Re: DYI Guys "How To" Restore Your Idle Stop Solenoid
[Re: ScottSmith_Harms]
#567073
12/30/09 04:09 PM
12/30/09 04:09 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
This is the tricky part. The copper wire is welded to the silver washer at the lower end, and to the opposite end at the wire connection tab base. It’s important to NOT break these connections. The housing is crimped at the lower end to retain the washer which is what retains the inner workings from exiting the can when the plunger is activated. There are basically two ways to remove the housing crimps, either pry them away with a stout set of pliers/side cutters, or grind them away completely (I use a dremel with a dime sized abrasive disc and VERY carefully grind away the nubs working around the wire). You may discover other ways to deal with the crimps but these two methods work for me. Also, the severity of the crimping varied; some are very shallow making removal easy while others are severe making grinding an absolute necessity. Once the housing crimps are out of the way the inner workings may still be stuck inside, usually it’s the dielectric potting glue around the housing can opening where the copper wire exits or the wire tab comes out. Carefully pry around these areas with a small screw driver to release the housing from the internals. Now, the washer is just resting around the base of the inner workings, other than the tiny copper wire nothing is holding it in place. Be sure to retain its position while removing the inner workings as a complete unit so you don’t break the wire connection on the washer. Use the still slightly screwed in plunger to push the internals out from the opposite end like a push up popsicle. You may have to pry the crimped areas away from the edges of the washer to free it as you push, it takes a bit of delicate dexterity. Once the unit is free of the housing you can unscrew the plunger and set it aside. Take the internals and put the assembly in a safe place to protect the delicate connections.
#567077
12/30/09 04:16 PM
12/30/09 04:16 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Now, cleaning these parts is not difficult, I process them with carburetor parts I restore, the exact method is proprietary, however for this job DYI is easy. First use a good degreaser like Purple Stuff or Simple Green to get the grease and oil off, then a soak in a store bought corrosion remover like Ospho, or a home brewed mix of citric acid, vinegar, and salt (as described by another member matthewnokc) also does a good job. His recipe: 1/2 gallon of white vinegar- 1/3 cup of salt - and the entire contents of 1 of those yellow plastic squeeze lemon juice bottles.
Soak the steel housing and the brass plunger in the solution overnight for the best results, clean off residue with a clean shop rag, use a scotch bright or 000 steel wool if there are stubborn stains. The original plating will be removed if you use the home brew vingar/citric acid mix above so the housing will now be bare steel (my example was also stripped of the plating and is bare steel as shown here).
You can use damp baking soda and a cloth to polish the surfaces, the baking soda works especially well on the brass plunger as a polish and leaves an OE appearance rather than an overly polished high luster that polished brass can have. Use dry baking soda in a cloth to buff it up to a shine.
Once you are happy with the housing finish you can use it as is, give it a light clear coat with something like Eastwoods “Nylac”, or do what I do and send it out for a proper silver/zinc plating job.
The example here is not plated yet, I just assembled it for show and tell, I will be taking it back apart send it out for final plating.
#567086
01/02/12 01:18 PM
01/02/12 01:18 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
In case this gets put into the archives, here's an application guide chart:
Delco Remy Idle Stop Solenoid Guide
19691/2-1971 Mopar Applications
Stamping# DR1114421 Part# 3514520 Early (Carter AVS) Part# 3549318 Late (Carter AVS) 1970 440 Carburetor: 4737S, 4739S, 4741S, 4740S Hex head with cap, no integral bracket
Stamping# DR1114442 Part# 3514892 (Carter AVS) 1970 340 Carburetor: 4936S, 4937S Round head, no integral bracket
Stamping# DR1114442 or DR1114447 (Evidence of either number being factory original) Part# 3438303 (Carter AVS) 1970 440 4738S 1971 440 4968S Hex head with cap, no integral bracket
Stamping# DR1114441 Part# 3438777 (Holley) 1971 383 4667A, 4734A, 4668A, 4735A, 6191A, 6193A Hex head with cap, no integral bracket, but includes wiring harness
Stamping# DR1114429 Part# 2875975 (and Part# 3438333) (Holley, Carter AFB, Carter Thermoquad) 1970 440+6 4375A, 4734A, 4376A, 4144A 1970 340+6 4791A, 4792A 1970 426 4745S, 4746S 1971 426 4969S, 4970S 1971 340 4972S, 4973S Round head with integral bracket
Stamping# DR1114443 Part# 3438338 (Holley) 1971 440+6 4669A, 4670A Hex head with cap
Stamping# DR1114420 Part# 3412059 (Holley) 19691/2 440+6 Hex head with cap
*Some information on this list was contributed by Tony D’Agostino, Bill Rolik, and Frank Badelson
[Re: meepmeep70]
#567088
01/02/12 06:58 PM
01/02/12 06:58 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Thanks Scott!! Maybe it will make it to Tech Archives???
Chris from New Jersey
