Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: enelson] #56562
05/02/08 07:04 AM
05/02/08 07:04 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
Is anyone using 2" B-body headers or are they all smaller?
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: RacerGofKGB] #56563
05/02/08 12:53 PM
05/02/08 12:53 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Well I had custom headers made for my car. They are 2" to 2 1/8" step headers. I can get to all my spark plugs easily, there are NO sharp bends or dings, I can remove my starter in less than 5 minutes, I can remove or install them quickley with no drama, AND I have maximum ground clearance as they are tucked up nice and tight to the floor pans.
Great investment over the long haul, one of the best moves I made on my car.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: nhramark] #56564
05/04/08 12:23 AM
05/04/08 12:23 AM
IN
67Dart383 Offline
67Dart383  Offline
IN
These are my homemade ones. Modified b-body headers of unknown make.
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: nhramark] #56565
05/04/08 10:17 AM
05/04/08 10:17 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
NHRAMark, custom is definitely the best way to go, I just didn't have an extra $700 laying around. When I do I can always sell these and get some customs. But for now they're on there and seem to fit pretty good.
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: ProSport] #56566
05/04/08 11:30 AM
05/04/08 11:30 AM
SINY
SanityLost Offline
SanityLost  Offline
SINY
When I first built my Dart 15 years ago I did not want cut the car. So this really limited my options especially back then.
I purchased a set of then first issue CPPA headers with 2" primaries down to a 3 1/2" collector.
The clearance issues were ridiculous. I had to finesse the #7 and #8 tube for plug wire clearance.I had to basically crush one tube for Pitman arm clearance and YES it does capture the starter.
I had them in the car for over 12 years. 3 years ago when I built the new motor for the car I looked at other options. Now again not wanting to cut the car really limited my options, BUT atleast there are other options out there now.
I was going to go with Schumacher try-Y header which I think are 1 5/8" primary that step up to 1 3/4" to a 2 1/2" ball type exhaust flange.
Was real tempted with these when saw them in a friends Duster, The fit was awesome BUT was leary of the size of the tubes.
I ended up coming across a Set of New TTI underchassis headers from a failed project for $150. I went with these as my exhaust at the time was built for the CPPA's. Now these are basically the old CPPA header with the clearance issues "supposedly" have been corrected....
What I found was, plug clearance was better but still not optimal and I massaged a few to make it a little better.
I still had to dimple the tube for the pitman arm clearance AND ground down the tip of the stud to the very top of the hole for the cotter pin. One thing I did not have to due that much banging on TTI as I had to do on the CPPA's for the pitman arm clearance.
Having an RB surely helped. I would assume with a low deck that the clearance surely would of been much worse.
Still encases the starter and Manual steering is a must.
Plug changes are still time consuming BUT I have made or modified different sockets and wrenches over the years to make the job easier. I can change 1,3,5,7 in about 10 minutes, 2,4,8 in about another 10 minutes, all from up top. #6 WHOA what a PITA!!! I have to change this one from underneath with socket,wrench on the end of it getting little turns as open space is extremely limited and VERY tight as takes about 10-15 minutes on its own.
I guess it would be easier IF I was to make an access hole in the fenderwell but I deal with it. Plug wires need periodic replacement and should be checked regularly depending upon amount of use for burns.
Plugs #7,6 & 8 are close to the tube. On these inbween the tube and boot I use some header wrap as a buffer.
Now with installation of the motor. I put the motor,trans,and headers in with everything bolted up.
I used to put it in from the top with the steering column removed and the torsion bars removed as well. This made it very easy to do, depending on the type of oil pan you were using. I tried the same method again when I had the motor out for freshening up. I changed out my oil pan to a Milodon low profile wedge style oil pan instead of the tried and true Moroso pan I used to run.
With the wedge profile milodon I had to notch out the k-frame lip for clearance which I did not know about until it fought me tooth and nail trying to get the motor and then I finally saw what the hang up was.
The other way I have put the motor in is from underneath already bolted up to the k-frame. This is by far the easiest and best way to do it in my opinion ESPECIALLY if the car is painted.
Now for future removal/install and hopefully not for loooooooooooooooooong time This is the way I will do it from now on.
Whew I have to take a nap now
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: nhramark] #56567
05/04/08 12:27 PM
05/04/08 12:27 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Mark, do you have any good pics of the headers in your car?
After using TTI headers, ( came with the car ) I just can't see paying $500 or more for a set of headers that don't fit verus $700 or more for a set of custom headers. It is money well spent I think. For other cars I've used Kooks and Tubular Automotive and was very happy with the results. I have no idea who does headers around me now that I live here in Ga, but I'm sure there is someone.
I'm Gumby dammit!
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: GwaiiEagle] #56568
05/15/08 10:38 AM
05/15/08 10:38 AM
Mine are Hedman 75150. 1"3/4 3" col. Accepts power steering. Very minimum denting. In a 383 Duster. Would be better with a 2 inch primary.
Do you have power steering or info to confirm that they fit? Everyone else seems to say manual is required. I'm putting a 383 in my Duster and want to keep the ps. Also, is there an advantage/disadvantage to the '73 and up steering components (different pitman/idler/drag link)?
Pictures/info would be greatly appreciated.
Re: Big Block A-Body Headers (what's avbl? PITAs?) #56569
05/15/08 12:09 PM
05/15/08 12:09 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I have Mad-dawg 2" headers on mine now with low deck 440-1's with a little mod. to #7 and #4. #7 had to be cut and dinged to miss the steering, and #4 hit the torsion bar. Besides that not too bad at all. I bought them off ebay for 550$ I beleive. They fit perfect with my low deck w/ stg 6 heads. This is all with rack-n-pinion steering so can't say about steering clearance.
One day I will have something cool here.
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: sdaurity] #56570
05/15/08 01:05 PM
05/15/08 01:05 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
I guess you need to figure out if you want max performance or just something that will work and kill the performance.
I am using Stahl Headers in my 68 Dart. They were on a low deck with 440-1's. They are 2 1/8 to 4 inch collectors. They are real close to equal length I think with in and inch. There are 3 out and 1 in on both sides. no dinging needed. The only adjustment made was when I went to the new style master cyl I have to move on of the tubes around.
Pics are in the tech section of bigblockdart.com
forgot, they will run you just over a grand. they are slip fit and very, very nice.
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: mopartony] #56571
10/11/08 10:49 PM
10/11/08 10:49 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
MoparTony,
Do you have a web link for the Stahl headers?
OOPS found it. WOW they are pricey. $1,450.00!
http://www.stahlheaders.com/Web321P_1.html
Doesn't say what transmissions will work. I have elephant ears with a 4-Speed on a Low deck with Indy SR's. My Pro-Parts seem to fit very well during mock up. They are an older set of headers, and are getting thin in a couple of places.
Would consider going with the Stahl if I knew for sure they would fit. The will work better with my engine combo though as my ProParts will be a little bit on the small side.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: GTSDave] #56572
10/12/08 12:14 AM
10/12/08 12:14 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Youse got two choices,both underbody since fenderwell headers on a street car suck. tti for manual trans. A-bodies or Schumachers tri-y if you're running a slushbox.
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: SLEDGEHAMMER] #56573
07/13/09 11:13 PM
07/13/09 11:13 PM
Maryland
SLEDGEHAMMER Offline
Maryland
I did find a set of 383-400ci B-body headers at Carlisle this weekend but nothing for a RB motor.
I was hoping to find something so I could check out the fit with a 440.
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: SLEDGEHAMMER] #56574
07/13/09 11:34 PM
07/13/09 11:34 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
The origional "ProParts" headers are no longer being produced and have not been for several years. Anyone that bought them recently simply purchased old inventory which is fine. Bob Mazzolini recently had them remade and improved and also offers a 2 - 2 1/8 step header in the same design. I believe that TTI is producing the headers specifically for Bob. They are not cheap either. They are right up there in price as the standard TTI stuff and Hooker Super Comp prices. Still cheaper than custom. I believe they are like $850 or so. Im not sure, so you would have to contact Bob Direct. I recently asked Bob how they were selling and he said surprisingly well despite the recession. He thinks the economy is starting to turn around because people are buying his headers again.LOL. ANyways Bobs number is 951-787-8783.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: PUNK] #56575
07/14/09 12:34 AM
07/14/09 12:34 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
I LOVE my hooker 2" fenderwells.
the headers come out 10 minutes--the starter in 5 . The plugs are easy to get to . No complaints except they burnt some paint on the firewall...
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: T748] #56576
07/14/09 08:49 AM
07/14/09 08:49 AM
Canada
CrAzYMoPaRGuY Offline
Canada
CPPA headers-
2" primaries, industrial chrome plated.I believe these are the same as modern TTI headers. These headers burned the boots of every plug wire and shield I tried with the exception of Jacobs wires with the ceramic boot. Switching to edelbrock heads cured all plug wire issues. The down side to these are that they totally encapsulate the starter. Want to change it? the motor is going to have to come out. when the motor goes in, the starter better be in the right position. If the body has rotated a bit too much and you get the motor in, you wont be able to spin the starter into it's correct position without pulling the motor back out. I've done all my motor installations by myself hanging the headers and starter roughly in place with safety wire. If you have a helper I'm sure you can knock a few hours off of the installation time.
The starter actually CAN be changed in the car, but it's a pain in the butt. I did mine many times.
When I switched to a ministarter I found out it was JUST in the way of one header tube, which I dinged in the car, teeny tiny little hammer and teeny tiny little swings, took me two hours to make one little ding.
You have to pull the steering column and steering box as well as lift the engine to get the starter out while the engine remains in the car, it ain't fun but it CAN be done!
CrAzYMoPaRGuY
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: Ari440] #56577
07/14/09 08:52 AM
07/14/09 08:52 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
do u remember what the proparts semi's set you back? money wise
call BOB MAZZOLINI
they go for $500 plus shipping
I just got a set of mazzolini tti's 2 1/8 for $936 delivered raw the car I just bought has some nice fenderwells on it.... I WILL be selling one of the sets
Mopar Performance
Re: Big Block A-Body Headers (what's avbl? PITAs?) [Re: 493_DART] #56578
07/14/09 10:23 AM
07/14/09 10:23 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
and when they are coated they look bad AZZ
WAXER
