Prestolite horn repair 101 #566967
12/30/09 01:42 PM
12/30/09 01:42 PM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Here's my step-by step "how to", not all the tough really.
1. Split the horn in half.
From the power side, take a drill bit that is larger then the swedge and drill until it is no longer holding the two halfs together. Drill all 6 and pull it apart. Make note of the orientation of the metal diaphragm and the back halve to the trumpet. While you have the drill out, take a number #29 drill bit and drill out the trumpet side and tap it for a #8-32 machine screw.
2. Look at the inside of the magnet and you’ll see two small contacts, that’s where all the problem is. Take a piece of sand paper folded in half, open the two contacts with a screw driver then slide the paper between them and take the screw driver out. Pull the sand paper, this will clean both contacts as you do that.
3. If the cardboard gasket that is on the trumpet is bad, cut a new on from any paper stock the thickness of, lets say, the cover of your Mopar Muscle magazine.
4. Your ready to test.
Reassemble the horn, I use 3 vise grips and make sure they’re tight.
5. Screw the horn assembly together and use a cutoff wheel to trim the threads flush then use the side of the wheel to grind off to a flat the other end of the screw.
I've done a half dozen horns so far and they all work.
Re: Prestolite horn repair 101 [Re: HEMICUDA] #566968
12/30/09 01:43 PM
12/30/09 01:43 PM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
#2
Re: Prestolite horn repair 101 [Re: HEMICUDA] #566969
12/30/09 01:43 PM
12/30/09 01:43 PM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
3#
Re: Prestolite horn repair 101 [Re: HEMICUDA] #566970
12/30/09 01:44 PM
12/30/09 01:44 PM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
#4
Re: Prestolite horn repair 101 [Re: HEMICUDA] #566971
12/30/09 03:50 PM
12/30/09 03:50 PM
Mike,
Will this work for Spartan horns also?
Re: Prestolite horn repair 101 [Re: HEMICUDA] #566972
12/30/09 03:59 PM
12/30/09 03:59 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
Great post, i have a nice set of correct ebody horns in my challenger that don't work. Do you ever need to replace anything inside?
Jeff
1970 Dodge Challenger T/A
Re: Prestolite horn repair 101 [Re: ] #566973
12/30/09 04:30 PM
12/30/09 04:30 PM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Mike,
Haven't had a Spartan horn apart yet, I'm sure they are as simple as the Prestolite.
Re: Prestolite horn repair 101 [Re: jeff968] #566974
12/30/09 04:32 PM
12/30/09 04:32 PM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Jeff
The only thing I had to make was the gasket. There is one thing I forgot, do not sand/glass bead the diapham because it's spring steel and the heat will ruin it. I used sand paper to clean most of the rust off.
Re: Prestolite horn repair 101 [Re: HEMICUDA] #3142377
05/03/23 07:32 PM
05/03/23 07:32 PM
Terreton
joncaudle Offline
joncaudle  Offline
Terreton
Dang it Did all the steps and mine still doesn't work shruggy
Any ideas on a next step?
Re: Prestolite horn repair 101 [Re: joncaudle] #3142454
05/04/23 08:33 AM
05/04/23 08:33 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Take a resistance reading across the horn. This will check the contact continuity and the coil integrity.
