Hemi Valve Spring Installer/Remover Needed #563377
12/26/09 08:25 PM
12/26/09 08:25 PM
Central Coast, Calif.
Snoopy Offline OP
Snoopy  Offline OP
Does anyone make a valve spring compressor for a 426 Hemi with the heads installed? I will need to break in the cam and lifters without the inner springs and I am looking for an easy way to do the job.
Re: Hemi Valve Spring Installer/Remover Needed [Re: Snoopy] #563378
12/26/09 08:37 PM
12/26/09 08:37 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Mancini has the tool you need - can also be used in the car.
Re: Hemi Valve Spring Installer/Remover Needed [Re: Snoopy] #563379
12/26/09 08:56 PM
12/26/09 08:56 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I use this tool from Detroit Tools. I was going to give details on it's use in my Hemi book, but the publisher edited that section out.
It's called the 426HemiVSR. I love it.
You can order it directly from Detroit Tools
Contact Mike Pollock at 1-313-942-2816
Re: Hemi Valve Spring Installer/Remover Needed [Re: Mopar_Rich] #563380
12/26/09 10:23 PM
12/26/09 10:23 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Will that work with the rocker still installed??The one I made requires the rockers removed.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi Valve Spring Installer/Remover Needed [Re: SSAAHemiFan] #563381
12/26/09 10:27 PM
12/26/09 10:27 PM
Snoopy Offline OP
Snoopy  Offline OP
It looks like it may be the same tool that Richard shows.
Re: Hemi Valve Spring Installer/Remover Needed [Re: hemi-itis] #563382
12/26/09 10:39 PM
12/26/09 10:39 PM
Snoopy Offline OP
Snoopy  Offline OP
Good question.
What do you use to keep the valves closed?
Re: Hemi Valve Spring Installer/Remover Needed [Re: Snoopy] #563383
12/26/09 11:17 PM
12/26/09 11:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Bought a simple one from Dick Landy years ago, it's a simple fork style. I'm sure someone made them for him but I don't know who, tool isn't stamped. Had to change the handle angle to clear the fender aprons, but it's simple & quick to use in the car now. Compressed air in the cylinder keeps the valves closed. Use a LOT of rags to prevent the keepers from falling inside the heads.
Re: Hemi Valve Spring Installer/Remover Needed [Re: topside] #563384
12/26/09 11:53 PM
12/26/09 11:53 PM
Snoopy Offline OP
Snoopy  Offline OP
Can you post a picture?
Re: Hemi Valve Spring Installer/Remover Needed [Re: Snoopy] #563385
12/27/09 12:06 AM
12/27/09 12:06 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Good question.
It's the same tool that Mancini sells and yes it works with the shafts intact. Just slide the rockers aside, pressurize the chamber to hold the valve closed, and pop the spring. Its' really VERY easy.
Re: Hemi Valve Spring Installer/Remover Needed [Re: Mopar_Rich] #563386
12/27/09 01:53 AM
12/27/09 01:53 AM
Snoopy Offline OP
Snoopy  Offline OP
Thanks for the leads. I think that I may try to make a tool. I am not running monster spring rates, so the tool doesn't need to be massive.
I hate to spend $200 on a tool that will only be used once, I hope.
Re: Hemi Valve Spring Installer/Remover Needed [Re: Mopar_Rich] #563387
12/27/09 08:31 AM
12/27/09 08:31 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Good question.
Same one I have and I got it from mancini. The only problem I have with it is the socket head bolts get in the way of the quick release pin on the exhaust side. Using a hex bolt solves this.
If your doing this on the car, you might find the exhaust a bit tricky. The valve points almost dead on to the inner fender. The fork is such that its a little tricky to get the locks in and it tends to pull the valve spring in toward the intake (you have to keep prying it back on center).
Re: Hemi Valve Spring Installer/Remover Needed [Re: torkrules] #563388
12/27/09 01:12 PM
12/27/09 01:12 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Wizard's Tools also have some additional choices..
http://wizardswarehouse.com/wwproducts.htm
the lever style would be fairly easy to make but may be tough to use in the car without lifting the engine some.
Re: Hemi Valve Spring Installer/Remover Needed [Re: SSAAHemiFan] #563389
12/27/09 01:54 PM
12/27/09 01:54 PM
Snoopy Offline OP
Snoopy  Offline OP
To bad they don't list prices.
Re: Hemi Valve Spring Installer/Remover Needed [Re: Snoopy] #563390
12/27/09 04:30 PM
12/27/09 04:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Pics of mine, #1
Re: Hemi Valve Spring Installer/Remover Needed [Re: topside] #563391
12/27/09 04:30 PM
12/27/09 04:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
and #2
Re: Hemi Valve Spring Installer/Remover Needed [Re: topside] #563392
12/27/09 10:13 PM
12/27/09 10:13 PM
hemi-itis Offline
hemi-itis  Offline
The ones I fabbed up look very similar to yours.I did have to drill a few holes in the rad support to slide the shafts out to remove the rockers
Re: Hemi Valve Spring Installer/Remover Needed [Re: hemi-itis] #563393
12/27/09 10:35 PM
12/27/09 10:35 PM
Snoopy Offline OP
Snoopy  Offline OP
Thanks for taking the time to take the pictures. Have you thought about making any for resale?
