimeters. The lower the average scar diameter, the better the anti-wear properties of the oil." - Cited Here - link
