When I first built my Dart 15 years ago I did not want cut the car. So this really limited my options especially back then.
I purchased a set of then first issue CPPA headers with 2" primaries down to a 3 1/2" collector.
The clearance issues were ridiculous. I had to finesse the #7 and #8 tube for plug wire clearance.I had to basically crush one tube for Pitman arm clearance and YES it does capture the starter.
I had them in the car for over 12 years. 3 years ago when I built the new motor for the car I looked at other options. Now again not wanting to cut the car really limited my options, BUT atleast there are other options out there now.
I was going to go with Schumacher try-Y header which I think are 1 5/8" primary that step up to 1 3/4" to a 2 1/2" ball type exhaust flange.
Was real tempted with these when saw them in a friends Duster, The fit was awesome BUT was leary of the size of the tubes.
I ended up coming across a Set of New TTI underchassis headers from a failed project for $150. I went with these as my exhaust at the time was built for the CPPA's. Now these are basically the old CPPA header with the clearance issues "supposedly" have been corrected....
What I found was, plug clearance was better but still not optimal and I massaged a few to make it a little better.
I still had to dimple the tube for the pitman arm clearance AND ground down the tip of the stud to the very top of the hole for the cotter pin. One thing I did not have to due that much banging on TTI as I had to do on the CPPA's for the pitman arm clearance.
Having an RB surely helped. I would assume with a low deck that the clearance surely would of been much worse.
Still encases the starter and Manual steering is a must.
Plug changes are still time consuming BUT I have made or modified different sockets and wrenches over the years to make the job easier. I can change 1,3,5,7 in about 10 minutes, 2,4,8 in about another 10 minutes, all from up top. #6 WHOA
what a PITA!!! I have to change this one from underneath with socket,wrench on the end of it getting little turns as open space is extremely limited and VERY tight as takes about 10-15 minutes on its own.
I guess it would be easier IF I was to make an access hole in the fenderwell but I deal with it. Plug wires need periodic replacement and should be checked regularly depending upon amount of use for burns.
Plugs #7,6 & 8 are close to the tube. On these inbween the tube and boot I use some header wrap as a buffer.
Now with installation of the motor. I put the motor,trans,and headers in with everything bolted up.
I used to put it in from the top with the steering column removed and the torsion bars removed as well. This made it very easy to do, depending on the type of oil pan you were using. I tried the same method again when I had the motor out for freshening up. I changed out my oil pan to a Milodon low profile wedge style oil pan instead of the tried and true Moroso pan I used to run.
With the wedge profile milodon I had to notch out the k-frame lip for clearance which I did not know about until it fought me tooth and nail trying to get the motor and then I finally saw what the hang up was.
The other way I have put the motor in is from underneath already bolted up to the k-frame. This is by far the easiest and best way to do it in my opinion ESPECIALLY if the car is painted.
Now for future removal/install and hopefully not for loooooooooooooooooong time This is the way I will do it from now on.
Whew I have to take a nap now
