Page 2 of 3 1 2 3
Re: 1 more time on a body rack and pinion !!!!!!! [Re: moparjimbo60] #565946
12/30/09 09:43 AM
12/30/09 09:43 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
No bumpsteer. Ackerman is off, but still driveable on the street. Some one said, there is a company that makes a front steer ball joint with ackerman corrected. I haven't found it yet....
Edit......
I noticed I didn't put the updated pic of the tie rod end. There is actually a 2" spacer in between the steering arm and heim now to remove bump steer....
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Post deleted by Defbob [Re: DemonDust] #565947
12/30/09 10:48 AM
12/30/09 10:48 AM
Re: 1 more time on a body rack and pinion !!!!!!! [Re: DemonDust] #565948
12/30/09 12:13 PM
12/30/09 12:13 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Re: 1 more time on a body rack and pinion !!!!!!! [Re: moparjimbo60] #565949
12/30/09 02:10 PM
12/30/09 02:10 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Here is another old pro stock set up.Front mount.Pinto rack ? and a Hardy coupler.
Leave the gun.......take the Cannoli's....Mike
Re: 1 more time on a body rack and pinion !!!!!!! [Re: mike s] #565950
12/30/09 02:11 PM
12/30/09 02:11 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
2
Re: 1 more time on a body rack and pinion !!!!!!! [Re: mike s] #565951
12/30/09 02:12 PM
12/30/09 02:12 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
3
Re: 1 more time on a body rack and pinion !!!!!!! #565952
12/30/09 05:59 PM
12/30/09 05:59 PM
Georgia
moparjimbo60 Offline OP
Georgia
hey hemi fred, so the secret to fixing the geometry is to use b- body ball joints on it. i guess you swap sides with them also ? would it be easier to use a motor plate and make a k member or just cut mine up to fit ? also heard someone say e-body balljoints fix the problem too ?
Re: 1 more time on a body rack and pinion !!!!!!! [Re: OzHemi] #565953
01/04/10 07:07 PM
01/04/10 07:07 PM
Australia
drag345 Offline
drag345  Offline
Australia
Stock K frame with the same setup...and yes, mine as his was RHD...
A buddy of mine with a '68 Charger R/T with a Hemi in it is running the same setup, but using a power rack.
Very common swap, been done in Oz for years using a Holden rack which gives no bump steer issues, etc.
What model Holden? & what coupler to the stearing column any info thanks.
drag345
Re: 1 more time on a body rack and pinion !!!!!!! [Re: drag345] #565954
01/04/10 08:24 PM
01/04/10 08:24 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
drag345
VK Tie rod ends and all are just right!
And used a stardard Holden steering coupler, shortened in the middle abit
You do have to swap the lower steering shaft in the steering column to Holden too, or the entire one if you machine a circlip groove in the top for the bearing.
Re: 1 more time on a body rack and pinion !!!!!!! [Re: OzHemi] #565955
01/05/10 10:10 AM
01/05/10 10:10 AM
Australia
drag345 Offline
drag345  Offline
Australia
Thanks for that just the info I have been looking for .
just have to see if it will fit with my home made 17/8" 4into1 extractors.
just one more? any idea how much weight the rack saves over the cast iron steering box?
Thanks drag345
Re: 1 more time on a body rack and pinion !!!!!!! [Re: moparjimbo60] #565956
01/05/10 11:35 AM
01/05/10 11:35 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
First, Happy New Year to all...
I'm not sure I can word my opinion without unintentionally offending you or anyone. FWIW I feel you are not comprehending the good advise given based on your last question to HemiFred. You cannot change from a rear to front steer by simply exchanging a few factory parts. Your proposing undoing proven critical steering engineering. What will you benefit? And at the cost of your and someone elses safety. IMO Bill Reilly and BondoBob (maybe others too) have adequately validated their front steer systems. Don't attempt it on your own on a budget (both money and fabricating resources) because you are not only putting yourself but others safety at risk...
Re: 1 more time on a body rack and pinion !!!!!!! [Re: drag345] #565957
01/05/10 12:20 PM
01/05/10 12:20 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Thanks drag345
I never weighed it all... I actually have the steering box and all the linkage out of my Charger still and a setup out of another VJ I wrecked too around...and have a couple Holden racks around
The racks are easy to get to, but the steering box and stuff is kind of buried
My K frame was from Paul Norris by the way
I just got the K frame from him, then a rack and steering joint plus column shaft and put it all together over here.
Here is the coupler mod I did (got a couple extra couplers, just incase )
Post deleted by Defbob [Re: moparjimbo60] #565958
01/05/10 02:15 PM
01/05/10 02:15 PM
Re: 1 more time on a body rack and pinion !!!!!!! #565959
01/05/10 02:30 PM
01/05/10 02:30 PM
mi
V
vcummins Offline
vcummins  Offline
V
mi
The answer is no. My front uses all factory parts other than the rack.my spindles are from an early disc brake I think by Kelsey . the lower arms do not fit on later spindles
Fred looks like the lower balljoint arm got A little hot at one time for the push toward the tire
Re: 1 more time on a body rack and pinion !!!!!!! [Re: moparjimbo60] #565960
01/05/10 04:07 PM
01/05/10 04:07 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
http://www.heidts.com/support_suspension_101.html
every thing needed to explain why and how it works and why some things don't
WAXER
Re: 1 more time on a body rack and pinion !!!!!!! [Re: QWK_ENUF] #565961
01/05/10 04:17 PM
01/05/10 04:17 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
the link i posted used to have a nice section that explained what ackerman angle was and why it was important.when ball joints are swapped side tot side on mopars this ackerman angle gets out of wack
WAXER
Re: 1 more time on a body rack and pinion !!!!!!! [Re: SB449VALIANT] #565962
01/05/10 05:24 PM
01/05/10 05:24 PM
Here
jcc Offline
jcc  Offline
Here
Wonder if that TR end makes the 11/16" TR crowd choke?
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: 1 more time on a body rack and pinion !!!!!!! [Re: QWK_ENUF] #565963
01/05/10 06:18 PM
01/05/10 06:18 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Here is my fix for the Ackerman issue caused by swapping the ball joints. I have cut the steering arm from the ball joint then made the new steering arm that bolts on using longer ball joint bolts. This arm moves the tie rod joint the same distance outside the ball joint as it was inside (stock rear steer).
Hard to describe in words. We'll see how it works about March?
Post deleted by Defbob [Re: QWK_ENUF] #565964
01/05/10 06:24 PM
01/05/10 06:24 PM
Re: 1 more time on a body rack and pinion !!!!!!! #565965
01/05/10 06:35 PM
01/05/10 06:35 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Swapping sides works as long as you correct the Ackeman geometry.The lower ball joint steering attachment needs to be heated and bent(usually straightened).If the correction is not made the car will track forward fine,but will spread the back and toe the front inward pulling down on the suspension when backing up.There are a lot of R&P front steering cars with this problem,rear positioned R&Ps will work fine.
Page 2 of 3 1 2 3
