milky dipstick -318 * UPDATE*
#563530
12/26/09 10:47 PM
12/26/09 10:47 PM
Posts: 763 Nashport, OH
chargers777
Nashport, OH
Anyone else ever see this?Doesnt appear to be water in the oil or pan.I just changed the oil.What could be causing this and is it safe to drive?318 is rebuilt-not by me-and was bored 40 tho.over.It now has 24,000 miles and runs great except for moisture on the dipstick tube.*After fixing the pcv valve and replacing the valve cover breather there is no more moisture on the dipstick tube.Thanks everyone for the ideas.
Re: milky dipstick -318
[Re: Commando1]
#563539
12/27/09 10:21 AM
12/27/09 10:21 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
True, if I was buying a car, and the dipstick was milky, I'd be afraid of it.
however, I also know that it's not a guarantee that something is broke. moisture is normal from combustion. moisture in the oil makes it milky. a lot of short trips, a very humid climate, drastic changes in weather in a short period of time...all can add to moisture in the oil.
just be sure the PCV system IS working, and avoid short trips, and as said, as long as you're not losing compression anywhere, coolant, plugs are looking good, I'd run it.
**Photobucket sucks**
[Re: chargers777]
#563542
12/27/09 11:29 AM
12/27/09 11:29 AM
Posts: 30,457 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
........ except for moisture on the dipstick tube.
COMMON thing to see ...on an engine where the car does not see a bunch of extended driving. On a stop-and-go daily-driver ... it happens a lot.
Now if you took this out on a 100 or 200 mile trip .... and this milky-situation was still present .....it would be a concern then.
[Re: 05dakota]
#563547
12/27/09 09:37 PM
12/27/09 09:37 PM
Posts: 15,491 the boonies
aarcuda
the boonies
remeber the dipstick is cooler than the engine. moisture condenses on cooler surfaceds. thats why to see it on dipsticks and the inside tops of valve covers
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
