Big Block A-Body Headers (what's avbl? PITAs?)
#56542
04/17/08 08:03 AM
04/17/08 08:03 AM
Posts: 292 dead center
CHRONiklyDEMONic
Demonized
Demonized
dead center
What's available these days for BB a-bodies? Are there any underchassis that aren't a headache? Maybe we can start a list, including Price, and your experiance/opinions? ![](/ubbthreads/images/graemlins/musik010.gif)
"After a Day filled with burning Rubber, you may find it time to re-tire."
Re: Big Block A-Body Headers (what's avbl? PITAs?)
[Re: T748]
#56546
04/17/08 05:45 PM
04/17/08 05:45 PM
CHRONiklyDEMONic
Demonized
Demonized
dead center
Does Tubular Automotive make BB A-body headers?
Their SB headers are killer.
[Re: CHRONiklyDEMONic]
#56547
04/17/08 08:34 PM
04/17/08 08:34 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Yes they do, from what I read online. If you call them and get info, please post it back here, I don't need headers now but it's nice to see what's out there..
[Re: Ari440]
#56554
04/17/08 09:36 PM
04/17/08 09:36 PM
Posts: 5,337 the house on the left.
cogen80
do u remember what the proparts semi's set you back? money wise
call BOB MAZZOLINI
they go for $500 plus shipping
i remember getting a few sets for under $400 years ago. lol.
#56556
05/01/08 09:55 PM
05/01/08 09:55 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
This winter I bought the ProParts 2" semi-fenderwell headers for my 69 Dart with a low deck and 440-1 heads. When I bolted on all 8 tubes I was thrilled with how they fit and didn't hit anything. But then I went to put the collectors on and things got ugly. The drivers side hung close to the ground on a bad angle and the passenger side ran right into the tranny k-member frame. ![](/ubbthreads/images/graemlins/crazy.gif) And when I turned the steering wheel I realized one of the tubes(#1) was hitting the steering drag link bar very hard. ![](/ubbthreads/images/graemlins/rant.gif) So I had to ding the #1 tube pretty hard, cut the drivers side collector and give it a different angle, same with the passenger collector and shortened it to get it away from the tranny k-member. But once I was done with the chop saw and the welding for about 3 weeks my body was wore out but they fit pretty nice now, although the collectors are not fun to try and slide over 4 pipes that are all fighting against each other. It took some work but I'm happy with the headers now, just need to get the car running again so I can drive it to settle the front suspension and make sure they're not too close to the ground, especially the drivers side. Wish I could post pics but our main computer that was setup for all that crashed.
[Re: ProSport]
#56557
05/01/08 10:01 PM
05/01/08 10:01 PM
Posts: 5,620 long island NY
Ari440
long island NY
next time
leave the pipes loose on the heads that way you can slip the collecters on easy and will not figth you
I dinged number 1 pipe too
the heigth of the moter makes a diffrence
1.39 9.85 - 137 mph
[Re: Ari440]
#56558
05/01/08 10:47 PM
05/01/08 10:47 PM
ProSport
Akron, Ohio
I did leave the pipes loose on the heads, still no fun. ![](/ubbthreads/images/graemlins/tsk.gif) I got them for $500 shipped from Mazzolini so they're not expensive and they will be pretty easy to work with now. I personally do not recommend cutting off the 3-bolt exhaust flanges, I rotated mine and rewelded them so they don't face the ground but I used to collector reducers that come with the headers to make tools to remove/install the collectors. We welded steel plate to the end of them with a nut in the center, that way I can bolt them to my collectors to tap them on w/o hurting the flange on the collectos and I can attach a small slide hammer to the nut to remove the collectors when necessary. I CANNOT imagine getting these collectors off w/o the 3-bolt flanges. I also added a couple more L shaped tabs to bolt the collectors to the pipes. The number 8 pipe barely slides in far enough.
